Author Topic: [GB] Liberi | 65XT with Frog side  (Read 9571 times)
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
« on: Thu, 21 July 2022, 21:45:58 »
About
    Hi, I'm $W4GK!NG, and this is my first publicly project.
    I saw a Kmac Mini and I instantly fell in love, so I made this board. The namesake and color choices are some weeb stuff no one probably cares about.
Specs
    - Material: 6063 Aluminum with Brass Weight
    - Color: Anodized blue or gray with Clear Coated Sandblasted Weight
    - Plate: Sandblasted Polycarbonate with MX cutouts (Alps plate will be available later)
    - PCB: Designed by Sleepdealer, Solder only with Alps support, using a Unified Daughterboard
    - Typing angle: 6°
    - Dimension: 358mm x 112mm
    - Front Height: 22mm adjusted
    - Weight: 1.6KG unbuilt
    - Mounting: Top mount
    - Layouts: Refer to the picture below
Colors
    The colors are RAL 5000 and RAL 7011.
Pricing, Lead Time, Availability & Vendors
    The GB will be running from July 22nd to August 5th with an unlimited cap
     Vendors
        - Ashkeebs (covers the NA area)
        - KEYGEM (covers EU and UK)
        - HexKeyboard (covers SEA and Asia in general)
        - Acid & Co (covers Indonesia)
    Price per keyboard is $545.00CA / €500.00 (incl. 19% VAT) / $589SG / 6,299,00Rp with 100MOQ
   Both the extra plate and PCB are $58.00CA / €55.00 (incl. 19% VAT) / $65SG / 749,00Rp
    The estimated shipping date is around Q2 2023 :thumb:
Prototype & Iteration
    Prototype Album
    Alexotos Prototyle Album
    (In the RAL 7011 color and with all the design updates)
This blue prototype was built in the most basic of all layouts.
    I typed on that for a month and I don't like how muted the spacebar was so I decided to add some acoustic cut on the spacebar area both on my prototype and the model.
    And I ended up infilling the front engraving with acrylic paint.
    For the GBrun, there are some changes since the prototype unit, the case wall size has been reduced and the wall that separated the xt column has been thickened a little. I also added a chamfer all around the bottom case and the seam, and also the plate height from plate to top case has been increased from 7.5mm to 7.8mm.
    Anyway here's a sound test of the first build of the prototype unit, without the spacebar cut yet.
Special Thanks
    Bachoo - Literally everything, from teaching me the design basic to CAD and ****, thank you :peepolove:
    CrazyAssMonkey - Thank you for answering all my dumb Fusion questions
    Bababaul - Thank you for the feedback and all the info I probably would never have if it weren't for you
    Founder role on my discord - Thank you for supporting me all this time, thank you
« Last Edit: Fri, 19 August 2022, 00:57:40 by $W4GK!NG »
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [GB] Liberi | 65XT with Frog side
« Reply #1 on: Fri, 22 July 2022, 21:06:50 »
del
« Last Edit: Fri, 22 July 2022, 21:33:04 by Kokaloo »
Offline Fraaaan
« Reply #2 on: Sat, 23 July 2022, 03:46:25 »
This is the top mounted, weeb, 65XT board of the year to get. GLWGB Swag! <3
Offline The0rigina1
  • fumoposting
« Reply #3 on: Sat, 23 July 2022, 04:43:08 »
2/10 needs more weeb
Offline whirlwind
« Reply #4 on: Sat, 23 July 2022, 04:48:10 »
Amazing job with the project Swag, good luck with the GB!
Offline Bunn3y
  • 绊
« Reply #5 on: Sat, 23 July 2022, 05:03:50 »
It's great to see that this project is finally coming to fruition. Congratulations on the groupbuy Swag!  :D
Collection: Ivery Praxis | HHKB Pro 2 | JTD.Works Ovinnik | Realforce R1 87u | Switchplate iiA Sanction
Offline ankit
  • Formerly ankit-sachdeva
« Reply #6 on: Sat, 23 July 2022, 11:12:16 »
liberi so lit, glwgb dad
Offline $W4GK!NG
    • Linktree
« Reply #7 on: Sun, 24 July 2022, 20:52:46 »
Thank you everyone for your kind words :thumb:
