Author Topic: [IC] Martingale | PCB mounted 60-percent | Group Buy: End of Sept. 2023  (Read 51127 times)
Offline Aethelberht
What are the final colours?
Apologies if you think I ignored, was just waiting on these haha. Final colours:
Also there will be an internal engraving, the one you see.
GB should be in Mid-March 2023. Should have protos in all colours before then, which is when I will update this thread properly.
Thanks for staying tuned guys!
I was a bit sad that in the original post you said GB was December 2022, then I found out it would be in March 2023. Phew :D
I'm better than all of you combined.
Offline boyjun
Will there be an option for shipping to Canada?
Offline elvenmonster
Yes :)
Offline NOLA
I'm here. Are the 4 colors set, or would you consider sneaking in a LE yellow ano?
Colours are final and streamers units already ready. Just waiting for the right time to release final info.
Offline hzh0525
Simple is great!
Offline lush_bunny
Did this ever run in March?
Offline vhaarr
No, still waiting :-)
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline pixelpusher
We wait
Offline lush_bunny
My watch begins.
Re: [IC] Martingale | PCB mounted 60-percent | Low front height, angle, USB port
« Reply #110 on: Fri, 22 September 2023, 14:41:53 »
Bumping this because we're finally going into Group buy! Will create a GB page very soon.
Offline vhaarr
Re: [IC] Martingale | PCB mounted 60-percent | Group Buy: End of Sept. 2023
« Reply #111 on: Fri, 22 September 2023, 15:57:45 »
Oh noes! That's like 4x HHKBs at the same time; Tempo, Kei, Brutal V2, and Martingale. And hopefully Lily right around the corner maybe :-D
I can't justify that, now I'll have to get picky.
And there's the MM-HHKB as well, though I won't get that because they've got too many GBs running at the moment. I'll wait until they fulfill Class 60 at least.
glwgb
Offline lush_bunny
« Reply #112 on: Sun, 24 September 2023, 01:37:23 »
Did I read the update correctly? This board will run for only the last week of September?
« Reply #113 on: Sun, 24 September 2023, 08:28:02 »
It will be open for a while (like a month, or till the units cap gets hit).
Offline pixelpusher
« Reply #114 on: Sun, 01 October 2023, 21:46:59 »
Planning to join for a green one, but I can’t decide on WKL or HHKB.  Did you ever have a HHKB top made?
Offline iwobobul
« Reply #115 on: Mon, 02 October 2023, 03:16:30 »
So much hype around this board, yet is appears so simple, doesn't even have a weight. What am I missing?
Offline pixelpusher
« Reply #116 on: Mon, 02 October 2023, 09:52:49 »
For me it's well photographed prototypes, the unique brass accent on the DB area, the low profile, the low angle, the way the PCB is top mounted, the unique green color, and the classic side profile.  I am hesitant also because we know this is his first group buy.  At least it's limited to 300 units.  100 would probably make me more comfortable.  I have recently been involved in failed group buys from Mechs & Co, Noxary, and MKB.  I've also had 3 keyboard group buys turned into vaporware over the past decade with a loss of about a grand.  It's a coin toss.  But I like the design a lot.  :p
« Last Edit: Mon, 02 October 2023, 10:00:36 by pixelpusher »
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #117 on: Mon, 02 October 2023, 17:09:02 »
Aesthetically it looks really nice, and there is some complexity here with the machining, not saying this a jane v2 in terms of complexity but I wouldn't say it's basic.
Is it worth 249? ehhhhhh I guess. It does contain a lot of stuff (2 pcbs and a case which adds to cost) but it is more basic and a pretty large moq considering this hobby which drives down price. Personally I would say it's worth it assuming quality control is very top notch. But you're not getting a good deal (not saying it is overpriced at all, just regularly priced)
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline lush_bunny
« Reply #118 on: Sat, 07 October 2023, 13:25:07 »
This piqued my interest because it is:
  • Plateless
  • Top Mount
  • Low Front Height
I never thought I'd get all three of them in a 60% layout, so I guess you could say it caters to this niche.
Offline finalarcadia
« Reply #119 on: Sat, 07 October 2023, 14:23:50 »
Simple outside but complex inside - the low profile design & unique pcb top mount is not something everyone can pull off with such precision.
