Author Topic: Cooler Master Quick Fire XT improvement?  (Read 3607 times)
Offline Nerif
« on: Sat, 26 March 2022, 16:12:03 »
hi everyone. month ago i have bought a cooler master quick fire xt keyboard with cherry blue switches. i was dissatisfied of the switches because some of them weren't clicking properly, so i decided to replace them with cherry mx black hyperglides and cherry mx clear for win keys (all springs are lubed). also, i have replaced stock thin abs keycaps with some pbt blank cherry profile keycaps. the stock costar stabs are lubed a little bit. I really enjoy typing on this keyboard, but I feel that this is not the end and this keyboard can be improved but i don't know how exactly can i make this keyboard better. Orings suck.
list of my ideas that possibly aren't worth it
•colouring the keyboard case (teal or aquamarine maybe)
•gluing some kind of rubber to the case bottom (like in the silenced hhkb)
•noise isolation
•pe foam (but i don't really know what it is to be honest)
thanks to everyone in advance.
̷C̷M̷ ̷Q̷F̷ ̷X̷T̷ ̷[̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷u̷e̷ ̷→̷ ̷C̷h̷e̷r̷r̷y̷ ̷M̷X̷ ̷B̷l̷a̷c̷k̷ ̷H̷y̷p̷e̷r̷g̷l̷i̷d̷e̷]̷
Anne Pro 2 [Gateron CAP Brown → Kailh BOX Dark Yellow]
Offline Tactile
Re: Cooler Master Quick Fire XT improvement?
« Reply #1 on: Sun, 27 March 2022, 11:22:39 »
Try the easy stuff first. Many people are pleased with the sound change after laying some non-slip rubber drawer liner inside the case. Don't glue anything, just lay it in.
284298-0
« Last Edit: Sun, 27 March 2022, 11:24:14 by Tactile »
REΛLFORCE
Offline Nerif
« Reply #2 on: Sun, 27 March 2022, 12:42:22 »
how will it change the sound of the keyboard? will it make my keyboard sound more quiet or what?
Offline Tactile
« Reply #3 on: Sun, 27 March 2022, 14:02:43 »
A bit quieter with a deeper, more mellow sound. In general, a more "quality, solid" sound.
REΛLFORCE
Offline AASH
« Reply #4 on: Sun, 27 March 2022, 15:25:16 »
My very first advice, if you have the means to do so, would be to desolder everything, lube the switches, lube the stabs and put it back together. Should greatly improve both sound and feeling. Then, while it's disassembled, try what Tactile said. It'll tune down the clicky sound of the switches, probably. Be sure to post back when you're done tho!
40s, with love
Offline Maledicted
« Reply #5 on: Mon, 28 March 2022, 10:29:02 »
hi everyone. month ago i have bought a cooler master quick fire xt keyboard with cherry blue switches. i was dissatisfied of the switches because some of them weren't clicking properly ...
Another unfortunate victim of Cherry MX blue. I hope you give clickies another chance some day. Even the Outemu and Gateron clones are much more consistent than Cherry ... but the MX click mechanism is pretty terrible in general.
Offline granola bar enthusiast
« Reply #6 on: Mon, 28 March 2022, 13:10:03 »
Just like some of the other comments said, putting foam under the PCB would be a great idea.
About the PE foam mod, some people love it and some people hate it (IMO I think its sound is somewhat overrated) but basically, when the foam is on the PCB under the switches it affects the sound at the cause and basically somewhat gives a louder more muted sound (makes sense right?) that frequently causes the keyboard to be somewhat marbly-sounding. I have tried different materials for the same mod and the main what that I liked was LD-PE foam, when testing it on my KBD67 Lite it didn't give the same full-on marbly sound that PE foam gives but brought out the sound a bit more and made it slightly louder. Probably won't be using either PE foam or LD-PE foam for any of my future keyboards but just wanted to give some info on it that nobody asked for.
Offline Nerif
« Reply #7 on: Tue, 29 March 2022, 04:37:13 »
i told that i've changed the blues to cherry black hyperglides with lubed springs
Offline Nerif
« Reply #8 on: Tue, 29 March 2022, 04:38:26 »
"louder more muted sound", ok i won't do this mod
Offline Nerif
« Reply #9 on: Tue, 29 March 2022, 04:40:19 »
in my experience clicky gaterons (or other cherry mx clones) are much worse compared to the genuine cherry switches. gaterons have literally no tactility and the click is annoying
Offline Maledicted
« Reply #10 on: Tue, 29 March 2022, 11:46:52 »
Maybe my test switch is an outlier, but I have mostly read good things about them as well by comparison. All of my Outemu boards are much crisper and less rattly than Cherry, with more defined tactility (probably helped out by the lack of rattle). The Gateron in my tester was almost indistinguishable from my Outemu boards, but that's 1 of 1.
Even my Outemu boards are just disposable boards I lend out to people to try mechanical switches for the first time. I can't stand typing with just about anything MX-based anymore. ¯\_(ツ)_/¯
Offline Nerif
« Reply #11 on: Wed, 30 March 2022, 08:23:08 »
we're opposites 'cause i hate outemu and gateron swithces. imo gaterons sound extremely plasticky and i felt no pleasure while typing on it. meanwhile, i really enjoyed typing on cherry mx switches, i tried blues, browns, silent reds and different blacks (hyperglides, cherry blacks from 2011) and i enjoyed typing on all of them except cherry from 2011 (which i have tried on tt esports meka g1)
Offline Maledicted
« Reply #12 on: Wed, 30 March 2022, 10:45:34 »
I hate every other Outemu MX clone switch I have tried besides blues. Even their browns manage to be scratchier than Cherry's. The tactile event is just better and more consistent with Outemu blue vs Cherry. I haven't tried any MX or clone that didn't feel and sound extremely plasticky, so I guess I'm not concerned with which ones sound slightly more or less so. lol
