Author Topic: [GB] Command 65 - Bluetooth & Toggle Switch & Buzzer (Production)  (Read 31533 times)
Offline PlayKeyboardTW
    • Shop
288782-0288784-1288786-2288788-3
Inherit The Classic
Inspired by the best selling computer - Commodore 64. Command 65 project was well supported by the keyboard community. It took us more than a year to develop and revamp the original design of Commodore 64.
The whole new Command 65 has the retro functions such as toggle switches and buzzer; along with the modern keyboard layout and wireless connections.
Groupbuy Page: https://www.play-keyboard.store/products/command-65
GB Starting Date: 2022.07.20 09:00pm Pacific Time
GB Period: a month
Shipping Date: 3 month after GB ends
Price: 219USD
Units: 500 for each color, 2000 total
Materials & Finish:
High quality injected ABS cases with spray painting
Black POM Plate
Black Anodized Aluminum Plate
Connections:
USB C/Bluetooth
Supported Layout:
289036-4
Features:
Made In Taiwan
Special Designed Top Mounting
High Quality NKK Toggle Switches From Japan
Buzzer
Flex Cut PCB
Hotswappable
Programmable
Silicone Plate Dampener
Silicone Bottom Dampener
QMK Firmware, supports VIA & LINK
Contents:
Top Case x 1
Bottom Case x 1
Main PCB x 1
Toggle Switch Daughter Board x 1
USB C Connector Daughter Board x 1
BL-5J Dual Batteries Module x 1
POM Plate x 1
Plate Installation Bar x 1
Silicone Plate Dampener x 1
Silicone Bottom Dampener x 1
Rubber Feet Set x 1
M2.5*8 Case Screws x 8
M2*6 Daughter Boards, Battery Module Screws x 8
M2.5*6 Plate Installation Bar Screws x 4
M2*3 Plate Screws x 6
M2*3 PCB Screws x 6
M2*3.5 Plate & PCB Installation Screw Nuts x 6
Prototype Photos
288790-5288792-6288794-7288796-8
288798-9288800-10288802-11288804-12
Typing Sounds
Facebook Fanpage
Instagram
Please join our Discord Channel for discussions. :thumb:
« Last Edit: Sat, 20 August 2022, 12:19:29 by PlayKeyboardTW »
    • Shop
Re: [GB] Command 65 - Bluetooth & Toggle Switch & Buzzer
« Reply #1 on: Thu, 07 July 2022, 07:41:37 »
Reserved.
Offline CatalystGear
« Reply #2 on: Tue, 12 July 2022, 12:22:18 »
Can't wait for this!
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #3 on: Tue, 12 July 2022, 15:46:55 »
Don't even dare to think about not offering ISO support !!!
Or...
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Jho
« Reply #4 on: Tue, 12 July 2022, 20:00:58 »
Checked up on the IC here and there and look at that GB is really soon. Price looking good, I very well might get.
Offline geewiz
« Reply #5 on: Wed, 13 July 2022, 05:48:31 »
Are any alternative layouts like split backspace supported?
Offline Poesjuh
« Reply #6 on: Wed, 13 July 2022, 13:39:21 »
What is the front height?
What are the supported layouts?
How do the internals look?
What are the mounting points for the plate?
    • Shop
« Reply #7 on: Wed, 13 July 2022, 23:17:58 »
Or...
It's ANSI/ISO, split backspace supported. So...  ;)
We'll update these in the product page.
    • Shop
Re: [GB] Command 65 - Bluetooth & Toggle Switch & Buzzer (GB on 7/21)
« Reply #8 on: Thu, 14 July 2022, 09:38:21 »
GB timeline has updated. :thumb:
Offline pixelpusher
« Reply #9 on: Thu, 14 July 2022, 17:20:23 »
Is the case spray painted?
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #10 on: Thu, 14 July 2022, 18:29:42 »
Could we see diagrams of the supported layouts?
    • Shop
« Reply #11 on: Fri, 15 July 2022, 01:17:30 »
Yes it is.
We'll update a pic to product page.
Basically it's ANSI/ISO, split backspace supported.
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #12 on: Fri, 15 July 2022, 08:43:52 »
Awesome. I was really wondering about the bottom row, whether you could have three 1u mods instead of the two 1.5u mods to the right of the spacebar. I'm really glad there's ISO support! Is that just for ISO Enter, or 1.25u left shift as well?
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #13 on: Fri, 15 July 2022, 10:30:12 »
Oh, what type of stabilizers does it use - screw-in or plate-mount? Thanks!
    • Shop
« Reply #14 on: Fri, 15 July 2022, 10:33:17 »
We just updated the layout pic in main post. Please check. :thumb:
PCB stabs as most custom keyboard kits. ;)
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #15 on: Wed, 20 July 2022, 23:06:19 »
I was all set to check out and then saw you only accept PayPal? Too bad.
    • Shop
« Reply #16 on: Thu, 21 July 2022, 03:35:49 »
Sorry that there are not so many payments available in Taiwan. :(
Offline phinix
Re: [GB] Command 65 - Bluetooth & Toggle Switch & Buzzer (Groupbuy Live!)
« Reply #17 on: Thu, 21 July 2022, 04:44:53 »
Fantastic design. If it was around $150 I would buy it. Afterall, its plastic.
Offline Maskar
« Reply #18 on: Sat, 23 July 2022, 05:00:06 »
I've been waiting for this since may last year and bought the classic straightaway. Very happy it does indeed support ISO. The price seems fine, but not too happy having to pay delivery for each keyboard individually, as delivery is already quite expensive. Hopefully the next GB will have a black version.
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #19 on: Sat, 23 July 2022, 16:46:29 »
I still broke down and bought it! I never really use PayPal, but this was worth it!  :D
    • Shop
« Reply #20 on: Sun, 24 July 2022, 01:31:42 »
Thanks! Price of Command 65 definitely should be higher comparing to other plastic case keyboard kit comparing to inside structure and design. :)
Sorry that the large flyer of DHL can only be available for one kit. We'll try to improve that in the future.
Thanks for the support! :thumb:
Really appreciate it! We'll secure the quality for the best.
Offline maoam
« Reply #21 on: Mon, 25 July 2022, 15:33:46 »
Shipping only from the US? (So no EU vendor?)
    • Shop
« Reply #22 on: Tue, 26 July 2022, 02:07:42 »
We are shipping from Taiwan. No proxies this time.
Looks very good.
Thanks!  :D
Offline KHAANNN
« Reply #23 on: Mon, 01 August 2022, 11:58:46 »
Are all the colors spray painted? Honestly the spray painting part worries me, it'll get worn down to the base in a year, otherwise an awesome project!
Offline pixelpusher
« Reply #24 on: Mon, 01 August 2022, 13:50:16 »
https://geekhack.org/index.php?topic=117715.msg3132966#msg3132966
Offline KHAANNN
« Reply #25 on: Mon, 01 August 2022, 16:31:13 »
I saw your question but I still have hope that one of them is the base color
    • Shop
« Reply #26 on: Tue, 02 August 2022, 07:47:55 »
Actually some keyboard cases are also spray painted. Normally it will be just a very thin layer since ABS is a great material to grab and hold the spray paint.
Offline elmo
  • Hello I like keyboards
    • Elmo's keyboards
« Reply #27 on: Sat, 06 August 2022, 12:45:50 »
What is the base color of the plastic? (without the paint)
Offline CaesarAZealad
  • Racc
« Reply #28 on: Sun, 07 August 2022, 15:07:13 »
Wish I had known about this sooner. Still it's a 75% so I'm not missing too too much.
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #29 on: Mon, 08 August 2022, 07:44:32 »
From the photos I've seen of the prototypes on their Discord, it looks like each color's plastic is similar to their final paint job. So the grey-painted version has grey plastic underneath, etc.
    • Shop
« Reply #30 on: Tue, 09 August 2022, 09:29:37 »
Thanks for clarifying. :thumb:
    • Shop
« Reply #31 on: Sat, 13 August 2022, 04:40:52 »
From some of you that may interested in watching a typing sounds video, here's one from MechMerlin's build stream earlier today. Come checking it out!
Offline kobyof
« Reply #32 on: Tue, 16 August 2022, 12:41:24 »
After going back and forth a million times just made the order. Ivory color 🔥
Now all is left is to count the days until it ships. Please do your best to ship fast!
Offline Starius
Re: [GB] Command 65 - Bluetooth & Toggle Switch & Buzzer (Production)
« Reply #33 on: Tue, 11 October 2022, 20:06:45 »
Damn, I can't believe I missed out on this one.   Will there be another round in the future?
Offline Rationalkeys
« Reply #34 on: Fri, 14 October 2022, 09:47:33 »
Love the aesthetics. Missed it on this run. Will be following closely for the next run. Good luck with production.
Offline k-dub
« Reply #35 on: Fri, 14 October 2022, 10:00:38 »
Candykey have preorders https://candykeys.com/product/command65
Offline Starius
« Reply #36 on: Sun, 06 November 2022, 17:15:50 »
Thanks for the heads up on that!  :thumb:
Offline hzh0525
« Reply #37 on: Sun, 26 February 2023, 15:10:05 »
Ordere as a 25-year-old Retro lover! :D
Offline pixelpusher
« Reply #38 on: Sun, 18 June 2023, 09:02:55 »
I'm still worried the tabs on the top case (where the plate slides in) are going to break sometime down the road.  I'm pretty sure there are stress marks on the plastic from where I wedged the plate in.  I built mine very early on before people were talking about filing the space down a bit, so I most likely caused some damage.  Trying to come up with a fix on standby if that happens.  ;D  Maybe a small 3d printed bracket that could be glued on to the underside of the top case?
Offline sketch3v
  • Sketch (astro-keys)
    • Astro
« Reply #39 on: Sun, 18 June 2023, 18:37:54 »
those little switches are so cute
