Author Topic: [IC] Martingale | PCB mounted 60-percent | Group Buy: End of Sept. 2023  (Read 61999 times)
Offline Versaknight
Looks good!
Offline Saks
Looks promising!
Any discord so we can follow updates?
Offline elvenmonster
Thanks everyone again!!
Discord server soon! In the process of setting it up. Will update the IC with the link :)
« Last Edit: Wed, 13 April 2022, 17:07:01 by elvenmonster »
Offline clickpig
  • naisu naisu naisu
interest piqued, would definitely be down for a hhkb unit.
glwic!
Offline rikercd
Love PCB mount boards and wish they were done more often. In for one 100%
Added a discord server link!! https://dsc.gg/boards@random
« Last Edit: Fri, 15 April 2022, 17:00:30 by elvenmonster »
Offline granola bar enthusiast
i do love plateless board's but wouldn't this have potential issues with the PCB mounting point's snapping off in the far future or is the PCB just more durable than i am imagining in my head
Hi. Not at all actually! I’ve been typing on these for quite a while now, and even when I apply full downward force, the mounting tabs are far away from snapping off. Under normal typing pressure, it is not of any concern.
I appreciate you pointing it out though since I’m sure others probably had the same concern!
Offline ^prince
Quality IC, 250 usd would be an amazing price! Keen to hear a sound test :)
Offline Fnzzy
Looking good! Best of luck with this.
Offline zyyg
Hi,there.
Does pcb support iso layout
Hi,there.
Hello! Yes it will support ISO. I havent uploaded the layout since bottom row layout options arent 100% decided yet.
Offline bobgr8
so nice!
Cheers man!
Offline heyimpanda
looks great, am addicted to low front height/angle board these days
Offline Vono
Looking good at a great price! GL
Offline BasedCoper
Hope the gb does well. Can see you put a lot of effort into this
Offline lush_bunny
I really hope alu won't be included by default.
First, I hope it helps drive/keep the price down.
Two, I love the 7V, but I was not a fan of the "floating plate above pcb mounted keeb" sound profile.
Either way, I'm watching this IC closely. Good luck my dude.
Offline lush_bunny
I have 2 plateless boards (Timberwolf and 7V), still going strong.
You are right, PCBs are more durable and flexible than most people think.
Apart from that, there is a threshold of distance (not sure how far) a PCB will flex before it snaps. The tiny amount of space inside a keyboard will not let that happen.
Offline Visionaire
Great looking board at an attractive price. Following along now. :)
Offline Capsy
Looks great elven  :thumb:
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
I love it! I'm in!
Yes
Thanks for the support people! Really hoping I can provide more consistent updates on the project. Next update would be about the final layout options (mainly with regards to spacebar), and hopefully some news on vendors!
Offline Rafa_n
  • stuffforrectangles.etsy.com
Excited for the next update.
EU vendor would be very nice.
Offline lush_bunny
Would appreciate a SEA vendor. Preferably Zionstudios or Rebult.
Looking forward to more updates.
Offline nick779
Man if this gets offered in WK and that green I might need to buy a few.
Offline lush_bunny
Ah a fellow man of culture. What keycaps would you use on em?
Offline catamscott
mounting looks good, price is awesome and finishing on the proto looks solid. very eager for more information, awesome project!
Offline skrunk
Nice and clean board with a great price!
Past Keyboards : LZ CLS, Unikorn, Noxary X65, KFE CE, HHKB Pro2, Realforce TKL
Current Keyboards: FC660C, HHKB Pro1, GSKT-00
Offline Nonnegaard
please dont, my wallet cant take much more
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline BasedCoper
Sad to see it ended up being worst-case scenario.
Nothing is firm yet. This estimate includes vendor fees!
Offline Backspace2
I was really considering this as a daily driver if it were 250-ish... I think I'll convince myself to buy it either way, but please keep us informed!
Yes
Offline BasedCoper
Hoping its lower, considering Nascent was a 65% that was $290 w/carrying case. Also, it had cerakote, which is more expensive than ano. But I understand vendors are probably the reason for this, hope it does well.
Offline Backspace2
Any updates on how it's going?
Yes
Offline menuhin
Thanks everyone for the support!
Also realized that I’m an idiot and didnt upload layouts. Will do it over the weekend, but you can expect the typical 60% fare. I really wanted to do the og HHKB layout with the larger right hand side blocker, but it likely wont happen. Will mostly include just the regular HHKB option along with WK and WKL.
Also regarding sound tests, they will take some time but I wanna make sure its a representative sound test. I personally do not have a recording setup of any sort, but will ask some friends to record it! Wont happen before end of month though.
Thanks again!!
I am happy that you have ever thought of the true (6u spacebar) HHKB layout.
It's a pity that won't happen in this run.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Yes! Am in the process of talking to vendors, and that can be a bit slow. However, I expect those details to get finalized soon!
Thanks again!!
There are some really interesting boards coming up soon^tm which will have the true hhkb layout (Baul's type-B, and the Matrix 6xv3.0 Falcon come to mind). You should check them out!
Offline menuhin
Thanks again!!
Thanks for the pointers.
With closer to the left F & J homing keys, a left shifted spacebar with 6u or even shorter at 5.5u is an optimized design - I think you might be one of the rarer designers who are aware of the value of the true hhkb layout.
I cannot locate "Baul's type-B"
About Matrix, they have beautiful and interesting designs, and they execute their projects brilliantly. However, I prefer designs that are a bit more minimal than their usual design language. Would be very excited if OWLab (or Qwertykey) or RAMA have a true HHKB option in their future projects, they all have not-so-overwhelming design language (just my personal taste) and their pricing are reasonable.
IBM M13 black
HHKB Pro 2 HasuBT
Offline Backspace2
Alrighty, sounds good. Best of luck!
Yes
Offline unusuaL_
insane pricing for what this is imo, good job  :thumb: glwic & glwgb
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline nlbh
When will GB start?
Offline Mecxs
I don't think there's a public IC for it yet but you can find info in Baul's discord - https://discord.com/invite/v2sWm88
Offline mr_foggy
  • neue = nope
please offer the proto green for public sale, it looks stunning. Imagine GMK Taiga on it
Re: [IC] Martingale | PCB mounted 60-percent | Low front height, angle, USB port
« Reply #93 on: Wed, 28 September 2022, 21:02:46 »
bumping up cause there have been updates :P
Offline funderburker
« Reply #94 on: Thu, 29 September 2022, 07:55:51 »
Cool project, also that proto green  :-*
Keyboard design by Skepur
« Reply #95 on: Thu, 29 September 2022, 08:38:48 »
not a fan of the big chamfers on the keycap side, but aside from this the specs are perfect imo, will watch and see how this project goes. GL!  :thumb:
They're much smaller in the more recent protos. Will post pictures soon, but you can follow my discord for the most up to date pictures! https://discord.gg/9yhpRku2
Offline gilbert
« Reply #96 on: Thu, 29 September 2022, 15:05:48 »
hyped for this
Offline conternecticus
« Reply #97 on: Thu, 01 December 2022, 10:13:39 »
What are the final colours?
Apologies if you think I ignored, was just waiting on these haha. Final colours:
295526-0
Also there will be an internal engraving, the one you see.
GB should be in Mid-March 2023. Should have protos in all colours before then, which is when I will update this thread properly.
Thanks for staying tuned guys!
« Last Edit: Mon, 16 January 2023, 19:42:15 by elvenmonster »
Offline mr_foggy
  • neue = nope
that teal/green is INSANE. definitely picking one up in that color.
