Author Topic: [IC] Slate - FRL TKL | New Prototype Photos - 5/21  (Read 24727 times)
Offline Ustinj
« on: Sat, 23 April 2022, 03:37:03 »
Slate FRL TKL
Now that I'm wrapping up on a small self-fulfilled keyboard GB for Moment, here is the very early IC for SLATE, an F-Rowless TKL keyboard that I've been working on for a while. Yes, I spend a lot of my spare time trying to make things...
The Goal
When I start a new keyboard project, I always try to do something a little bit differently. Moment had the angled chamfers and curves; Cloudline had the soft, sweeping, contrasting curve fitting closely with its theming; Derivative has a somewhat interesting side-profile and a gently-curved cherry lip. All of these boards have some form of a shelf / handle side-profile and slightly angled rears, leading to a bit of an 'aggressive' stance between all of them. After seeing so many beautiful and distinguishable boards without shelved side-profiles such as the HHKB HG, Keycult No.2, Bisoromi's Kei, various Noxary boards, etc., I really wanted to make something without the previous shelf design - it proved to be a bigger challenge than anticipated.
To my dismay, I constantly ended up with a keyboard that looked a little too much like something else. It either ended up looking like a No.2 with the gently lifted rear, a wedge with an HG chamfer, or a plain wedge. There is nothing wrong with any of these, because they all looked clean and beautiful... but I didn't feel worth putting it forward, as it didn't have that 'unique' touch that I strive to include (plus I'd probably get roasted for "looking like ______").
I've attempted to start this project dozens of times, and ended up abandoning what I had, dozens of times - it was frustrating!
TL;DR: I badly wanted to make a keyboard design without a "shelf" / handles, but my dozens of attempts were scrapped for lack of identity.
History of "Slate" (expand for more)
The name SLATE was initially chosen around on the basic wedge-like design I was aiming for. The wedge design is usually the very first keyboard design any keyboard designer creates - I created my first wedge on September 5th, 2020 (thank you to my partner Shannie for encouraging me) - a blank SLATE, if you will. The Tofu (the wedgiest of them all) was the first foray into custom keyboards for many enthusiasts here today. Almost every keyboard design I've made starts as a blank slate (Moment, Cloudline, Derivative, this), and is built upon into a more refined, unique, and complete product. Oh yeah, and a slate is also a flat stone that people used to write on.
However, though I've given up on the project multiple times, picked it back up, re-used the name for different designs - I think I've finally settled on a design that *doesn't* have a shelved side-profile, and something different enough that I'm happy with it. I have decided to keep the name SLATE following its annoying history..
Details
  • Layout: F-Rowless TKL (WKL / FULL)
  • Mounting: Top mount / PCB gasket mount
  • Materials: 6063 Aluminum top, [Dyed] polycarbonate bottom, stainless steel / brass weight
  • Typing Angle: 7 degrees
  • Front Height: ~17.5mm, ~22.6mm EKH
  • Plates: tbd, HALF plate by default
  • Pricing: timeline is very far away so will definitely change - target price <$5xx
The Design (finally)
A simple soft chamfer around the front and rear edges of the board transitions seamlessly to a more interesting convex left and right face. The side profile is something I'd liken to an "inverse Dolphin" - while the curves might look a bit expensive, this side profile can be milled entirely with a 3-axis CNC: a convex face, crossed with a 45-degree chamfer on the top case, creates a visual curve that seems to exceed the three linear axes.
Moving towards the bottom edge of the case - the accented bottom piece lifts gently at the edges, giving the board a subtle 'floating' effect. With the planned underglow PCB, cases with clear polycarbonate bottoms can expect a subtle spill of underglow from the sides (to be verified / tested). Also makes the board a bit easier to pick up.
The case design also aims for a fully-screwless exterior design similar to the Keycult No. 2, in which the case fasteners are hidden by a bottom weight that is secured through screws reached through the plate. While it does make assembly a bit more complex and painstaking, it allows us to avoid screw threads tapped directly into the polycarbonate bottom case, which are prone to stripping. Also, it isn't nearly as visible as having the fasteners near the plate between the keycaps. Another highlight of the bottom is the contrast of several materials - an aluminum top case accents the perimeter, while a color-coordinated dyed polycarbonate bottom curves down into the stainless steel or brass weight. The blend of these three different materials is definitely something that I hope to see more of.
The Mounting
The Slate FRL TKL is designed to have two comfortable options for mounting - a classic top mount, and a gasketed PCB-mount. A single layer of non-adhesive (removeable for top-mounting) gasket strips will be sandwiched between the bottom case and the PCB, while the top case's slight compression of the plate will secure these strips in place. If these isolation strips aren't used, the plate can instead be fastened to the top case in your traditional, tried-and-true top mount.
Project Timeline / IC things
Some of you guys may know that I tend to juggle multiple projects (but will never run more than one self-fulfilled group buy at once). I've just wrapped up fulfillment for my previous small run, Moment. The sale model I hope to follow for my projects is is that I'll do a small, self-fulfilled limited run with limited color options and engravings. If people still want the board after, then I'll pass the project to a vendor to do a larger sale, as I can only handle so much myself.
  • Prototype 0 (complete, design changes made)
  • Apr 2022: Initial IC
  • Prototype 1 + PCB prototype (in progress)
  • Q3/4 2022: Round 0 (small run)?
Initial IC Form: https://forms.gle/3hgH18KF895LyHak7
Instagram: https://www.instagram.com/jjw_kb
Discord (any small runs / news will happen here): https://discord.gg/uwBXETHrP9
Prototypes / Media
Was not a fan of prototype 0 - the side profile had large fillets which didn't look great in direct light. Prompted an external redesign (proto enroute). However, the contrasting bottom materials looked fantastic and the screwless assembly worked handily (though I've slightly tweaked the plate to allow for larger tool clearance.
Thank you for any feedback / support.
« Last Edit: Sat, 21 May 2022, 15:08:13 by Ustinj »
Offline sirieous
  • help
Re: [IC] Slate - FRL TKL | Initial IC, Feedback Gathering
« Reply #1 on: Sat, 23 April 2022, 03:38:29 »
very cool mr justin
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Sat, 23 April 2022, 03:39:13 »
that side profile :p
Offline unusuaL_
« Reply #3 on: Sat, 23 April 2022, 03:44:08 »
very interesting variation on the wedge, nice job
collection: hibike 1/1, casper60, hhkb pro2, matrix 2.0additional, cw88
Offline linell
« Reply #4 on: Sat, 23 April 2022, 03:45:23 »
I love the chamfer  :thumb:
bro this a **** set, just be thankful you even getting 1 base running fr
Offline frigidisdead
« Reply #5 on: Sat, 23 April 2022, 03:46:44 »
Looks really cool while still being different than your previous designs. With no exaggeration, I will purchase whatever you release good sir.
Offline chat and team
« Reply #6 on: Sat, 23 April 2022, 03:49:06 »
pricing lol, another boring tkl
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Slayer77
« Reply #7 on: Sat, 23 April 2022, 03:52:56 »
Wow, revolutionary feedback right here!
Sent from my GM1911 using Tapatalk
Offline DuellM
  • Keyboard Fatty
« Reply #8 on: Sat, 23 April 2022, 03:54:11 »
Another Fantastic Keyboard Project 😊. Will Be Watching & Waiting For This  ^-^
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #9 on: Sat, 23 April 2022, 04:01:00 »
[...] If people still want the board after [...]
Dude, go straight to unlimited GB!!!
Beautiful!!!
I'm still waiting for my Cloudline but can't wait for this project to come to fruition. Good job!!!
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline whirlwind
« Reply #10 on: Sat, 23 April 2022, 04:07:22 »
Eating ramen for another month I guess, first it was the cloudline, then the cat tray and now this!
Offline Gnome
« Reply #11 on: Sat, 23 April 2022, 05:08:27 »
Been waiting for this for quite a while. FRL tkl so good.  :thumb:
Some more layout support would be nice, Like split backspace and split Rshift.
Looking foward to GB, Maybe I'll even get a chance to get in on the R0.
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #12 on: Sat, 23 April 2022, 05:11:53 »
Alright I'm sold
French keyboard streamer
Offline Screen.jing
« Reply #13 on: Sat, 23 April 2022, 08:29:17 »
good looking Mr Justin!
Too many projects going on at once
Papilio
MF60
Disco
Vlad
65
Adamo
Offline granola bar enthusiast
« Reply #14 on: Sat, 23 April 2022, 08:52:31 »
side profile looks pretty cool, although on the "gasket"-ish mount is there not going to be something above the PCB where the lower gasket is? would this cause any issues as i have noticed this to not have been done on other boards i have looked at or built
Offline bshendy
« Reply #15 on: Sat, 23 April 2022, 09:53:54 »
this is a fkin clapper, can't wait for this one
Offline wigol2506
    • Instagram
« Reply #16 on: Sat, 23 April 2022, 10:15:52 »
Really appreciate your dedication to the craft; will be interested in going in on this.
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline dantambok
« Reply #17 on: Sat, 23 April 2022, 10:38:26 »
ooo i like the curves
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / Duck Viper v3 / HBCP / Noxary 280 / LZ Physix / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 350 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT / LZ Erghost /  Finder Works Hyphen / 2x Singa Kohaku / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / QK80 / Keycult No 2 TKL / FLX Virgo r2 / Matrix Navi / JJW Derivative / TGR Lena
Coming --   Lynx50 (wixx scammed us) / Ladybird60 / TGR Shi
100+ GMK sets
Offline Ghostinn
« Reply #18 on: Sat, 23 April 2022, 10:59:47 »
Absolutely gorgeous design, will follow this as the prototypes come in. Excited to see this project come to fruition!
Offline WXYaa
« Reply #19 on: Sat, 23 April 2022, 11:22:18 »
Very very nice!
Offline darthcapn
« Reply #20 on: Sat, 23 April 2022, 11:38:34 »
Aahh I love all your designs so much!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline Draxion
« Reply #21 on: Sat, 23 April 2022, 11:41:05 »
Gold
« Reply #22 on: Sat, 23 April 2022, 12:05:42 »
So hawt
Offline ImaSpacePotato
« Reply #23 on: Sat, 23 April 2022, 12:29:46 »
Nice to see more FRL TKL, though can't say the curves are for me.
GLWIC anyways.
Offline pyrobunny
« Reply #24 on: Sat, 23 April 2022, 12:45:55 »
Absolutely beautiful board, that side profile looks fantastic! This could very well be my first FRL TKL  :)
Offline pepperfez
« Reply #25 on: Sat, 23 April 2022, 13:25:01 »
I would like for you to stop designing boards that will make me cry when I lose the lottery to buy one.
Offline BasedCoper
« Reply #26 on: Sat, 23 April 2022, 16:40:19 »
Love me some top mount FRLs. But why go "screwless" and force us to see every screw ALL the time... :(
Offline autumnfall
« Reply #27 on: Mon, 25 April 2022, 19:54:52 »
There's lots of FRL TKL lately, but this one is particularly good looking!
Offline pixelpusher
« Reply #28 on: Mon, 25 April 2022, 20:25:45 »
Is there a render of the entire keyboard?
Offline Nonnegaard
« Reply #29 on: Tue, 26 April 2022, 05:17:53 »
it looks like an Andromeda. jk
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline flying1911
    • Mechlovin' Studio
« Reply #30 on: Wed, 27 April 2022, 19:58:13 »
Justin never disappoints. Another great design!
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline yangsiyin
  • Hello World~ Keebs
« Reply #31 on: Wed, 27 April 2022, 22:54:28 »
front-face: hmmm TKL?!
side-face: Shut-up and Take my money~~~~
Offline exusiailover79
  • winning
« Reply #32 on: Wed, 04 May 2022, 01:46:29 »
beautiful board that curve pulls gooch im in
Offline Ustinj
Re: [IC] Slate - FRL TKL | Prototype 2 Photos - 5/21
« Reply #33 on: Sat, 21 May 2022, 15:07:56 »
Just took delivery of the latest prototype. Now having it in person, I'm very very pleased with how it looks. I don't think I'll be exploring the option of thinner vertical bezels anymore - I think it looks really good how it is, definitely was not expecting for it to  look this good in person.
Offline less_blank
Re: [IC] Slate - FRL TKL | New Prototype Photos - 5/21
« Reply #34 on: Sat, 21 May 2022, 18:35:39 »
Proto looks so good. Thick bezels is definitely the right call.
Offline Ashen_21
« Reply #35 on: Sat, 21 May 2022, 22:37:42 »
The love the design and that side profile! GLWIC!
Offline prashnerd
« Reply #36 on: Sun, 22 May 2022, 05:27:07 »
After seeing the design of the Neson 700e I have been more and more convinced of the FRL TKL layout. I think I would be very sorely tempted by this board if the timing works out and is priced well. Definitely going to be watching this with great interest. Also, is this going to be offered with a hotswap PCB option or solderable only? If the latter, I hope we see more options for layouts like split backspace etc.
Watching the thread for now!
Offline Friendship
« Reply #37 on: Thu, 26 May 2022, 08:43:48 »
Dang I really like this, well done! Hopefully I can snag one ;D
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline hottrout
  • I'd Hit Dat Key
« Reply #38 on: Fri, 27 May 2022, 09:08:41 »
Clean ... very clean.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline EdgeOfInfinity
« Reply #39 on: Wed, 22 June 2022, 23:25:23 »
nice work dude!
Offline TQuest
« Reply #40 on: Fri, 12 August 2022, 01:21:16 »
Love the side profile and overall design. The top mount / pcb mount option is very interesting - does this mean there is a possibility to go plateless using the pcb mount option?
Offline shendoo
  • *RAUGHS*
« Reply #41 on: Tue, 16 July 2024, 13:04:50 »
Love the design! Any update on this??
Offline tankLancer
« Reply #42 on: Sun, 18 August 2024, 10:02:59 »
Great design! The wedge diagram initially raised concerns about potential finger fatigue when I have to move the keyboard around. Yet the ergonomic and elegant curve on the prototype really impressed me.
GLWIC.
