Author Topic: [IC] MW FFITI | Sample Pictures  (Read 14121 times)
Offline Blamby
« on: Tue, 12 July 2022, 16:23:22 »
├┬┴┬┴┬┴┬┴┬┴┬┴┬┴┬┴┬┴┬┴A set inspired by general Graffiti art ┬┴┬┴┬┴┬┴┬┴┬┴┬┴┬┴┬┴┬┴┤
MANUFACTURER: MW
288955-0
Base kit
Sketch kit
The novelties will be done with a thermal sublimination technique
Big thanks to Dontstealmylollipop for amazing novelties
NordeUK Kit
Spacebar Kit
288957-1
Nk65 by NovelKeys
8XMK2 by KBDFans
Sample pictures:
The samples are showing only the colors, the legends are not final
Vendors:TBD
R1 MODS-RAL 200 80 20
R2 MODS-RAL 100 90 40
R3 MODS-RAL 080 85 40
R4(first) MODS-RAL 350 80 20
R4(second) MODS-RAL 300 80 15
Alphas-RAL 110 90 10
Legends-RAL 270 20 25
Collaboration:TBD
A lot of thanks to Dontstealmylollipop for novelties
Updates:
29.07
-Corrected render mistakes
-new base kit instead of alt mods
-removed hiragana kit
05.07:
-new novelties
-changed renders on Sunsetter
-manufacture kfaPBT
-US Vendor KFA
19.05
-Samples arrived
-Manufacture(MW)
-New renders arrived
« Last Edit: Sat, 22 November 2025, 10:03:31 by Blamby »
Offline Blamby
Re: [IC] PBT FFITI
« Reply #1 on: Tue, 12 July 2022, 16:30:48 »
RESERVED
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] PBT FFITI
« Reply #2 on: Tue, 12 July 2022, 16:31:54 »
im not seeing a manufacturer anywhere
Offline Zetina
  • Big bird
    • Instagram
Re: [IC] PBT FFITI
« Reply #3 on: Tue, 12 July 2022, 16:34:21 »
Cool concept but I don't understand why add hiragana alt alphas GLWIC  :thumb:
Instagram: @zetina.kb
Offline Blamby
Re: [IC] PBT FFITI
« Reply #4 on: Tue, 12 July 2022, 16:34:36 »
updated, sorry forgot to mention
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
Re: [IC] PBT FFITI
« Reply #5 on: Tue, 12 July 2022, 16:38:09 »
not seeing the correlation between hiragana and graffiti
Offline Blamby
Re: [IC] PBT FFITI
« Reply #6 on: Tue, 12 July 2022, 16:43:04 »
I find the sublegends quite lovely with this color palette
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
Re: [IC] PBT FFITI
« Reply #7 on: Tue, 12 July 2022, 17:14:42 »
if there is no reason for hiragana sublegends other than looks, remove them.
Offline finalarcadia
Re: [IC] PBT FFITI
« Reply #8 on: Tue, 12 July 2022, 17:18:04 »
Why lol aren't sets mostly for the look of it. Or do you require some lore
Sent from my SM-S908U1 using Tapatalk
Offline Bub
    • big bub's beepers
Re: [IC] PBT FFITI
« Reply #9 on: Tue, 12 July 2022, 18:23:03 »
i like novs and alt mod kit
alphas seem out of place
glwic tho cool idea
Re: [IC] PBT FFITI
« Reply #10 on: Tue, 12 July 2022, 18:33:32 »
Graffiti font is interesting but looks very cramped on the modifiers. Alphas look like they came from a totally different set in the renders with graffiti modifiers. Could probably lean a lot harder into the graffiti theme if alphas used graffiti font and modifiers were graffiti icons. Novelties are nice but it feels like a waste that they aren't graffiti style.
This is a cool idea but from the theme I was hoping to see something with more personality.
« Last Edit: Tue, 12 July 2022, 18:56:03 by unwashed_heathen »
Offline Cylent
  • Formerly cylentshadows
Re: [IC] PBT FFITI
« Reply #11 on: Tue, 12 July 2022, 19:54:17 »
Some thoughts:
-As a mod gradient enjoyer myself, I like the colors. They remind me of a more saturated ePBT gelato.
- While you don't need to have a manu, you should have some in mind, and if you're planning on choosing between multiple dyesub manus, you should say that.
-The kitting is missing a few things, namely mod esc, 2u shift, and purple up arrow. You've chosen to forego alternate options for the vertical keys, which imo doesn't make much sense if this is all regular dyesub.
-I echo many others who think this hiragana kit should be trashed. I completely fail to see the connection between graffiti and hiragana alphas.
-Novelties are alright, but I think you really are missing an opportunity by not having an iso novelty.
-The alt mods are cool, but I think by mixing so many colors into the legends you've lost me here, and I'm sus of an unknown, unchosen manu's ability to produce this. I think by making all the legends black the alt mods can really shine - or at least always use contrasting colors on opposite sides of the color wheel (I'm looking at you, R3).
-Finally, on the renders, Cypher has alpha-colored arrows that don't exist in your kits, and some have a ton of noise. I understand if you personally don't prefer denoise on your renders, but if you're not denoising you need higher samples.
Overall this is promising but needs some fine-tuning. GLWIC! :thumb:
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
Re: [IC] PBT FFITI
« Reply #12 on: Tue, 12 July 2022, 21:22:23 »
hey that's a nice keyset but
Base Kit:
- The full-touch Caps Lock has the wrong legend (CapsLock instead of Caps Lock)
- The non-barred set of F, J, and 5 are rendered as flat, as opposed to the traditional scooped
- The R4 >< key for terminal ISO has its legends swapped, despite a perfectly fine version being rendered in the NorDeUK kit
- No pink R4 1u Fn means that split right Shift users have to use a purple Fn key instead
- No F13
Hiragana Kit:
- The entire kit is missing top-right legends. As far as I know, they're actually useful
- Not having an extra tab also makes this kit far less useful for people who may want to buy Base + Hiragana and have compatibility for two boards
- Same issue with flat/scooped F and J
Alternative Mods Kit:
- The yellow and orange keys have legend colour inconsistencies. Some legends are pink and some are purple and there's next to no correlation
- Same issue with pink 1u Fn
NorDeUK Kit:
- why'd you switch over to krk for this lol
- There's a redundant >< key in R4, unless you don't plan to fix the one in Base
Spacebar Kit:
- Convex 6u is here twice; is one of them supposed to be center stem and the other uncentered?
Renders:
- There's a typo on the fancy banner
- The Cypher renders have alpha arrows, orange 2u Numpad Plus, and purple icon + text Numpad Enter, none of which are in the set
- The Ikki68 Aurora renders have Super keys; again, not in the set
- The M60 renders have a pink 1u Fn
- The Sunsetter renders have Super keys and a pink 1u Fn
- The Jane render is rendered with F13
MANUFACTURER: TBD
 :-X
Offline less_blank
Re: [IC] PBT FFITI
« Reply #13 on: Tue, 12 July 2022, 22:54:24 »
I like the alt mods a lot but it looks a little odd with the regular alphas, an alpha kit with similar legends would be cool or just a full base kit version would be even better.
Offline sirnottoday
  • hi!
Re: [IC] PBT FFITI
« Reply #14 on: Wed, 13 July 2022, 04:44:04 »
Like the concept. GLWIC!
There's a typo on Renders banner :)
Re: [IC] PBT FFITI
« Reply #15 on: Mon, 25 July 2022, 11:12:52 »
What ever happened with GMK Pride? I see you’re posting new interest checks but dodging questions about GMK Pride updates…
Offline Blamby
Re: [IC] PBT FFITI
« Reply #16 on: Mon, 25 July 2022, 14:16:26 »
Pride should be finished around next month, maybe a bit more and then should be shipped
Offline Blamby
Re: [IC] PBT FFITI
« Reply #17 on: Fri, 29 July 2022, 02:32:23 »
UPDATE:
29.07
Offline Gerevala
Re: [IC] PBT FFITI
« Reply #18 on: Fri, 29 July 2022, 05:04:06 »
I really don’t think PBT can make this color.
Offline Blamby
Re: [IC] PBT FFITI
« Reply #19 on: Sat, 30 July 2022, 14:05:01 »
working on this
Offline Blamby
Re: [IC] kfaPBT FFITI | New novelties, manufacture
« Reply #20 on: Wed, 05 July 2023, 13:54:03 »
Finally, its been over a year since the last update. Now I can make some of you happy with the new update which includes:
-new novelties
-manufacture kfaPBT
-US Vendor KFA
Offline Blamby
Re: [IC] MW FFITI | Sample Pictures
« Reply #21 on: Sat, 19 April 2025, 05:31:52 »
19.05
-Samples arrived
-Manufacture(MW)
Offline Blamby
« Reply #22 on: Sat, 22 November 2025, 10:04:19 »
Update: New renders
In plan: Collaborating with vendors
