Author Topic: [IC]Realuables Aluminum relegendables  (Read 5030 times)
Offline LegendsWorks
  • thocc
« on: Sat, 16 April 2022, 17:30:59 »
PROJECT CANCELLED
Due to other projects and issues with sourcing the TOP parts of the relegendable caps, I will have to sadly cancel the project, Thank you everyone for the feedback  :thumb:
An aluminum relegendable novelty keycap made for collectors by collectors
RENDERS
RETRO
CLASSIC
PRIME
SPECS
6063 aluminum
Sandblasted sand blasted with a #150 grit
Anodized
Cherry profile
Top caps are being played around with right now, Will update when there is more known
Aiming price is sub 30 USD
Designed by Legendsworks
« Last Edit: Mon, 25 April 2022, 15:33:09 by LegendsWorks »
Offline Fraaaan
Re: [IC]Realuables Aluminum relegendables
« Reply #1 on: Sat, 16 April 2022, 17:50:31 »
Do you have any prototypes? What is the wall thickness? What profile does this match? What transparent material is used for the cover?
  • thocc
« Reply #2 on: Sat, 16 April 2022, 17:57:52 »
Hello Fran, My apologies for not adding enough info into the IC, Will add it right now. Prototypes will be made soon, I got to excited and posted the IC Thread to Fast, Again a mistake on my side, Everything will be out soon sorry for the inconvenience  ;)
Offline herbologist
  • beige enjoyer. send help.
« Reply #3 on: Sat, 16 April 2022, 18:02:24 »
Ic seems premature and is lacking important information. Might be a good idea to participate a bit more in the community.
Sent from my Pixel 6 Pro using Tapatalk
Offline rookb
« Reply #4 on: Sat, 16 April 2022, 18:03:09 »
What colours are these? CR or N9? U9 and L9? How are you going to colour match these?
  • thocc
« Reply #5 on: Sat, 16 April 2022, 18:08:04 »
Greetings Rookb! Color wise I'm currently playing around with the colors and will get some more Information out soon!, Thank you for your comment!
Offline stewfayew
« Reply #6 on: Sat, 16 April 2022, 18:39:59 »
It's like those crime shows. Where they're trying to catch a serial killer. They can't charge one suspect with the same crime twice, so they gather lots of evidence to convince a jury beyond a shadow of a doubt that the suspect did the bad things. They get one shot at nailing the criminal for everything they did.
You can post another IC or add more information to this one later of course. But it doesn't have the same "wow" factor ya know?
Offline Nonnegaard
« Reply #7 on: Tue, 19 April 2022, 03:22:49 »
30 for any alu cap, and im in. i know that it has magnets and faceplates and all that, but $110 for the monokei zimo cap was ridiculous. resin artisans reaching 100 is also crazy, but shee it is what it is
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline saab
« Reply #8 on: Tue, 19 April 2022, 08:10:09 »
More colours would be nice, do you have any pictures of a working prototype?
