Author Topic: Wheelwriter 10 Series II  (Read 5687 times)
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« on: Fri, 24 September 2010, 18:51:15 »
Got it for free...well found it beside a building labelled E-Waste :D
:D
Unfortunately the ribbon was ripped, so I had to do some surgery.
But in the end, no problems.
Neato
Nice keys
And if you hadn't realized:
Buckling Spring :D With single piece caps, I might add.
Only 2 rivets missing, pretty good, for probably being dropped (it's pretty heavy).
Technically, I could read all the stuff people before me typed, but that would be a pain, as there's no spaces...
No ground...
Best part, the power switch :D
More pics on picasa.
« Last Edit: Fri, 24 September 2010, 19:15:15 by HaaTa »
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline elbowglue
« Reply #1 on: Fri, 24 September 2010, 18:54:59 »
Awesome!
Love the toes too hehe.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline HaaTa
  • Kiibohds!
« Reply #2 on: Fri, 24 September 2010, 19:14:31 »
Quote from: elbowglue;226469
Awesome!
Haha, yeah. It's big and heavy, so trying to get a good shot is difficult :P.
Especially when your apartment has no furniture...yet.
Kiibohd
Offline HaaTa
  • Kiibohds!
« Reply #3 on: Fri, 24 September 2010, 19:50:11 »
Picked it up on 09/20/2010, keyboard made:
Damn, a month early :P.
Kiibohd
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Sat, 25 September 2010, 15:18:18 »
Quote from: HaaTa;226467
Yummy, battery leakage. (Or is it?) Thankfully those are alkalines at least.
I hope getting the cracked case fixed wasn't too much of a problem? I once had a similar problem on a radio, got it glued for the most part but it resisted pretty heavily.
Offline HaaTa
  • Kiibohds!
« Reply #5 on: Sat, 25 September 2010, 18:40:49 »
Quote from: keyb_gr;226734
Yeah, definitely battery leakage. I'll fix that part once I feel the need to save margins, and settings :P. Currently I've just unplugged the battery unit.
The crack seems very fixable (glue), as it's not really a big structural piece (only covers the keyboard portion). Picking up the whole unit, there's a big metal plate on the bottom.
Kiibohd
Offline didjamatic
« Reply #6 on: Sat, 25 September 2010, 22:23:18 »
I have an Actionwriter (similar to Wheelwriter) Has anyone made these work on a PC?
Offline williamjoseph
« Reply #7 on: Sun, 26 September 2010, 02:09:06 »
I have a series II wheelwriter 6. Picked it up at the local goodwill store for $5, 3 additional font weels, 5 ribbons and 3 correcting ribbons for another $2. Using the hell out of it for filling out applications. anyone have any lead on legit work at home possitions PM me.
Offline ch_123
« Reply #8 on: Sun, 26 September 2010, 03:52:15 »
Why does the Wheelwriter need a battery inside it? Does it have a BIOS? :P
These must have been pre-rubber washers on the barrels. It also looks like a Model F conversion.
Offline HaaTa
  • Kiibohds!
« Reply #9 on: Sun, 26 September 2010, 07:46:29 »
The battery is for saving settings such as the margins, spellcheck, etc.
Manual
Kiibohd
Offline ch_123
« Reply #10 on: Sun, 26 September 2010, 07:58:07 »
From the manual's troubleshooting section -
Typewriter Operates Hot
3. Make sure typewriter is not near a heater.
Good 'ole IBM...
Offline sethstorm
« Reply #11 on: Sun, 26 September 2010, 11:23:54 »
If I was only that lucky, HaaTa.  That said, my purpose for such a dumpstered typewriter would be to rip out the keyboard casing.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline pkpossum
« Reply #12 on: Sat, 23 October 2010, 11:42:05 »
Wheelwriter 3 problem.  Typewriter ribbon does not move when keys are struck.  Correcting ribbon moves when correction key is struck.  Odd thing, I have two wheelwriters (one stored as a backup).  Both have the same problem.  When the "in use" one failed, plugged in the other, and it had the same problem.  Huh?  What are the likely causes of a ribbon motion problem?  Both are about the same age (1990's), is there a "life" issue with some part?
« Last Edit: Sat, 23 October 2010, 11:49:23 by pkpossum »
