Author Topic: [IC] Theca x Rubrehose | Group Buy November 16-30th  (Read 47485 times)
Offline densus designs
  • * St. Jude Supporter
« on: Sat, 21 May 2022, 03:09:42 »
Theca x Rubrehose by Densus Design & KLC
More Pictures
Pics taken by jtqx#8261, @joshkeyboards on instagram
My Discord My Instagram
KLC's Discord KLC's Instagram
Board Features:
- F12 WKL or WK TKL layout with ANSI and ISO Support
- 18mm front height without feet
- 2.8KG Built
- Custom Silicone Gasket Mount or Top Mount
- 8-degree typing angle
- “Seamless” Sides
- Recessed USB-C port parallel to your desk
- Internal Brass Weight
- External Silver coloured brass or Brass Weight
- MX or Topre PCB
Final Information:
Theca GB will start on November 16th and be open for two weeks, closing on the 30th. GB may close early if soft cap is met.
Mounting:
V1 Gaskets Left, V2 Gaskets Right. Only 20A in Black (matte) for final production.
Theca can be mounted in two ways: Top Mount or Gasket Mount.
Unlike most other gasket mounted boards, Theca utilizes custom injection moulded silicone gaskets to achieve a smooth and flexible typing experience, accompanied by the recessed areas on the bottom case for increased flex.
After manufacturing and testing prototypes using different gasket thicknesses, I am extremely satisfied with the resulting typing feel and flex. Gaskets will be available in only 1 hardness: 20A Durometer (Black). Due to the lack of adhesive between the gaskets and plate/case, harnesses can be seamlessly installed and swapped without frustration or clean-up.
As well as this, Theca can also be mounted to the top case using 8 screws for a more classic typing feel.
Topre Addon Kit:
For Theca, we will be offering an addon kit for topre compatible parts, this kit will include PCB, plate, standoffs and screws. Designed by the Talented Cipulot, this pcb allows for multi-layout options including 7u & 6.25u bottom rows along with stepped and regular capslock. Above are some pictures of the PCB with artwork by Rubrehose!
Internals:
Theca's Internals have been updated since the initial prototype, this will provide a cleaner look and should give a more even sound.
Please note that all brass weights will be clear-coated.
Included Carry Case:
This premium carry case included with Theca has been designed to make it easy to place and pick up boards with wide side openings for hands. This bag uses two custom moulded eva parts to hold Theca while also separating extra parts such as plates, PCBs and extra gaskets. Sponge foam has been adhered to the top of the case to prevent damage during shipping and daily use.
Colours Available:
Black Ano, Brown Ano (same as rotor) & E-Beige (E-coating)
PCB & Layouts
- Winkeyless or Winkey
- ANSI and ISO Support
- Regular and Split Backspace Support
- Regular and Split Left and Right Shift Support
- Regular and Stepped Caps Support
- 6.25u & 7u bottom row options
Build Stream(s) and Typing Tests
Xanniard - DONE
Ruminative- DONE
GymLeaderNathann - DONE
XinXinWong- DONE
Georen-  October 26
StarFirePenguin- October 31
TimKeyLess- TBA
WarmThoughts- November 6
Enomooshiki- TBA
Lighting keyboards- TBA
« Last Edit: Mon, 07 November 2022, 05:34:31 by densus designs »
Offline Invezting
Re: [IC] Theca x Rubrehose | Premium TKL with Dual Mounting!
« Reply #1 on: Sat, 21 May 2022, 03:11:37 »
This is dope
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Sat, 21 May 2022, 03:12:38 »
What does the plate look like?
« Reply #3 on: Sat, 21 May 2022, 03:14:52 »
Ill add a photo of the plate now!
Offline darthcapn
« Reply #4 on: Sat, 21 May 2022, 03:19:18 »
Hottieeee! Looks so good.
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline ankit
« Reply #5 on: Sat, 21 May 2022, 03:20:38 »
« Last Edit: Fri, 02 September 2022, 18:25:41 by ankit-sachdeva »
« Reply #6 on: Sat, 21 May 2022, 03:24:28 »
Thank you for the feedback, I can post some more photos shortly as well as an ic form for plates and colours.
Offline chat and team
« Reply #7 on: Sat, 21 May 2022, 03:28:21 »
cool and all but we all already know this is going to be 500+
geekhack mods constantly break tos and refuse to read
Chinese overlords won
« Reply #8 on: Sat, 21 May 2022, 03:30:43 »
Again, pricing has not been decided but this is 2.8kg built with 2 different weights and 3 different materials depending on configuration.
Offline Sissy
« Reply #9 on: Sat, 21 May 2022, 03:40:28 »
Aw yea very nice. Only real downside I see is not a universal PCB but not the biggest issue
Offline DubbTom
« Reply #10 on: Sat, 21 May 2022, 03:41:10 »
Brown please. Tyvm
poker II
Offline arium
« Reply #11 on: Sat, 21 May 2022, 06:30:41 »
beige and brass pls
Offline finalarcadia
« Reply #12 on: Sat, 21 May 2022, 08:32:02 »
Awesome <3 Rubrehose
Sent from my SM-S908U1 using Tapatalk
Offline Bub
    • big bub's beepers
« Reply #13 on: Sat, 21 May 2022, 08:47:16 »
interested in e-beige. got any more photos?
please consider trying to run small duration unlimited GB over raffle
Offline superjackie
« Reply #14 on: Sat, 21 May 2022, 11:53:55 »
what layout does hotswap pcb support? fixed ansi only(stepped cap?), or iso hotswap possible?
Offline sirieous
  • help
« Reply #15 on: Sat, 21 May 2022, 13:34:13 »
Neat weight
Offline forgiivn
« Reply #16 on: Sat, 21 May 2022, 14:37:49 »
Very nice, can't wait!
Offline Kinesiologist
« Reply #17 on: Sat, 21 May 2022, 17:30:37 »
hope to see more color options, love the design tho
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #18 on: Sat, 21 May 2022, 19:19:33 »
Silver and Brass would be a killer combo with deadbeats! 100% in!
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #19 on: Sat, 21 May 2022, 19:59:19 »
Props to you and chad on this! Very intresting internals love to see it.
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline Xanira
  • Where am I? Who am I?
« Reply #20 on: Sat, 21 May 2022, 20:10:33 »
gib
Offline ARSLOCK
  • CarolinaMech.com
    • Carolina Mech
« Reply #21 on: Sat, 21 May 2022, 20:16:33 »
How many units available?
Offline lionblinds
« Reply #22 on: Sat, 21 May 2022, 20:37:20 »
Cool,wish that would be an unlimited GB
Offline kbye
« Reply #23 on: Sat, 21 May 2022, 21:05:02 »
Didn’t think I’d want another TKL but here I am. Looking great so far
Offline dantambok
« Reply #24 on: Sat, 21 May 2022, 21:36:47 »
dank weight design!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / Duck Viper v3 / HBCP / Noxary 280 / LZ Physix / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 350 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT / LZ Erghost /  Finder Works Hyphen / 2x Singa Kohaku / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / QK80 / Keycult No 2 TKL / FLX Virgo r2 / Matrix Navi / JJW Derivative / TGR Lena
Coming --   Lynx50 (wixx scammed us) / Ladybird60 / TGR Shi
100+ GMK sets
« Reply #25 on: Sat, 21 May 2022, 22:23:55 »
IC Form has been posted.
IC Form
Depending on Interest, we are looking into a limited run of WK tops.
« Reply #26 on: Sun, 22 May 2022, 02:16:37 »
For those that wanted to see what e-beige looks like, here is e-beige on a new lin whale!
Offline rmendis
  • Artisan addict
« Reply #27 on: Sun, 22 May 2022, 10:04:59 »
Offline catamscott
« Reply #28 on: Sun, 22 May 2022, 12:15:40 »
very nice! mounting looks good and gasket socks over separate strips is nice, weight looks nice and the internal cuts look neat. that e-beige is hot too. really interested in seeing how this turns out  :thumb:
edit: topre kit would be really really cool too!
« Last Edit: Sun, 22 May 2022, 14:30:47 by catamscott »
Offline Nonnegaard
« Reply #29 on: Sun, 22 May 2022, 14:07:05 »
this is extremely hot
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
« Reply #30 on: Mon, 23 May 2022, 01:05:57 »
Hello, Just wanted to answer a few questions and some feedback from the IC form.
1. This board will not be offered in F13, only F12.
2. Soldered will be the default PCB, Hotswap will be available as an add-on.
3. KLC will be the only vendor of this board.
4. More plates will be added and tested. So far we have: Aluminium, Carbon Fiber & FR4. PC and POM are still being decided.
5. Half plates will also be available, still haven't decided on what materials, no plastic ones will be offered.
6. No polished weight options will be added.
7. No more colours options will be added.
8. Winkey option will be available, depending on interest it may be only available in certain colours.
9. Thank you for the great interest in the topre kit. Currently the prototype plate is being made and the pcb is still in the design phase. After testing we will see if  it can be offered with this board.
Thank you again for the overall high interest in this keyboard!
Offline SDKCAMPING
« Reply #31 on: Mon, 23 May 2022, 02:10:50 »
I'm a fan, and the price is better than most TKLs now too, following
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Adelscott
« Reply #32 on: Mon, 23 May 2022, 04:06:23 »
Where did you see the price ?
Please think about ISO users, add a split left shift to your "alice style" keyboards
« Reply #33 on: Mon, 23 May 2022, 04:36:43 »
It was posted briefly but removed it as it was very rough. I had wrote 450-550usd.
« Last Edit: Mon, 23 May 2022, 04:39:27 by densus designs »
Offline UGunaLOSE
« Reply #34 on: Tue, 24 May 2022, 12:43:26 »
PogChimp
« Reply #35 on: Mon, 30 May 2022, 03:12:46 »
Update 30/5/22:
We have decided to only include 30A hardness for the gaskets due to the harder 50A gaskets feeling the same as top mount and with the compression, its much harder to assemble the case.
We will also remove the internal mounting point due to the interference of Topre housings. Instead we have chosen to use a magnet for the middle screw point. All the other screws will remain unchanged.
Offline LegendsWorks
  • thocc
« Reply #36 on: Mon, 30 May 2022, 04:49:02 »
Looks good, I'm not sure if I missed it but is there INFO on the colors that will be avail?
« Reply #37 on: Mon, 30 May 2022, 05:29:43 »
4 colours are currently mentioned, Black and E-Beige are confirmed but are still deciding between silver and brown (currently tied on IC form)
Offline DJ Clicks
« Reply #38 on: Mon, 30 May 2022, 07:25:54 »
Is it possible to have the option to choose solder or hotswap instead of being forced to get solder and buying hotwap as extra? Also would hotswap be cem3 as well?
« Reply #39 on: Mon, 30 May 2022, 07:45:56 »
Currently pcb options wont change, both cem3
Offline mvkb
  • Designer
    • MVKB
« Reply #40 on: Mon, 30 May 2022, 07:56:53 »
Does this mean 3rd party PCB's will fit?
Love all the updates you've been posting here, might want to update the top post with all the new details 🙂
« Reply #41 on: Mon, 30 May 2022, 08:18:15 »
Yes it does now! as long as the pcb has a jst connector it should be fine, havent tried any south facing stabs though.
Thank you,
I will be updating the thread now!
Re: [IC] Theca x Rubrehose | Colour Options Finalised, Updated internals!
« Reply #42 on: Tue, 07 June 2022, 07:49:39 »
7/6/22 Update:
- Internals have been updated, grooves removed, brass weight covers DB channel.
- Final colour options have been decided: Black Ano, Brown Ano (same as rotor) & E-Beige.
- IC form closed
- Larger proto order will be placed in the next few days for build streams!
Offline yukitoki
« Reply #43 on: Tue, 07 June 2022, 13:13:23 »
Thank you for the updates.
Offline Diggidy
« Reply #44 on: Wed, 08 June 2022, 04:39:53 »
Please consider a non-engraved weight option.
I like the board, and am super interested in the topre addition; however, the weight design is very cartoonish to me and a complete turn off.
« Reply #45 on: Wed, 08 June 2022, 05:25:27 »
Thank you for the feedback but there won't be a non engraved version.
« Reply #46 on: Wed, 08 June 2022, 22:13:58 »
nice
Offline rmendis
  • Artisan addict
« Reply #47 on: Wed, 08 June 2022, 22:48:04 »
7/6/22 Update:
- IC form closed
Awesome! Is brown anno the same as this: https://imgur.com/a/uQVvS9B ?
« Reply #48 on: Wed, 08 June 2022, 22:51:22 »
7/6/22 Update:
- IC form closed
Yes it is, that was the first prototype of Rotor and it wasn’t perfectly matched to the correct pantone. Here is the link the final prototype that is patched well.
https://www.instagram.com/p/CYicBB9vayX/
Offline granola bar enthusiast
« Reply #49 on: Thu, 09 June 2022, 09:28:38 »
KBD67 lite and many other boards that use silicone gaskets had an extremely stiff feel and the silicone did not help the boards in the slightest, how is the flex on this board?
