Author Topic: [IC] Derivative R1 | 60% | Group buy opens March 25th - April 10th!  (Read 66684 times)
Offline Ustinj
Derivative R1
This is the interest check for Derivative, a 60% keyboard. There was an very small run of in-stock initial units (Round 0) during Fall 2021, but there have been some design changes I've contemplated since then. I also wanted to share this IC in case some were looking to pick up the board - this is basically to say that there WILL be another run, and I hope to make it far more available than it currently is.
Details
  • Layout: 60%, WK / WKL / HHKB
  • Mounting: Top / Relief / O-ring Gasket
  • Materials: Aluminum 6063, Stainless Steel Weight & Logo Insert
  • Weight:
  • Typing: 6.5 degrees
  • Front Height: varies, 22.4mm EKH
  • Pricing: Starting at $439 USD (US Pricing)
GB / Sale Info
GB opening March 25th - April 10th
US Pricing: $439 USD (WK/WKL) - $449 USD (HHKB)
(Pricing and sales formats may vary regionally)
  • US: jjwkb, 250u - 9 AM PT
  • CA: Deskhero, 70u
  • EU: KEYGEM, 70u
  • EU/UK: Prototypist 50u
  • OCE: Switchkeys, 70u
  • AS: HEX Keyboards, 150u
  • KR: Swagkeys, 40u
Shipping estimate is the standard GB fare, aiming for approximately Q4 2023 - Q1 2024 for shipping.
Kit includes: Keyboard, full aluminum plate, PCB + Daughterboard, carrying case & microfiber cloth, 50A O-ring, assembly hardware, misc. documentation.
There will be add-on options:
  • Aluminum Full Plate
  • Aluminum Half Plate
  • Polycarbonate Full Plate
  • Polycarbonate Half Plate
  • Polypropylene Full Plate
  • Extra PCB + DB
  • O-rings (30A, 50A, 70A)
Design Info
Whenever I sit down and begin a new design, I always look to incorporate at least one distinct feature that gives the keyboard a sense of identity. One of the biggest challenges in keyboard design for me is creating something that is unique / different, while keeping design cues intentional and avoiding too overbearing complexity. Derivative features a sleek and layered side profile with contrasting curves mirroring one another. These are some key details that were considered in Derivative's design.
On the top face is a long, sweeping front lip that bows gently outwards towards the center. It gives Derivative a defining feature visible from a working angle, while reducing the front height of the board ever so slightly.
With Derivative, I've added an accompanying bevel (similar to Geon's awesome Frog) on the side profile that lines up directly with the front-lip to avoid that. The board's side profile is a shelf design, curved downward into the table. Beneath the shelf, there's a secondary curve in the base that turns away from the table - the two opposing curves work nicely together. The secondary curve is not a result of a stepped side profile, but a direct transition into the large filleted corners.
The R1 weight is now longer and more proportional. A recurring request was for the two-piece weight to return, so it will be returning with improvements.
I'm not an engineer by day - so custom keyboard case design may be the one of the only things I dabble with where fractions of a millimeter make such a core difference between having a functional case and a complete headache.
The side profile of Derivative features a shelf design that cuts directly into the bottom of the case. In order to have a shelf design, there's a minimum thickness required for the shelf otherwise the side profile cuts  a hole straight into the bottom case (that is, if I want to keep the super thin side bezels). This became a careful, frustrating battle between three things - keyboard height, internal clearance beneath the PCB, and minimum shelf thickness to retain the 'shelf' side profile. If you've designed a keyboard, you know exactly what I'm talking about :D
In the end, I opted to give the modifier switches minimal internal clearance - this buys the case more material for the shelf to cut into. Towards the center, the case internals opens up and give additional room for the alphas to flex where it actually matters.
Mounting
Derivative's compact plate design allows for three practical mounting styles to choose from - classic top mount, a far more flexible relief mount (only viable on materials such as aluminum, carbon fiber, etc), and large o-ring gasket mount.
I anticipate the following plate materials will be offered:
  • Aluminum Half / Full
  • Carbon Fiber Half / Full
  • FR4?
  • Polycarbonate Half / Full
  • Polypropylene?
Colors
So far the colors I've settled on are:
  • Mercury (Silver)
  • Clay (Clay)
  • Amphibian ('Green')
  • Coast (Blue)
  • Velvet (Red)
Here is a section of renders for what I aim to reproduce. Note that these are in prototyping and the final results will probably vary a bit.
Layouts
Layout will be available in full (WK), WKL, and MX HHKB. Expand for renders.
Media
Typing (full alu plate, 35a o-ring):
Typing (half alu plate, 35a o-ring):
Build stream from Lulzthax:
Links
« Last Edit: Mon, 27 March 2023, 23:10:09 by Ustinj »
Online ankit
  • Formerly ankit-sachdeva
Re: [IC] Derivative R1 | 60% o-ring, top, relief mount
« Reply #1 on: Wed, 29 June 2022, 15:18:24 »
Really happy to see HHKB for the groupbuy. Derivative so lit.
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #2 on: Wed, 29 June 2022, 15:20:41 »
very nice, filled the IC form  :D
Offline Neely_12
« Reply #3 on: Wed, 29 June 2022, 15:21:35 »
You love to see it. Although I do think a copper weight would look a little nicer with some of these colors. Great job as always  :thumb:
Offline The0rigina1
  • fumoposting
« Reply #4 on: Wed, 29 June 2022, 15:23:33 »
PP good, hoping for more units, more is better
Offline unusuaL_
« Reply #5 on: Wed, 29 June 2022, 15:29:35 »
continuing to provide good designs, making them accessible is something i love to see  :thumb:
i'd like to see a weight of a different material if possible, e.g. copper as mentioned above
« Last Edit: Wed, 29 June 2022, 15:31:56 by unusuaL_ »
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Oogtug84
« Reply #6 on: Wed, 29 June 2022, 15:34:00 »
Yes.
I would really dig the orange cream or soft pink from play tray gb >.>
« Last Edit: Wed, 29 June 2022, 15:43:45 by Oogtug84 »
Offline themasterphi
« Reply #7 on: Wed, 29 June 2022, 15:41:02 »
Big fan of r0, was waiting for the more readily available gb later on. Can wait for it  :thumb:. One of my favorite 60% boards I’ve typed on
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #8 on: Wed, 29 June 2022, 15:44:02 »
Love the aesthetic of this board! Very happy to see it come to GB
Offline gotgoodiez
« Reply #9 on: Wed, 29 June 2022, 15:46:44 »
Love the new color choices, making the board more available and making it cheaper too
Offline linell
« Reply #10 on: Wed, 29 June 2022, 16:04:45 »
what is relief mount  :cool:
bro this a **** set, just be thankful you even getting 1 base running fr
Offline mr_foggy
  • neue = nope
« Reply #11 on: Wed, 29 June 2022, 16:12:25 »
derivative so lit
Offline less_blank
« Reply #12 on: Wed, 29 June 2022, 16:36:13 »
Yes.
Second this, would love an orange cream.
Personally would prefer darker shades for a few of the colors (green, purple and red), but can respect if you want to keep things light and bright for this run.
Offline wencan008
« Reply #13 on: Wed, 29 June 2022, 16:38:05 »
Love my r0 and excited for the r1 gb, definitely 60% you shouldn't miss
Offline blight
« Reply #14 on: Wed, 29 June 2022, 16:54:53 »
Filled out the IC form. Very excited for this board and hope I am able to get a unit!
Offline LMarci
« Reply #15 on: Wed, 29 June 2022, 17:49:07 »
I liked the board a lot already and the new color options have managed to reinforce that. Can't wait!
« Last Edit: Wed, 29 June 2022, 17:55:21 by LMarci »
Offline Slayer77
« Reply #16 on: Wed, 29 June 2022, 18:27:07 »
Green..nice.
Sent from my GM1911 using Tapatalk
Offline paqji
« Reply #17 on: Wed, 29 June 2022, 18:32:39 »
i have been waiting for this, we love to see it!!! green is clean
Offline RachaXD
« Reply #18 on: Wed, 29 June 2022, 19:02:22 »
So fricken hyped for this. Down for the dark grey or blue personally. Can't wait to see this move to GB
Offline elvenmonster
« Reply #19 on: Wed, 29 June 2022, 19:57:59 »
100% Joining this GB if I get the chance. Following you for a while and wanna say that your designs are the only ones that really intrigue me outside the Matrix sphere. Lot of original work here. GLWIC!
Offline wigol2506
    • Instagram
« Reply #20 on: Wed, 29 June 2022, 20:09:22 »
Thanks for making this board more accessible!
Really like the sharp transition corner on the R0.
One of the most thoughtful designers ever, cannot wait to join this GB - hopefully we see an interesting 4th colour
GLWIC
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline Jacno
« Reply #21 on: Wed, 29 June 2022, 20:37:58 »
Really excited for this. The gray and the smooth transition bezel  :cool:  Hoping that there is a possibility for silver as well.
Offline Sicowa
« Reply #22 on: Wed, 29 June 2022, 20:52:58 »
Totally get the idea for the flashy colours, any chance we can kill the black or smth for that beige you had in r0  :-[
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline gloomycloud
  • me enjoy 60s
« Reply #23 on: Wed, 29 June 2022, 21:15:59 »
A picture which shows all the mounting points would be nice sir
HHKB Pro Hybrid || Polaris || Kei || Meridian || Leviatán
Offline bitbot
« Reply #24 on: Wed, 29 June 2022, 21:29:42 »
2nd this
Offline Ustinj
« Reply #25 on: Wed, 29 June 2022, 22:06:25 »
Sorry - I tend to prefer uploading images in square aspect ratio because Geekhack seems to limit the maximum width of an image, so hopefully the following upload helps! It's either a 4-point relief mount, or 4/5-point top-mount.
This diagram should clarify the mounting points (other side of plate is a direct mirror), along with any confusion about what "relief" mount is. It's been called leaf-spring a few times but I just call it this - because it's essentially a top mount, supported by a giant relief cut that allows the plate to bend against long arms.
The manufacturer let me know that they won't be doing that color code for me anymore because it created a good number of b-stocks - so that color won't return. Also usually for any R0 / small runs, I typically won't repeat the same colors or weight designs so that people still get that feeling of having an early bird edition :-)
Offline Ensaum
« Reply #26 on: Wed, 29 June 2022, 22:11:01 »
Very interested. Will be following closely. Please don't kill grey/black though.
Offline sirieous
  • help
« Reply #27 on: Thu, 30 June 2022, 00:21:50 »
so hot, please consider dailyclack for oce vendor
Offline conternecticus
« Reply #28 on: Thu, 30 June 2022, 00:34:42 »
Purple looks great. Please consider vendor for South East Asia/China. GLWIC!
Offline ilikerustoo
« Reply #29 on: Thu, 30 June 2022, 01:31:59 »
Nice
Offline Nuap
« Reply #30 on: Thu, 30 June 2022, 02:42:03 »
Really like this, please consider an Australian vendor
Offline treeleaf64
    • treeleaf64
« Reply #31 on: Thu, 30 June 2022, 22:27:26 »
It's not different, you've taken a bunch of features from different keyboards and combined them
camp bottom
corsa side
through weight
curved cherry lip (still not original)
frog chamfer
i like the font for your "designed by jjw" engraving
anyway have a good night from the treeleaf
Everyone must pay the cat tax
Offline Ensaum
« Reply #32 on: Thu, 30 June 2022, 23:10:37 »
camp bottom
corsa side
through weight
frog chamfer
Well.. I mean.. I think that's the point lol
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #33 on: Thu, 30 June 2022, 23:14:20 »
finally
cherry lip
Offline mr_foggy
  • neue = nope
« Reply #34 on: Fri, 01 July 2022, 12:00:03 »
in no matter the price
Offline Visionaire
« Reply #35 on: Fri, 01 July 2022, 21:32:07 »
Form filled
Offline treeleaf64
    • treeleaf64
« Reply #36 on: Fri, 01 July 2022, 23:23:15 »
camp bottom
corsa side
through weight
frog chamfer
design cue != cut and paste
Offline Visionaire
« Reply #37 on: Mon, 11 July 2022, 08:27:10 »
camp bottom
corsa side
through weight
frog chamfer
I think the similarities are intentional as is implied in the name of the product.
Offline Ustinj
« Reply #38 on: Mon, 11 July 2022, 23:54:56 »
Prototypes for R1 arrived.
Purple is a bit too bright / vibrant for my eyes, so probably will have that toned down slightly.
Other two colors are as I hoped.
Regarding the naming, you guys are on the dot - I named it Derivative because new boards are usually variations of existing boards. I can agree with some of the similarities, but I don't see a Corsa side.. though if I'm honest, I believe a keyboard is almost always going to have some basic atomic features that you can't avoid, for the sole fact that it's a keyboard. No matter how you break things down, some things are going to remain constant... like the fact that most are shaped like rectangles, have a weight, have handles to pick it up by, etc - that aren't super specific to one particular board; on the other hand some beautiful cues have clear originators, like the Jane's iconic backplate, the super clean Koala curve, etc.
Offline kidpid
Re: [IC] Derivative R1 | 60% o-ring, top, relief mount | v1 Prototypes
« Reply #39 on: Tue, 12 July 2022, 10:28:15 »
Damn that's a really nice red!
« Reply #40 on: Fri, 15 July 2022, 08:56:51 »
glad to see a GB, I'm in!
Offline flying1911
    • Mechlovin' Studio
« Reply #41 on: Mon, 18 July 2022, 00:35:08 »
so glad to see this fantastic design being made more available. It's time to build my R0  :thumb:
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline infinitum
  • i buy expensive plastic
« Reply #42 on: Mon, 18 July 2022, 06:42:04 »
simply can't wait for r1!
Offline Homiezoned
« Reply #43 on: Mon, 18 July 2022, 11:39:06 »
I need
Offline scoopbb
« Reply #44 on: Mon, 18 July 2022, 14:26:47 »
will plate files become available after gb?
Offline Ustinj
« Reply #45 on: Fri, 05 August 2022, 03:10:49 »
Yes  :thumb:
Offline scoopbb
« Reply #46 on: Fri, 05 August 2022, 12:09:57 »
Offline HOiYA
« Reply #47 on: Sat, 06 August 2022, 00:23:35 »
Any details on the PCB? Will there be a hotswap option? I'm asking as my soldering skills are non-existant!  :))
Offline milka158
« Reply #48 on: Sat, 13 August 2022, 12:08:40 »
gb asap pls
Offline milka158
« Reply #49 on: Mon, 29 August 2022, 15:46:39 »
Would you consider offering the R0 weight as an add-on or an upgrade option?
