Author Topic: [IC]Tyche75 [02]  (Read 10210 times)
Offline chaucer
[IC]Tyche75 [02]
« on: Mon, 06 June 2022, 20:13:18 »
:)Hello there
It's been a long time,
I'm Chaucer and it's been 5 months since the last IC. Thankfully, we have managed to produce and deliver a number of products.
 Now, let's get reacquainted, Tyche75!
:)First of all, the Tyche in the name Tyche75 is derived from the Greek mythology of Tyca (Τuχη, Greek for "luck", "fortune").
(Τuχη, Greek for "chance", "luck"), the ancient Greek goddess of luck and prosperity
The design of the nameplate is taken from the main part of the author's print
The nameplate is laser-radiographed in pure copper with a transparent electrophoretic finish
Disassembly diagram and disassembly video
The first batch of users received the kit and responded that the mounting was too tight and the positioning plate was too tight
So the interface PCB and the positioning plate were rebuilt
Brass plates
PCB section (hot-swappable, Bluetooth wired dual-mode
support mac system, Bluetooth dual-mode function
support up to 2 devices to code, optional connection to Bluetooth devices,
 default 6 keys without punch, can shortcut key conversion to full key without punch)
Software part is VIA solution
[/b]
Upper left corner indicator supports (static, fade, rainbow flashing, rainbow flowing, blinking, breathing light, etc.) brightness adjustment, speed adjustment, saturation adjustment (can be adjusted quickly via shortcut keys, no need to connect to software), power warning flashing function
Default firmware is wireless mode off indicator (can update firmware to on, auto hibernate to wake up by itself)
The studio provides subsequent firmware updates from time to time (QQ group and the official website provide downloads) Official website: Tyche75.com
The dimensions are shown below and the kit weighs approximately 2290g when assembled
Basic Info.
- Layout. 75%
1: Keyboard body Top and bottom cover*1 Includes bottom nameplate*1 Front brand nameplate*1 Top cover light guide*1
2: Bottom acoustic foam*1 sandwich foam*1 poron strip*16 under shaft pad*1 (Inoue, Japan)
3: Positioning plate*1 (optional)
4: PCB*2 (Type-C part Keyboard part)VIA Compatible
5: Mounting screws*1 bottle (includes 6+1 class bottom M2.5 , 2 screws M3, PCB fixing screws, screwdriver to be provided)
6: Power supply battery*1 (2200 mAh 3.7V)
The lower case battery compartment is security and limited number (limited to 100 sets per colour)
About the housing
The first Tyche 75s are CNC machined from 6 series aluminium
Available in 4 colourways in Anodised Silver, Anodised Black, Electrophoresis White and Electrophoresis Grey. Finished by a manufacturer with experience in production.
Colour comparison of real pictures
Rendering colour comparison
Finally from a player shot
Discord
https://discord.gg/3sQRHpkp
Web
https://tyche75.com
« Last Edit: Tue, 07 June 2022, 02:39:02 by chaucer »
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
Re: [IC]Tyche75 [02]
« Reply #1 on: Mon, 06 June 2022, 20:17:05 »
Really cute board! GLWIC =)
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline chaucer
« Reply #2 on: Mon, 06 June 2022, 20:28:17 »
Really?
Offline DirtyGingy
« Reply #3 on: Mon, 06 June 2022, 20:36:16 »
This is one hell of a board concept. I definitely need to read through the post more when I have a little free time
Offline chaucer
« Reply #4 on: Mon, 06 June 2022, 20:43:59 »
This damn BBS forum code, sorry
« Reply #5 on: Mon, 06 June 2022, 22:33:24 »
Seen some posts suggesting runner is sus on prev IC threads. Lack of rebuttals and frequently repeated ICs of the same design lend credence to that. If anyone has more info please share.
Link to a prev thread:
https://geekhack.org/index.php?topic=115106.0
Offline chaucer
« Reply #6 on: Mon, 06 June 2022, 22:50:19 »
Hi,Since the last IC, it has gone into production and this IC post is actually the last one before GB, the post where you can see our products in real life.
Offline Keeblet_257
« Reply #7 on: Sat, 11 June 2022, 10:13:43 »
why is the IC not getting updated and why is there no GB post when the GB dropped already?
« Last Edit: Sat, 11 June 2022, 13:39:08 by Keeblet_257 »
Offline Akele
« Reply #8 on: Sat, 11 June 2022, 17:46:07 »
I'm not a fan of the Emo Toys badge on the frame, but other than that this is a great looking board.
Offline chaucer
« Reply #9 on: Sun, 12 June 2022, 16:33:40 »
We are ready to go, we now need to sort out the shipping as well as the agency. GB will be issued afterwards
Offline chaucer
« Reply #10 on: Sun, 12 June 2022, 16:35:25 »
Well, I hope to follow up with more nameplates to choose from
Offline hzh0525
« Reply #11 on: Fri, 17 March 2023, 05:51:34 »
I will stand for this simplified design style~~ Expecting more kits to be released~
Offline Dmitri
« Reply #12 on: Mon, 24 April 2023, 17:41:42 »
Will this get a GB?
