Author Topic: [IC] GMK White on Black Essentials - GB starts February 27th  (Read 242330 times)
Offline GMK83
Re: [IC] GMK White on Black Essentials - waiting for quotes
« Reply #200 on: Sat, 10 December 2022, 20:30:37 »
Any timing on this running?
Offline Razer1987
« Reply #201 on: Mon, 12 December 2022, 06:15:55 »
- Added 2 heart key, R1 F13 as well as R1 = to extensions kit
I feel dumb but I need to ask, is the 2 heart key a reference to something in particular? in the UK or in the hobby?
Offline II_Versey
« Reply #202 on: Mon, 12 December 2022, 11:45:50 »
I'm probably go for the extras/pre-orders than the gb lol since of gmk 2yrs wait time
Offline IOVERCALLHISTIOCYTES
« Reply #203 on: Mon, 12 December 2022, 12:10:14 »
Thats totally understandable, but getting these kits made at all is decidedly not a sure thing. Still waiting to hear on beige extensions but the 2 week numbers weren't good and with other vendors mightve had several kits canceled.
Offline ankit
  • Formerly ankit-sachdeva
« Reply #204 on: Mon, 12 December 2022, 12:35:43 »
Originally was from a 1800HAU. Emir made a new mold with GMK Rouge. mcmcmc is making a new "fixed" mold with GMK Beige Addon & Extension that is available to everyone to use. Photos of the OG cherry board can be found in both threads.
Offline blunt
« Reply #205 on: Thu, 15 December 2022, 00:56:31 »
Resubmitted for quotes a few days ago with the new kitting. Will be running as soon as we get those in as the kits are basically final at this point
Offline blunt
« Reply #206 on: Fri, 16 December 2022, 08:40:48 »
Got quotes for the most recent kitting. Will be talking with vendors about MOQ/pricing and will update with a GB date once everything is set
« Last Edit: Fri, 16 December 2022, 08:44:07 by blunt »
Offline ideus
  • Björkö.
« Reply #207 on: Fri, 16 December 2022, 12:58:50 »
If the extensions kit is meant to cover the UK-keyboard-layout, it is missing the row four pipe backslash key.
Offline Fraaaan
« Reply #208 on: Fri, 16 December 2022, 13:23:53 »
GMK WoB from Drop already comes with a r4 pipe so full UK ISO is covered. I guess including it for other WoB sets out there could be a consideration but majority of people will be buying this to upgrade their standard WoB.
Offline ankit
« Reply #209 on: Fri, 16 December 2022, 18:14:42 »
R4 pipe was included originally but as Fran mentioned, it is redundant as this set is meant to be an add-on to drop's GMK white on black which already has it.
Offline ideus
  • Björkö.
« Reply #210 on: Fri, 16 December 2022, 18:36:53 »
The R4 pipe is rare out of complete sets like Drop's. It is a shame that it cannot be included.
Offline blunt
« Reply #211 on: Sat, 17 December 2022, 03:42:01 »
Drop GMK WoB, GMK Originative, GMK Originative Cyrillic, GMK Originative Japanese, and GMK Cyrllic WoB all have UK-ISO in their base or R4 pipe keys. I'm not sure what base kit you are talking about when you are requesting for this single key. Other sets like GMK Griseann (R1) are so incredibly rare that it would be completely useless to add to this kit. Drop GMK WoB has 12.9k sales listed on drop dwarfing literally every other WoB set and is what this set is designed to complement.
Can you please point to specific popular WoB sets that would require us to add R4 pipe?
« Last Edit: Sat, 17 December 2022, 03:49:01 by blunt »
Offline ideus
  • Björkö.
« Reply #212 on: Sat, 17 December 2022, 10:05:52 »
Thank you for pointing out that this set is to complement Drop's sets. I thought that this may serve to complement US ANSI OG sets to be compatible with the UK layout, also. My mistake.
Offline kspark324
Re: [IC] GMK White on Black Essentials - finalizing pricing/MOQ
« Reply #213 on: Sat, 17 December 2022, 21:10:41 »
I might be in the minority based on a few comments but super bummed we lost the arrow caps lock. Definitely a skip now
Offline GMK83
« Reply #214 on: Fri, 30 December 2022, 08:13:53 »
Any idea on GB dates yet?
Offline blunt
« Reply #215 on: Tue, 03 January 2023, 14:22:50 »
We're still waiting on Cherry for rights to use their logo. Cherry should've reopened offices after the Christmas break so hopefully we hear back from them soon. Once we get that, it's just a matter of picking the MOQ and date as we have everything else ready to go.
Offline GMK83
« Reply #216 on: Tue, 03 January 2023, 19:29:12 »
Thanks for the updates!
Offline mamahuhu
« Reply #217 on: Sat, 07 January 2023, 13:58:54 »
LGTM. Good luck ankit!
Offline francis
« Reply #218 on: Sat, 14 January 2023, 13:24:55 »
It's seems I'm a bit late to the party since you are pretty set on the current kits but I do have to ask why not just make the CMYW kit identical to the CMYK kit from the Beige Addon Extension run? Is 1.25u Fn not as common as I think it is? Also why include 2 1u Fn keys?
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #219 on: Sat, 14 January 2023, 15:38:48 »
If I had WOB or was planning to get it, I would buy ALL kits.
But I am team beige (and purple).  :'(
I wish you lots of luck with this GB. Kitting looks really good.  :-*
Btw any chance for CMYW render or pic with WOB?
« Last Edit: Sat, 14 January 2023, 15:40:25 by twitchytheinsideman »
Offline haeland
« Reply #220 on: Sat, 21 January 2023, 10:09:31 »
also in. just waiting for the gb link to grab one of all the kits  ;D
Offline ankit
« Reply #221 on: Sun, 22 January 2023, 18:48:52 »
- The 2 1u Fn keys allow you to get the most usage out of the kit for split right shift users, allowing people to use both R4 and R5 accents with split right shift -- one with icon shifts and one with text + icon
- 1.25 Fn is not needed. Adding another color would increase the price of the set considerably and having that many colors on the bottom row looks cluttered/ugly. Using the black Fn looks better to us.
I assure you that the kitting decisions made were well considered.
Offline ankit
« Reply #222 on: Sun, 22 January 2023, 18:50:32 »
CMYW accent kits already exist and photos are readily available.
Photos do a better job of showcasing this set than renders can  :thumb:
Offline treeleaf64
    • treeleaf64
« Reply #223 on: Fri, 27 January 2023, 18:37:01 »
Looks great. Wob is super cheap now on mm.
Yayayayaya Yayaya!!!!!
I Am excited
Everyone must pay the cat tax
    • Twitchy Homepage
« Reply #224 on: Fri, 27 January 2023, 18:51:36 »
I Am excited
If WOB price in EU also drop, I will buy  :-[
Offline ankit
« Reply #225 on: Thu, 02 February 2023, 19:25:10 »
we got licensing from cherry
gb late feb - early march
Offline C0M9L3X
« Reply #226 on: Thu, 02 February 2023, 22:19:30 »
Hurry please
Offline haeland
« Reply #227 on: Thu, 02 February 2023, 22:31:31 »
this is amazing. thanks for all the hard work on this!
Hurry please
ಠ⁠_⁠ಠ
Offline iamtragic
« Reply #228 on: Fri, 03 February 2023, 01:23:31 »
Love ya work Ankit, excited to be in for all kits.
Offline stomaha
Re: [IC] GMK White on Black Essentials - GB soonish
« Reply #229 on: Sat, 04 February 2023, 05:51:47 »
Glorious.
Offline blunt
Re: [IC] GMK White on Black Essentials - GB starts February 27th
« Reply #230 on: Wed, 08 February 2023, 18:38:44 »
GB dates: February 27th to March 24th.
All kits will have an MOQ of 150 except for CMYW which will have an MOQ of 250
Offline stomaha
« Reply #231 on: Thu, 09 February 2023, 06:32:16 »
jazzed.
Offline AmethystDCVR
« Reply #232 on: Mon, 13 February 2023, 20:07:37 »
same. but at least theres still dracula ligature kit whenever that releases
Offline ankit
« Reply #233 on: Mon, 13 February 2023, 22:08:55 »
dracula mods are not cr/ws1
also dixie mods lmao
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #234 on: Tue, 14 February 2023, 16:34:13 »
nice
Offline involuntarysoul
« Reply #235 on: Tue, 21 February 2023, 18:27:53 »
i feel the R5 kits should be separate, i am basically paying double price for a R4 kit...
« Last Edit: Thu, 23 February 2023, 13:06:34 by involuntarysoul »
Offline HarryBackman
« Reply #236 on: Fri, 24 February 2023, 20:43:57 »
I'm in!
Offline blunt
« Reply #237 on: Sat, 25 February 2023, 08:16:10 »
When many sets are failing to hit MOQ, the last thing you’d want to do is have more kits. Even if that weren’t the case, I wouldn’t have split the kits anyway because the kitting can fit any 2 boards easily and can fit upto 4 depending on the layouts. There’s a reason addon kits like these have never been split in the past.
« Last Edit: Sat, 25 February 2023, 08:21:20 by blunt »
Offline stomaha
« Reply #238 on: Sat, 25 February 2023, 15:31:47 »
Are prices being released in advance of the GB going live? No a huge deal if not, just curious where they’re going to come in.
Offline ankit
« Reply #239 on: Sat, 25 February 2023, 19:08:45 »
Waiting on vendors to come back with pricing still, some vendors wanted to wait until this weekend to base their pricing on the most up to date conversion rates.
Pricing likely won't be announced before Monday but Blunt or I will update here & discord if we here back before then. I'm sorry I don't have a better answer for you.
Offline vheissu
  • Pragmatic Geometrist
« Reply #240 on: Sat, 25 February 2023, 22:09:56 »
hurry up ankiti
Offline kingpingwing
« Reply #241 on: Mon, 27 February 2023, 07:38:53 »
For years they've searched, their quest unfulfilled,
For keycaps with UK keys that fit the bill,
They scoured the web, they asked around,
But nowhere were these keycaps to be found.
But lo and behold, what's this they see?
A group purchase, just for me!
The keycaps they've longed for, oh so rare,
Are finally within their grasp to bear.
With trembling hands, they hit "add to cart",
A rush of joy that fills their heart,
They've waited so long, it's hard to believe,
That finally, these keycaps they'll receive.
And when they arrive, the moment's divine,
They'll place them on their keyboard, oh so fine,
The wait was worth it, they can finally say,
For these keycaps will brighten up their day.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #242 on: Mon, 27 February 2023, 11:36:14 »
Epic post! I would invite you if could....... but alas, we are on a forum!!! XD cross post to Reddit bro!
« Reply #243 on: Mon, 27 February 2023, 12:24:51 »
you would invite me to take my poetry to Reddit?
Offline actress
« Reply #244 on: Mon, 27 February 2023, 12:49:19 »
we taking credit for ai generated content already huh.
Offline II_Versey
« Reply #245 on: Mon, 27 February 2023, 13:00:29 »
I thought gb was today bruh
Offline ankit
« Reply #246 on: Mon, 27 February 2023, 13:12:31 »
gb post was submitted for approval last night. prototypist is live now -- apex and mechs & co should be live later today.
Will update here when everyone else is live. I'm sorry for the rocky start unfortunately this was out of our hands.
« Reply #247 on: Mon, 27 February 2023, 13:49:46 »
in the process of implying that it wasn't mine but perhaps not making the sarcasm clear enough... yes
    • Twitchy Homepage
« Reply #248 on: Mon, 27 February 2023, 16:03:15 »
GLWGB :thumb:
« Reply #249 on: Tue, 28 February 2023, 06:48:27 »
ur right i confused with another mod addon.
this one: https://imgur.com/40VBMU1 from wob red cyrillic. although tbh i dont know how easy these will be to get. i just need 1 set lol. i already cannibalized 3 from katakana after playing drops coupon circus game and selling the alphas. i really dont want to go through all that hassle again
