Author Topic: [IC] Rose60 (Interchangeable Layout Seamless Screwless 60%???)  (Read 20353 times)
Offline kiwikang
Hello there!
My name is Kiwi from Keyspensory and we want to bring a new project from overseas to the western audience!
Keyspensory would like to introduce.....
The Rose60 by LYJ Studio
Links:
Keyspensory Discord:  https://discord.gg/buZSJX3sz3
Here are the current specs of the board!
Case Material: 6063 Aluminum
Colors: Fixed Combination in Black, Ewhite, Pink, Blue
Group Buy Format: Unlimited
Degree: 6
Mount: Poron Gaskets
Extras: Carrying case, PCB Foam, Bottom Case Foam, Battery Slot Foam, Bumpon
PCB: Standard ANSI 60% Hotswap flexcut PCB Included, GH60 style pcb supported (dz60, gh60, etc)
FRONT PANELS CAN BE CHANGED OUT FROM WK/WKL/HHKB VIA MAGNENTS
Extra Options:
Front Panels in WK/WKL/HHKB layout (Different colors will be available) & Plates (as listed below)
Structure
Pieces: Top/bottom piece, weight, top magnetic piece (Interchangeable to WK,WKL,HHKB)
Plate Material: Aluminum, FR4, PC
Poron Foam: Plate Foam, Case Foam, Battery Slot Foam
Expected GB: June 2022
Expected Lead Time: Depends on how many units are sold (We will update this when the GB is closed)
Expected Price: <$250
Vendors:
US: KeysPensory.store (DC:https://discord.gg/VN3bucdxHQ)
SEA: IlumKB
EU: KeyGem
CA: Kanatakeys
PH: Zion Studio
UK: TBD
AU: TBD
Type Test:
We will contact different content creators on making different videos to showcase all types of configurations! The first post will be updated with sound test as they go out!
Renders
Black/White
Black/Pink
White/Pink
Pink/White
Pink/Black
White/Blue
Blue/Black
Blue/White
Blue/Pink
Prototype
WK
HHKB
« Last Edit: Sun, 24 April 2022, 22:07:22 by kiwikang »
Offline BasedCoper
Re: [IC] Rose60 (Interchangeable Layout Seamless Screwless 60%???)
« Reply #1 on: Sun, 24 April 2022, 21:26:27 »
Seems like a cool concept and alright price. Why go screwless though? GLWIC
« Last Edit: Sun, 24 April 2022, 21:29:00 by BasedCoper »
Offline freather
    • Keyspensory
« Reply #2 on: Sun, 24 April 2022, 22:05:03 »
there are screw inside, but from outside it looks screwless lol
Offline kajahtaa
« Reply #3 on: Sun, 24 April 2022, 23:34:13 »
Cute
Offline chat and team
« Reply #4 on: Mon, 25 April 2022, 00:52:17 »
meh it should have stayed china only
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Botty212
« Reply #5 on: Mon, 25 April 2022, 01:03:25 »
meh feedback should have stayed quiet
« Last Edit: Mon, 25 April 2022, 01:06:07 by Botty212 »
« Reply #6 on: Mon, 25 April 2022, 01:35:18 »
you straight up have no feedback.
This was about 150 USD during china gb up 100 . Man those ocean freight companies are charging so much!!!
Offline SDKCAMPING
« Reply #7 on: Mon, 25 April 2022, 08:21:55 »
I do not see why not, this is the second time I've seen you question screwlessness even when the screws are not visible from above, what is the downside of it?
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Getsome!!!
« Reply #8 on: Mon, 25 April 2022, 08:58:30 »
Who doesn't like to screw?
Offline BasedCoper
« Reply #9 on: Mon, 25 April 2022, 09:09:15 »
https://www.twitch.tv/blacksimon/clip/RefinedPlayfulZebraFeelsBadMan-7soHRtpYHDobA0jO
Main downside aside from the fact that instead of never seeing the screws you get to always enjoy seeing them, is the fact that it, as far as I know, is almost always more expensive to machine, for something that ultimately doesn't matter, because you never see the screws at that bottom of your board anyway.
« Last Edit: Mon, 25 April 2022, 09:13:10 by BasedCoper »
Offline rpiguy9907
« Reply #10 on: Mon, 25 April 2022, 13:04:27 »
This is lovely and well priced. Will definitely pick one up!
Offline 583921282
« Reply #11 on: Mon, 25 April 2022, 17:55:23 »
I see what you mean. However, it would be different this case. The top screw is hidden by the magnetic front panels, so you would not see any screw holes from the top down and bottom up
Offline TheIcyKoala
« Reply #12 on: Mon, 25 April 2022, 20:58:01 »
I think this is my favorite looking interchangeable blocker board thus far  :thumb:. I'm curious how this compares to the isabell yg have coming, esp considering they are in a similar price range iirc.
Offline zebus
« Reply #13 on: Tue, 26 April 2022, 10:19:17 »
Sure it's not possible bc of the cost associated with it, but man a frosted polycarb front panel option combo'd with the white aluminum frame would be sick.
« Last Edit: Tue, 26 April 2022, 14:09:31 by zebus »
Offline Jho
« Reply #14 on: Mon, 06 June 2022, 19:48:42 »
Very interesting design. And that potential price projection is very promising too.
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #15 on: Sun, 12 June 2022, 00:13:35 »
Hoping it's possible to just buy an extra mid piece so that I can swap up the color on mine. I'm getting tired of ewhite
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline philipb
  • Enigo designs
« Reply #16 on: Sun, 12 June 2022, 02:00:50 »
This is actually a really intelligent implementation of screwless design. Cheers! Board looks cool.
Offline philipb
  • Enigo designs
« Reply #17 on: Sun, 12 June 2022, 02:03:36 »
In this instance, it probably isn't that much more expensive to machine. The screws are hidden by a thin piece of aluminum, not a giant backweight. The added cost is probably insignificant.
And you can also make that same argument with pretty much any other back design. Why do boards like the KC no. 2/Kei/Unikorn/Jane etc. all have back decorations if you never see them anyways? Tiny aesthetic details matter sometimes, especially when a lot of this hobby is just taking pictures of the stuff you bought.
« Last Edit: Sun, 12 June 2022, 02:08:25 by philipb »
Offline conternecticus
« Reply #18 on: Sun, 12 June 2022, 06:16:42 »
iirc the groupbuy in China was case + plate only, no PCB.
Offline MOSEXD
« Reply #19 on: Mon, 13 June 2022, 16:19:08 »
That's a beauty, I'll grab one for sure!
Offline MrEsosmao
« Reply #20 on: Wed, 15 June 2022, 17:44:33 »
Happy to see HHKB getting love! :thumb:
« Reply #21 on: Tue, 21 June 2022, 10:14:54 »
There was an issue with the top case being loose and jiggle in the China groupbuy. Has this issue been addressed in the global GB?
Offline vrapan
« Reply #22 on: Wed, 24 August 2022, 13:39:07 »
does the layout actually support arrow keys?
