Author Topic: [IC] The NUM1 - Gummy O-ring BT NumPad - GB from NOV 19-22!  (Read 15925 times)
Offline Friendship
« on: Mon, 27 June 2022, 21:42:09 »
[ The NUM1 ]
A gummy o-ring mounted number pad with a Daughterboard, Bluetooth, alternative top mount, and Alps compatibility.
GB THREAD HERE: https://geekhack.org/index.php?topic=118848.0
V2 and V2.5 prototype photos:
[ The Group Buy information ]
Vendor: The fantastic https://thockeys.com !!!
Price: $250 for the kit (batteries not included)
Sale format: Raffle
Unit count: 21 units
Timeline: GROUPBUY RAFFLE OPEN NOVEMBER 19-22
Extras:
$12 - MX PP Plate - Cut by the wonderful Jake at the https://p3dstore.com
$18 - MX Alu plate - "jack" anodization color
$18 - Alps Alu Plate - "jack" anodization color
$30 - PCB
$6 - O-ring 50A
$55 - Case top (one of the 3 colors to choose from)
[ The Kit ]
- NUM1 case top (color info below)
- NUM1 case bottom Silver Anodization
- Sandblasted brass weight
- Mx 5052 Aluminum Plate ("Jack" anodization color)
- 1.6mm PCB (designed by TrifeLife)
- Daughter board (Unified C3 design)
- 1x JST cable
- 1x 50a O-ring
- Hardware
- 3M bumpons
[ The Colors ]
"Ron"
more views and Manu color chip:
"Gump"
"Jack"
[ The Specs ]
Angle: 6.5 degrees
MX plate material: semi-transparent polypropylene OR anodized almost black 5052 aluminum
Alps Plate material: Anodized almost black 5052 aluminum
Firmware: ZMK
Battery life: ZMK estimates 2-4 weeks
Built weight: ~1.3 Lbs
[ The Sound tests ]
Proto 2 sound tests:
Cherry on Alu
https://clips.twitch.tv/AffluentSaltyKangarooPRChase-hpdV_1uDCvYN2_Fa
Cherry on PP
https://clips.twitch.tv/HilariousAbnegateWerewolfDxAbomb-Rr_5XkRev7v9-Uz-
Old sound tests:
[ The Layout ]
Applicable for both MX and Alps switches. Sorry no southpaw. Blue highlighted inner zones are the O-ring pedestals, outer zones are the top mount points
[ The Updates ]
7/24/22
- Prototype V2 and PCB V2 set to ship Monday 7/25
- V2.5 prototype ordered from another Manu to test their capabilities as a potential production runner (eta 1 month for that). The V2.5 has a larger battery bay, up to 150mAh from 70mAh (battery life pending testing)
- Sale set to a Raffle format
- $275 price has been removed, current target is $225 but is not final.
11/4/22
- We have a Vendor!!! huge shoutout to Aiwanei at Thockeys for taking this little passion project on and making it a reality!
- Updated kit (removed battery, removed black hardware torx variant (silver still available)
- Finalized color options (see above)
- Finalized weight material and finish (sandblasted brass)
- 250$ finalized kit price (why the increase? long story short, the V1 and V2 proto manu become untrustworthy, the V2.5 proto manu had more errors than i could count, so i had to choose a Manu that was experienced/well recommended and sadly a little pricier)
[ The Discord ]
https://discord.gg/NW8txQcnA8
[ The Special thanks ]
TrifeLife
Maly
Yataomi
Choobies
The MLI homies
This lil guy: https://i.imgur.com/5znfuGO.jpg
Thank you all for being my friends :)
Sincerely yours, your friend,
- Friendship
Old IC stuff:
[ The Inspiration ]
This was born from being disappointed in the lack of premium numpad options available at the time of initial design as well as age old instigating questions like "what if we slapped an o-ring into it?" and "what if we slapped bluetooth into it".
More ramblings of context:
I was also influenced by one of my favorite kustoms the GHv2 by LZ.
The engraving and name was born from some cheeky wordplay of songs by one of my favorite artists Machinedrum. I binged his music throughout this design process and felt inclined to immortalize it within the design. His use of numbers in his song names also integrated well into the theme of the numpad.
NUM1: a play on 'Come1' off the album “Room(s)”
Only 1 Way 2 Numpad: a play on 'Only 1 Way 2 Know' off the album “Vapor City Archives”
I was made aware only somewhat recently that a fellow member of this community HineyBush designed the TKL ONE and the NUM ONE (I knew the TKL ONE but didnt know it had a numpad!). Given the name is nearly identical, I reached out to Hiney for permission to continue use of the NUM1 name for this project, He approved! :D Thanks Mr. Hiney!
[ The V1 to V2.5 Changes ]
A more comprehensive history of the design and changes can be found in my discord below but here are the main points
- Increased total height of the pad 1.4mm to increase case bottom thickness for acoustic improvements to front row switches
- Xonledge added for same reason as above
- USB C cutout squared to accept lindy connectors
- Oring sidewall relief cut depth increased to isolate impact force to just the oring pedistals
- Removed long bumpons in favor of 3m dome bumpons for better acoustic isolation
- Added battery bay and Bluetooth functionality supporting 150Mah LiPo batteries
- Increased the fillet from 1.25 to 1.5 on edges for softer feel when moving around your desk
Full album Link: https://imgur.com/a/MFKxSja
V1 prototype photos:
[ The Packaging ]
not enough interest for bionicle tube  :'(
« Last Edit: Mon, 14 November 2022, 10:14:56 by Friendship »
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] NUM1 - Gummy O-ring BT Number Pad
« Reply #1 on: Mon, 27 June 2022, 21:45:50 »
[ The Packaging ]
For low unit self run, I will likely stick with a foam lined corrugated box. However, if a vendor picks this up and the unit count can be upped, there is a possibility we could explore this wild Bionicle inspired design
Holy **** this packaging is lit af. Cool project GLWIC.
Offline chat and team
« Reply #2 on: Mon, 27 June 2022, 21:47:12 »
This is pretty cool but for 275 it isn't.
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #3 on: Tue, 28 June 2022, 05:23:49 »
275 haha that's hilarious
Offline KneeDeep
« Reply #4 on: Tue, 28 June 2022, 07:19:06 »
Super neat and alps support, I'm there!
Offline GMK83
« Reply #5 on: Tue, 28 June 2022, 08:44:40 »
100% in.  Looks fantastic.
Offline vonk
« Reply #6 on: Tue, 28 June 2022, 08:53:42 »
Cute
Offline asianfork
  • Alice
« Reply #7 on: Tue, 28 June 2022, 08:54:35 »
Looks clean! Very nice
Offline BRSxIgnition
« Reply #8 on: Tue, 28 June 2022, 09:39:34 »
Had me with everything else but lost me at $275 USD for a numpad.
Offline panka
« Reply #9 on: Tue, 28 June 2022, 09:44:35 »
cool macropad, but the price is god awful
Offline Friendship
« Reply #10 on: Tue, 28 June 2022, 10:45:29 »
Cute
Thanks y'all!!! Your kind words and support means a lot to me!!!
I understand the sentiment, I am a first time runner and the projected price was with a small MOQ in mind. It is not firm and could come down closer to GB (especially if interest grows), but for obvious reasons I cannot guarantee that. I appreciate y'alls thoughts on this!
Offline catamscott
« Reply #11 on: Wed, 29 June 2022, 11:43:10 »
that packaging is so sick wtf. I'm not a big numpad guy but this looks great  :thumb:
Offline Slayer77
« Reply #12 on: Thu, 30 June 2022, 15:46:26 »
I hope you can up the unit count and lower the price, would be interested then.
Sent from my GM1911 using Tapatalk
Offline shendoo
  • *RAUGHS*
« Reply #13 on: Thu, 30 June 2022, 17:34:22 »
Really interesting but it's a big pass for me with that price tag. GL
Offline SDKCAMPING
« Reply #14 on: Thu, 30 June 2022, 23:29:51 »
Too expensive for me but good luck, o-ring is good
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Lendios
  • im addicted
« Reply #15 on: Sun, 03 July 2022, 14:46:59 »
Really cool but as others have said the price is way too high, is there another manufacturer who can do it for cheaper? I'm interested to know why they're charging so much.
Would much rather have worse packaging, less SKU's and no engravings if it lowers the price.
Offline Hentoys
« Reply #16 on: Tue, 05 July 2022, 12:07:41 »
I am going to jump on the price. Great idea but the price is killer. It's almost as much as a quality TKL.
Offline Friendship
Re: [IC] The NUM1 - Gummy O-ring BT Number Pad - 7/24/22 update
« Reply #17 on: Sun, 24 July 2022, 19:23:30 »
Hey everyone!
First off, thanks everyone for taking the time to fill out the IC, great data coming from that. If you haven't already, please let me know your thoughts!
Second, I have made an updates section in the main post and you will notice some changes above it  based on that. A more firm price will be provided closer to the group buy date but I am happy to be able to confidently drop the price down from the initial $275. Pictures and evaluation of the V2 and V2.5 builds will show up on my discord first, so feel free to hop on in and say hello!
Offline infinitum
  • i buy expensive plastic
« Reply #18 on: Mon, 25 July 2022, 13:06:53 »
love the idea, but the price looks pretty steep. usually macro pads are around the 100 range, and most people probably wouldn't be willing to spend more
Offline PuNkShoO
  • I make keyboard switches.
    • Check out my projects!
« Reply #19 on: Mon, 25 July 2022, 13:09:50 »
uh yes please
Offline cbbplanet
« Reply #20 on: Mon, 25 July 2022, 13:23:13 »
looking forward for this to be going into GB!
« Reply #21 on: Mon, 25 July 2022, 13:36:48 »
With a lower price and the newly added BT support and battery I'm interested.  :cool:
You may be able to further reduce costs by going the GB route and producing more, considering you're currently only doing 21 units? Upping that to 50 or 100 may bring the price down enough to generate that additional interest.
GLWIC.
« Last Edit: Mon, 25 July 2022, 13:41:51 by BRSxIgnition »
Offline Friendship
« Reply #22 on: Tue, 26 July 2022, 10:45:14 »
uh yes please
Thanks for the support y'all!!!
GLWIC.
This is a GB and not in stock
While it would be lovely to be able to get this design into more folks hands, I am hesitant to increase the quantities without vendor support.
« Last Edit: Tue, 26 July 2022, 12:26:51 by Friendship »
Offline mongoose27
  • WKL FTW
« Reply #23 on: Tue, 26 July 2022, 11:47:54 »
Very nice numpad but  very steep price.  I'd be in otherwise.
Offline dededecline
    • Linktree
« Reply #24 on: Tue, 30 August 2022, 19:19:53 »
This looks great fam, glwgb!
Offline Friendship
« Reply #25 on: Thu, 01 September 2022, 08:37:13 »
<3<3<3<3<3<3
also a little update, V2.5 prototype should be in hand in 2 weeks time! Also both Alu and PP o-ring V2 proto sound tests are here!
Cherry on Alu
Cherry on PP
« Reply #26 on: Thu, 01 September 2022, 12:41:06 »
Probably my favorite numpad IC going right now, despite the price. Excited to see this go live, especially after hearing those new sound tests.
Offline Friendship
« Reply #27 on: Fri, 04 November 2022, 20:48:04 »
thank you so much for the kind words! I am very excited to bring this to life!
also revamped the IC in prep for GB in 2 weeks!!! Raffle format so no need to be speedy!
Offline Razer1987
Re: [IC] The NUM1 - Gummy O-ring BT NumPad - GB from NOV 19-22!
« Reply #28 on: Sat, 05 November 2022, 07:22:59 »
21 units 😱 finger crossed for the raffle!
Offline Friendship
« Reply #29 on: Mon, 07 November 2022, 18:53:14 »
<3 thank you for your interest! May the RNG be with you :)
Offline Friendship
« Reply #30 on: Mon, 14 November 2022, 10:17:30 »
Hey everyone! GB thread is up here https://geekhack.org/index.php?topic=118848.0
locking the IC thread in prep for GB :)
