Author Topic: [IC] Etcetera - 65% Plateless PCB-top-mount with leaf-spring(New Sound Test!)  (Read 26163 times)
Offline ookies
Etcetera65
Background
Hi yall, _ookies here
For quite some time now, I've been looking for a 65% board. However, I can't seem to find one with all the features I want in a board.
So I decided to make my own keyboard, taking inspiration from previous designs and combining it into one neat package.
Inspiration
This board is the combination of several features that I liked from other boards. The Plateless/PCB mount of the 7V(Gok), the leaf spring design from nemui(Bachoo), the accent/pen bar from j-02(Jae), Etc.
Specs:
  • 6.5 degree typing angle
  • Case material: 6063 aluminum
  • Accent Bar material: PVD copper
  • Plate: an fr4 plate will be included for people who prefer a stiffer typing experience
  • Mounting: pcb-leaf-spring-top mount
  • 20.28mm front height
  • Feet: SKUF feet
Colour option:
  • Beige
  • Grey
  • EWhite
PCB and Layout:
  • 1.6mm PCB
  • QMK and VIA compatible
  • Comes with c3 daughterboard and jst cable
  • Only solder version planned for now
  • both solder and hotswap option available
Renders
First Prototype Photos
Extended Album
Second Prototype Photos
Second Prototype Sound Test
Plate: Plateless
Switches: Stock Gateron Yellow
Stabilizers: Durock V2 Screw-in Stabilisers with Krytox XHT-BDZ
Keycaps:  Epbt origami
*stock gateron yellow are used for a replicable test*
First Prototype Sound Test
Plate: Plateless
Keycaps: GMK Modern Dolch 2
IC Form: https://forms.gle/bdeRLUVJ7Jm895US9
Discord: https://discord.gg/RDqT4Gcxjp
Instagram: https://www.instagram.com/_ookiesdesign/
Todo:
- Proto build and Sound test
- More renders
- Design a hotswap pcb
Updates:
- 25/6/2022 added some more renders
- 25/6/2022 discord server added
- 26/6/2022 added fr4 plate and hotswap pcb as options
- 28/6/2022 added sound test for first prototype
- 12/11/2022 second round of proto ordered
- 21/12/2022 second proto of PCB arrived
- 11/03/2023 second batch of proto Cases arrived
« Last Edit: Fri, 14 April 2023, 18:21:29 by ookies »
Offline DirtyGingy
Re: [IC] Etcetera - 65% Plateless PCB-top-mount with leaf-spring
« Reply #1 on: Thu, 23 June 2022, 07:00:57 »
mode called, they want their design language back
jk
Offline ookies
« Reply #2 on: Thu, 23 June 2022, 07:01:20 »
Hi, this is my first IC page, so I'm sorry if there are any mistakes.
I'll update it little by little.
updates:
added discord server
added several renders
from the feedback received, i've decided to add an fr4 plate for people to choose if they want plateless or not and a hotswap pcb as options
<23/8/2022>
finished designing the hotswap PCB, will order a proto of it soon
<12/11/2022>
finished designing everything, protos have been ordered
<21/12/2022>
Both solder and hotswap PCB have been assembled
« Last Edit: Wed, 21 December 2022, 05:43:58 by ookies »
Offline DaaDaa
« Reply #3 on: Thu, 23 June 2022, 07:26:17 »
gorgrous board. will follow this IC.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline DirtyGingy
« Reply #4 on: Thu, 23 June 2022, 10:16:51 »
If you do add a hotswap pcb, I will definitely have more interest, but this is honestly an interesting board. I'll keep an eye on the project for sure
Offline croatoanlp
« Reply #5 on: Thu, 23 June 2022, 10:25:09 »
Would be interested in seeing the board from a left angle, to better see the accent piece
Offline DaaDaa
« Reply #6 on: Thu, 23 June 2022, 10:35:20 »
It’s platelets so hotswap won’t happen
Offline DirtyGingy
« Reply #7 on: Thu, 23 June 2022, 12:06:40 »
While I don't fully believe it myself, the maker alexa is supposed to do plateless hotswap well https://www.makerkeyboards.com/products/alexa
I'll find out when mine gets here. Someday.
Offline Akele
« Reply #8 on: Thu, 23 June 2022, 13:10:11 »
Looks good. Do you plan to support ISO on the board?
Offline DaaDaa
« Reply #9 on: Thu, 23 June 2022, 18:50:42 »
good to know. i tried platless with every millmax socket available and it doesnt even work for a minute, but the alexa page says that the new hotswap sockets have been tried for months.... good news but ill believe it when i see it.
Offline ookies
« Reply #10 on: Thu, 23 June 2022, 18:51:40 »
Yup. the PCB supports both ansi and iso
Offline ookies
« Reply #11 on: Thu, 23 June 2022, 18:53:12 »
Thats a good idea. ill make a few renders from all sides and update the post
thanks for the suggestion
Offline ookies
« Reply #12 on: Thu, 23 June 2022, 18:57:42 »
yea hotswap was not included due to it being plateless. tho i might add hotswap as an option if people dont mind using a plate. even the Alexa has a solder PCB for 'extra plateless stability'
Offline SDKCAMPING
« Reply #13 on: Thu, 23 June 2022, 22:34:30 »
have you tested the pcb? with such a flexible material, plateless,and long arms i imagine it will feel way too soft and mushy with too much movement.
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline ankit
  • Formerly ankit-sachdeva
« Reply #14 on: Fri, 24 June 2022, 00:17:42 »
Can we see a photo of the left side profile? Looks interesting but there are no photos or renders.
Offline ookies
« Reply #15 on: Fri, 24 June 2022, 03:54:15 »
Yup ive just added some renders of the left side profile. its in the 'Renders' section
Offline ookies
« Reply #16 on: Fri, 24 June 2022, 03:57:43 »
Yup, i have build the prototype with gateron yellows and plateless(typing this message with the prototype). i will add a typing test video soon, haven't gotten the time to record a video haha. so far i don't think it is too mushy in normal typing. sure it flexes alot when pressed hard but on normal usage it feels soft instead of mushy.
Offline GraffitiDecos
« Reply #17 on: Fri, 24 June 2022, 20:55:49 »
Very interesting! I will be keeping my eye on this one GL!
Sent from my SM-S901W using Tapatalk
Offline ookies
Sound test of the first prototype is here!!!
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
Gorgeous board. I love the design!
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline Homiezoned
That accent bar is nice
Offline Nongo
super excited for this it looks so cool
Offline superjackie
Nice looking board! any internal or external weight option? how much does this board weigh? Thanks!
Offline lush_bunny
You had me at
I may not have enough funds to join this GB, but I wholeheartedly hope this succeeds. GLWIC!
Offline ookies
Fully built, the proto weights 1.755Kg. Tho I'm currently testing on adding an internal weight to improve acoustics
Offline JustMilica
  • A weeb
Looks really good. Would love it if there was an option for a silver-colored (PVD stainless steel or alu, for instance) accent bar rather than just the copper one.
Offline ookies
currently thinking of adding other material and finish as extras if people want it
tho its not finalised yet
Offline Jho
Love that sound test. Am interested if price is decent.
Offline ookies
Hey guys
Sorry for taking so long but I'm finally finished with designing everything
I've also ordered several prototypes, this includes the board, PCB, packaging etc.
I'm planning on sending a few to reviewers and if all things goes well we could look into planning the GB
Offline arr1
  • Ñ supporter
looks amazing
Offline Ashen_21
Gorgeous board, looking forward to seeing it develop and in the hands of creators as well! GLWIC!
Offline ookies
Thanks alot!!! Really hoping that the protos will come out well. so far the PCB protos are looking really good
Offline Toptiginn
    • toptiginn.com
The white one with brass looks really good :thumb:
Offline ookies
Thanks a lot!
Offline saab
Really like how the accent bar flows with the side profile.
Offline ookies
thanks!! glad you like it.
Offline Burt888
I assume Iso will be only on the Solder PCB or will habe the Hotswap ISO aswell?
Offline ookies
yea, sadly iso is only for the solder PCB
Offline Frothy_Coffe_e
This looks so good!!! Nice 😊
Depending on price I’m definitely interested.
Offline ookies
Ayee thanks. price is not finalized yet but I expect it to be around 300-350
Offline OhNyne
This is my type of board, Iso, hotswap. Just not sure how plateless would work on a hotswap pcb, but it would definetley shake up the market.
