Author Topic: Freebird TKL vs Mode Eighty  (Read 3969 times)
Offline LosTaquitos
  • Professional Procrastinator
    • Keebs.gg Profile
« on: Sat, 09 April 2022, 17:27:41 »
I'm curious to know what you all think about the Freebird TKL and the Mode Eighty. I was considering placing an order for the Freebird but discovered the Mode Eighty before I did and now I'm not sure which I want. The Mode Eighty is double the price, so I guess my biggest question would be is the price increase justified?
E-White & Brass Sonnet | Black Sesame V2 | GMK Civilizations
Offline granola bar enthusiast
Re: Freebird TKL vs Mode Eighty
« Reply #1 on: Sun, 10 April 2022, 12:47:46 »
the mode eighty is designed to be as quality as possible but in my vision it's a bit outdated, in my preference i think the compatibility of both gummy o-ring and top mount (Freebird TKL) is far more useful and important than the possibility to use a stack mount which from what i have heard feels almost as stiff as a tray mount (Mode Eighty), and while you can also use top mount this is also an option on the FB TKL so I wouldn't consider that a point really for the Mode Eighty. Second of all the price point of the Freebird TKL is amazing for what you get, you get something with on par (and in my preference better) value than a keyboard worth 500 dollars or more. I feel maybe when the Mode Eighty was originally released it was considered good for its price but with all of the amazing options for much cheaper pricepoints I think the Freebird TKL is a far better buy than the Mode Eighty. I will actually be getting a FB TKL of my own soon
« Last Edit: Sat, 23 April 2022, 22:12:22 by granola bar enthusiast »
Offline Versaknight
« Reply #2 on: Tue, 12 April 2022, 08:48:07 »
I think the freebird is more value for money but if you like the aesthetics of the mode, go for it. Neither of them are terrible choices.
Offline Versaknight
« Reply #3 on: Tue, 12 April 2022, 08:52:11 »
Although, I would personally recommend something like the glare TKL or the safa588 (extras) or the frog if those are in your budget
Offline LosTaquitos
    • Keebs.gg Profile
« Reply #4 on: Wed, 13 April 2022, 16:40:04 »
The FB TKL is definitely better value, no question there. I chose to go with that instead of the Mode Eighty for that very reason, no point in paying double/more than double the price just for a marginally better experience.
