Author Topic: [IC] GMK White on Black Essentials - GB starts February 27th  (Read 242329 times)
Offline Fraaaan
Re: [IC] GMK White on Black Essentials - waiting for quotes
« Reply #150 on: Thu, 10 November 2022, 14:11:28 »
Any idea when this will run?  Still waiting on quotes?
Still waiting on quotes.
Planned for Q1 2023 now  :(
gmk lead times gonna be same still right like 2 years?
This set will get placed into the queue just like any other GMK GB set. It's safe to assume that it'll take longer than a year but I believe 2 years is a stretch at this point.
Offline IOVERCALLHISTIOCYTES
« Reply #151 on: Thu, 10 November 2022, 16:29:35 »
There’s also no color matching for this set. Any custom colors have been used before.
Offline udller
« Reply #152 on: Thu, 10 November 2022, 18:16:59 »
that extension kit set is nice :)
Offline blunt
« Reply #153 on: Fri, 11 November 2022, 15:25:24 »
How about the macOS 1.5u command and 1u option?  :D
Maybe a handful of people have asked for this so it won't be running especially considering how we want to keep the kitting price low so all kits hit MOQ
Offline blunt
« Reply #154 on: Fri, 11 November 2022, 15:27:54 »
Actually all colors but one have been matched, the red from Villanelle is in the process of matching right now and should be done soon and should surely be done by the time this set goes into production :catyes:, just waiting on quotes now as Ankit mentioned. Considering that beige stuff (Hineybeige and Beige Addon & Extension) is running right now, this will be run in Q1 2023.
« Reply #155 on: Fri, 11 November 2022, 15:35:34 »
Blunt thanks for clarification. Thought the dark red had been matched (admittedly that other set is similar, Da?)
Offline blunt
« Reply #156 on: Fri, 11 November 2022, 15:45:53 »
We wanted to match RAL 3005 ourself originally but then found out Villanelle is also uses RAL 010 20 25 which corresponds to RAL 3005 in the Classic RAL chart. I can't remember what set's red we wanted to use before choosing the Red from Villanelle or if we even had another set's red we wanted to use.
Offline Razer1987
« Reply #157 on: Fri, 11 November 2022, 16:13:54 »
Hi, would you reconsider addition of F13 after the change of extension kitting of GMK Griseann? Thanks !
Offline blunt
« Reply #158 on: Fri, 11 November 2022, 16:29:46 »
We haven't received quotes yet for our original kitting so I'm not sure how long a requote is going to take, you can also use the Cherry 1u's as F13 which looks nicer imo but we will look into it for sure.
Offline II_Versey
« Reply #159 on: Fri, 11 November 2022, 21:23:27 »
What are the chances of you guys adding maybe wob hangul or zhuyin in this since isn't gb suppose to be all wob essentials?
Offline blunt
« Reply #160 on: Fri, 11 November 2022, 23:38:49 »
0, WoB Hangul R2 already ran a while back and I already have WoB Zhuyin
Offline II_Versey
« Reply #161 on: Sat, 12 November 2022, 22:05:26 »
It ran for sure but hangul and zhuyin is over priced in the aftermarket maybe you guys should make a poll for it since it's a really got set and im sure people would be interested
Offline ankit
  • Formerly ankit-sachdeva
« Reply #162 on: Sun, 13 November 2022, 00:02:33 »
Hangul ran 8 months ago, it would be insane to run it again.
Zhuyin is easily available for less than extras pricing aftermarket.
Regardless, it's not happening in this set. I hope that helps. :thumb:
Offline II_Versey
« Reply #163 on: Sun, 13 November 2022, 14:01:34 »
alr i guess and hangul sold for 450 in the aftermarket lol
Offline iamtragic
« Reply #164 on: Sun, 13 November 2022, 15:11:16 »
Fortunately, GMK WoB Hangul R2 is available for pre-order on MKB.
Offline II_Versey
« Reply #165 on: Sun, 13 November 2022, 22:47:40 »
WAIT HOLY **** I JUST FOUND OUT thanks so much my guy gonna be grabbing it and before I do is there any usa based website that still had pre-orders?
Offline dcsenjoyer
« Reply #166 on: Mon, 14 November 2022, 04:01:27 »
Please consider including r1 "=", "f13" and shinethroughs, because these have been dropped from gmk griseann extension kit.
Offline blunt
« Reply #167 on: Mon, 14 November 2022, 05:22:47 »
Shinethrough is present in WoB Shinethrough which has already shipped to buyers. As far as the other keys are concerned, we’ll take a call once we get in quotes for the original kitting.
Offline stomaha
« Reply #168 on: Mon, 14 November 2022, 06:46:17 »
Agreed, r1 = is critical to many builds with numpads (Sar!). Please please consider adding now that it has been dropped by GMK Griseann
Offline Yppta
« Reply #169 on: Mon, 14 November 2022, 07:27:17 »
I second the point about r1 "=" its a must now since its been dropped from griseann.
Offline stomaha
« Reply #170 on: Mon, 14 November 2022, 12:46:25 »
I would add one other point to the R1 = request: the = key has been run in many GMK kits previously, but never in a CR/WS1 WoB kit. So, unlike some of the other kit additions proposed above, there isn't a substitute circulating in the secondary market.
Offline ankit
« Reply #171 on: Sat, 03 December 2022, 15:27:47 »
Hi everyone!
We have made some kitting changes due to changes with GMK Griseann 2 as well as current GB sales.
- Removed R0 from R0/R5 kit, R5 only now.
- Removed dark yellow keys from Dark RGB kit
- Removed R0 cherry logo keys from extensions kit
- Added 2 heart key, R1 F13 as well as R1 = to extensions kit
- Removed stepped purse capslock and full touch purse capslock, as well as stepped arrow capslock from icon mods
All changes have been reflected in the original post.
Kitting is not likely to change at this point but if you have any other suggestions please fill out the IC form or leave a comment.
We still hope to run this in Q1 and expect new quotes soon.
Offline ankit
« Reply #172 on: Sat, 03 December 2022, 15:33:07 »
fixed extensions render, sorry about that  :blank:
Offline jeroplane
« Reply #173 on: Sat, 03 December 2022, 16:26:29 »
Great job Ankit
My signature hasn't changed since 2012. I should really update it.
Offline B_D
    • bdskeyboards
« Reply #174 on: Sat, 03 December 2022, 16:27:04 »
insta cop
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Offline stomaha
« Reply #175 on: Sat, 03 December 2022, 17:39:52 »
Ankit 2024
Offline Sicowa
« Reply #176 on: Sat, 03 December 2022, 19:36:40 »
Happy bday qt
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline elvenmonster
« Reply #177 on: Sat, 03 December 2022, 20:32:27 »
Definitely in for the dark rgb
Offline GMK83
« Reply #178 on: Sun, 04 December 2022, 05:30:24 »
In for dark rgb also
Offline Razer1987
« Reply #179 on: Sun, 04 December 2022, 06:09:39 »
A bit sad to see R0 left the kitting, was really looking for this as the old set R0/R5 extension is almost impossible to buy on the mechmarket. Rational is purely price? or the fact that R0 is not really an OG thing but something really exotic available on a few old boards?
I will still probably commit for some sets.
Offline Yppta
« Reply #180 on: Sun, 04 December 2022, 11:40:58 »
Love the changes to the extensions kit. Would like to add that a r3 up arrow would put this set over the top for me personally, although I understand it will probably never happen.
Very exited none the less :) grate work ankit!
Offline blunt
« Reply #181 on: Sun, 04 December 2022, 12:49:22 »
R0, like R5 is pretty expensive. The vast majority of buyers who buy the R0/R5 kit are only going to end up using R5. The change was made purely because of the price and the current situation of the hobby.
Offline LXVRGS
« Reply #182 on: Sun, 04 December 2022, 17:53:30 »
extremely bummed to see r0 not make it
Offline Tomson
« Reply #183 on: Mon, 05 December 2022, 04:25:15 »
Why dark yellow got removed?
Offline ankit
« Reply #184 on: Mon, 05 December 2022, 12:11:55 »
This is a kitting reduction that cuts the number of keys in the R0/R5 basically in half. The majority of people haven't tried R0 but I honestly believe it's too tall and looks out of place on most layouts other than 75%s. With the way current GMK GBs are going, we don't think it makes sense to include anymore. Realistically if we try to make everyone happy with every kitting decision we will end up with kits that are too bloated/expensive to run in a time when not every GMK set is making MOQ anymore.
Dark yellow felt forced in that kit and out of place. Black keys for supers look nicer to us for winkey boards. We are working to further reduce the Dark RGBW and CMYW kitting to reduce redudent/unutilized keys.
Offline Razer1987
« Reply #185 on: Mon, 05 December 2022, 14:15:48 »
As a ISO user, I am really worried about Alt Gr! It would be nice to see at least the most common kept like the 1.5u R5 one or 1.25u R4. Same for shift, at least icon 1.25u would be great.
ty
Offline ankit
« Reply #186 on: Mon, 05 December 2022, 14:28:55 »
angry alt and 1.25u shifts will not be cut -- hope to share more soon :thumb:
Offline II_Versey
« Reply #187 on: Mon, 05 December 2022, 17:29:44 »
Hi everyone!
Why you remove purse caps :( they were the best part ankit
Offline II_Versey
« Reply #188 on: Mon, 05 December 2022, 17:30:55 »
Hi everyone!
Please add them back they were so good ;(
Offline Plurrkeebs
« Reply #189 on: Mon, 05 December 2022, 19:13:06 »
I like it very much  :thumb: :thumb: :thumb: :thumb: :thumb:
Offline ankit
« Reply #190 on: Mon, 05 December 2022, 23:14:13 »
We still have the windowed stepped purse capslock! :p
Offline II_Versey
« Reply #191 on: Tue, 06 December 2022, 11:52:08 »
Alr I guess but still why you guys remove purse caps its really rare to find one and can only be get in gmk metaverse
Offline SE7EN_ate_NINE
« Reply #192 on: Tue, 06 December 2022, 14:23:54 »
Bring back the purse!
Offline ankit
Offline ankit
« Reply #194 on: Thu, 08 December 2022, 14:36:15 »
More kitting changes:
- Removed 1.25 super from CMYW
- Removed 1u alt from Dark RGB
- Changed all capslocks to purse
pretty confident in this kitting now  :thumb:
Offline azhdar
  • Praise the AZERTY god
« Reply #195 on: Thu, 08 December 2022, 19:20:52 »
Perfect kit.
Don't change a thing.
Azerty Propagandiste
Offline II_Versey
Offline ubmit
« Reply #197 on: Fri, 09 December 2022, 14:19:16 »
this is a banger
Lyn Whale | KFE CE | Frog | Singa | Dolice | Haus | Kei | Polaris | Prophet | Bongoneko
Offline epicdesk.shop
« Reply #198 on: Fri, 09 December 2022, 23:05:47 »
Goes hard!
Offline Akele
« Reply #199 on: Sat, 10 December 2022, 17:58:12 »
Nice, glad to see the return of the purse capslock.
