Author Topic: [IC] Safety Linear Switches | Small Poppy Sound  (Read 7005 times)
Offline goju2506
  • Instagram @goju.works
    • My Instagram
« on: Thu, 14 April 2022, 07:16:04 »
[IC]Safety Switches
Hi keeb lovers,
May I present to you a brand new switch in collaboration with Tecsee, I hope this will bring a new feel to your typing experience.
Safety Switches - Linear with 65g two stage spring
Long pole stem with 3.7mm travel
Stem: UPE mix
Top: PC
Bot: Nylon
Manufactured by Tecsee
Thanks to the material combo, Safety Switches' sound signature stands in the middle between clacky and thocky also with low volume - hence the name Safety! Perfect for using in open workspace without bothering others!
This is a nice little poppy sound that I've been enjoying quite a lot recently - Imagine the crackling of a burning campfire is the best I can describe
Sound test:
IC form: https://forms.gle/P9AV9aSHvDs78TK39
Coming soon to Vendors:
CN: KPrepublic
OCE: Switchkeys
EU: Candykeys
England: Prototypist
Vietnam: TKS
CA: Keypresso
NA: Dangkeebs
SEA: TBD
« Last Edit: Tue, 03 May 2022, 12:17:12 by goju2506 »
Offline Ella
  • Why is it called an oven
Re: [IC] Goju.works Safety Switches
« Reply #1 on: Thu, 14 April 2022, 07:22:33 »
Cherry mx black still unmatched
Offline goju2506
    • My Instagram
« Reply #2 on: Thu, 14 April 2022, 20:38:07 »
Better after 1 million strokes ;)
Offline shendoo
  • *RAUGHS*
Re: [IC] Safety Linear Switches | Small Poppy Sound
« Reply #3 on: Tue, 19 April 2022, 12:34:00 »
Sounds good and love the colorway!
Offline Getsome!!!
« Reply #4 on: Tue, 19 April 2022, 17:47:59 »
Must have for GMK cinder and Carbon people.
Offline lush_bunny
« Reply #5 on: Tue, 19 April 2022, 19:43:12 »
You are a genius
Offline lush_bunny
« Reply #6 on: Tue, 19 April 2022, 19:47:18 »
Consider sending to Theremingoat for a review. Thanks!
Offline Keeblet_257
« Reply #7 on: Wed, 20 April 2022, 08:11:01 »
testing a switch in different positions is joke unless the board sounds the exact same on every key, which I highly doubt to be the case.
the switch isnt the only thing that will change the sound, the place of the key also pays a role.
Offline Zeryph
« Reply #8 on: Wed, 20 April 2022, 12:12:30 »
Awesome color-way! I like the sound too! Not sure if I’ll like the long pole or not, but I’m willing to buy enough switches to fill a TKL and try it out! GLWIC!
