Author Topic: [IC] Daal - A Plateless O-Ring 60% - Production units ordered!  (Read 70254 times)
Offline Omnias
Re: [IC] Daal - A Plateless O-Ring 60%
« Reply #100 on: Fri, 12 August 2022, 18:15:36 »
Based project, based specs, based PCBs by a based PCB designer, based case design everything promoted by a SUER DUPER BASED designer.
What's not to like about this project, given also that the not cash-grabbing price and the fact that proceedings will go towards a good cause, especially important in the current moment.
Really appreciate that this project is driven by passion and aims to bring a good experience to the user.
Did I already said this is based?  ;D
I might just have to get a 10u spacebar for this build
Offline Applet
« Reply #101 on: Mon, 15 August 2022, 08:48:29 »
GL with GB! Looks great and love that it'll be able to source parts after GB  :cool: Sustainability/longevity of the keeb should be considered in all GBs imo.
Offline LMarci
« Reply #102 on: Mon, 15 August 2022, 18:35:35 »
Daal so good :thumb:
« Last Edit: Sat, 08 October 2022, 05:42:51 by LMarci »
Offline hpetrovski
  • Osum
« Reply #103 on: Wed, 17 August 2022, 14:10:49 »
Great project Ankit, regardless of you doing a disservice to the o-ring community! :thumb:
Offline B_D
    • bdskeyboards
« Reply #104 on: Thu, 18 August 2022, 10:01:30 »
Holy for that price this is amazing! Please make more  :thumb:
height=120]https://imgur.com/rPWNMJz.png[/img][/url]
Offline treeleaf64
    • treeleaf64
« Reply #105 on: Fri, 19 August 2022, 15:54:03 »
I typed on Daal and it was good  Reminded me of vintage cherry board and    Felt better than IDB along with better finishing.  It also looks much better than idb.
And there is the treeleaf cowering behind a rock as his tormentors approach
Everyone must pay the cat tax
Online Kokaloo
  • 🤘(• ω •)🤙
« Reply #106 on: Fri, 19 August 2022, 16:27:44 »
no way a keyboard made to not look like a brick and not designed to cost as little as possible looks better than idb??
Offline treeleaf64
    • treeleaf64
« Reply #107 on: Fri, 19 August 2022, 16:42:04 »
Do not make fun of your poor treeleaf : (
Offline base
« Reply #108 on: Sat, 20 August 2022, 00:24:30 »
Excited for this one.
Offline Ustinj
« Reply #109 on: Sun, 21 August 2022, 01:04:25 »
EPIC!
Offline frickingben
« Reply #110 on: Sun, 21 August 2022, 20:22:58 »
wwwwwwwwwwwwwwwwww
Offline Riizmaa
« Reply #111 on: Wed, 24 August 2022, 19:06:09 »
this was to low so I wanted to bring it back up *wink*  :p :p :p :p
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #112 on: Wed, 24 August 2022, 20:01:05 »
I want daal
checking for gb info
I want daal btw
Yes
« Reply #113 on: Wed, 24 August 2022, 21:33:24 »
I want daal
I want daal btw
the gb info is that it'll be in stock at some point. you can sign up to get alerts for this thread on the bottom right corner of the page
Offline Riizmaa
« Reply #114 on: Thu, 08 September 2022, 02:58:40 »
weeeeeeee up up up weeeeeeee up up  :p :)) :cool: :cool: :cool: :cool:
Offline herbologist
  • beige enjoyer. send help.
« Reply #115 on: Thu, 08 September 2022, 20:15:46 »
Ne update? Maybe PC??
Sent from my Pixel 6 Pro using Tapatalk
Offline ankit
  • Formerly ankit-sachdeva
« Reply #116 on: Sat, 24 September 2022, 14:07:13 »
I have received 3 more prototypes since the last update including a PC and aluminum version of the final design. Here is a picture showing the evolution of the side profile (rightmost is latest/final).
Unfortunately the design doesn't lend itself well to PC due to the amount of compression needed to compress the 75a o-ring. I am currently waiting on what will hopefully be the last prototype and then will order production units immediately afterwards.
Lightning has received and will be streaming one of the 3rd revision prototypes with Gateron X switches soon.
Offline juaninamilli
« Reply #117 on: Mon, 26 September 2022, 18:23:59 »
Nice! Looking forward to the stream.
Offline hiddensong
  • this too shall pass
« Reply #118 on: Wed, 05 October 2022, 05:10:12 »
What length wire is supported for 10u? Wanna see if I have the correct length or if I must source.
Offline ankit
« Reply #119 on: Wed, 05 October 2022, 13:54:53 »
7u and 8u wires will both supported to support both DCS 10u molds. I will be ordering production PCBs this week and will be hopefully be able to show what 10u looks like on the board later this month. This is the production PCB with maybe some small silkscreen changes but otherwise finalized.
Biggest changes are:
- added extra diodes on PCB
- added another indicator on the "Escape" key to be used as a layer indicator
« Last Edit: Wed, 05 October 2022, 14:23:13 by ankit-sachdeva »
Offline Sleepdealr
  • my name is calliah
    • https://sleepdealer.xyz
« Reply #120 on: Wed, 05 October 2022, 23:12:55 »
To clarify on the indicators
The CapsLock LED will be used as a regular caps lock indicator. (On when caps is enabled)
The Esc LED will be used as a layer indicator. (On when on layer 1)
Green 3mm LEDs will be included
Online LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] Daal - A Plateless O-Ring 60% - Production units ordered!
« Reply #121 on: Mon, 10 October 2022, 16:08:55 »
daal proto pics
good job hali, sleepdealer, and ankit :cool:
Offline kidpid
« Reply #122 on: Tue, 11 October 2022, 09:31:07 »
This keyboard is looking really good! One minor thing, would it be possible to move the DB back a bit so you can add a recessed area around the USB-C port so the cable looks a bit cleaner from the top?
This is what I'm talking about:
Here's how the Kei does it for reference:
Offline Bub
    • big bub's beepers
« Reply #123 on: Tue, 11 October 2022, 10:33:30 »
daal
Offline ankit
« Reply #124 on: Tue, 11 October 2022, 14:07:12 »
Production units have already been ordered and this is not something I am going to change at this point. I prioritized the board looking cleaner from the back unplugged than looking from the top down plugged. :thumb:
Offline kidpid
« Reply #125 on: Tue, 11 October 2022, 14:45:02 »
That's fair.
Offline treeleaf64
    • treeleaf64
« Reply #126 on: Wed, 12 October 2022, 00:08:48 »
I typed on the polycarbonate clear unit and the aluminum production prototype, and they were both great. I preferred the 75a harder o ring on the pcb. I trust My Frogger.  if he does not fulfill the in stock   I will go to his house and steal all of the daals and Raals
Offline VXQN
« Reply #127 on: Wed, 12 October 2022, 05:17:42 »
Love the design of this board, the proportions are just perfect to my eye.
The decision to open source it is also commendable. Looking forward to trying to buy one!
Offline mr_foggy
  • neue = nope
« Reply #128 on: Wed, 12 October 2022, 13:12:10 »
gibe daal
Offline ankit
« Reply #129 on: Mon, 31 October 2022, 17:13:42 »
Hey ya’ll! Just a small update!
Production has started on the cases:
- Ordered 25 HHKB and 25 WKL cases at the end of last month
- My manufacturer has just started machining on them as of this week
- Carrying cases and microfiber clothes will be ordered slightly before production is finished
Production PCBs have arrived:
- These include 10u support, extra diodes, and another indicator LED spot on the ESC key
- Have tested these with some Cherry and JWK switches I have on hand which all both fit snuggly
- Fixing some small firmware issues before I flash, test, and package all of these
- Photos will be updated on original post shortly
Sales format has been decided:
- Will be utilizing a raffle instead of FCFS due to the limited number of units left after FnF units
- More details will be announced once finalized
Finally:
I happy someone trying to do something differnt with a good target price of $280 in-stock buy. This looks like a plateless mount using a o-ring around each of the 4 pcb tabs for flex as such this is not a true o-ring mount just because the design use a o-ring does not make it a o-ring mount (i.e. a burger mount use small o-rings around the screw but cannot be called o-ring either). Please change the title of your ic for currently calling this a o-ring mount does a disservice to keyboard community and other great designs that are true o-ring mount which suspend the pcb all the way around providing the the flex GLWIC.
Happy Halloween!  ;D
Offline Cawfee
« Reply #130 on: Mon, 31 October 2022, 17:31:41 »
based ankit
Offline Nuap
« Reply #131 on: Mon, 31 October 2022, 18:42:41 »
Thanks for choosing a raffle format.
Offline Backspace2
« Reply #132 on: Mon, 31 October 2022, 19:40:05 »
Woo raffle format! Hyped for this!
Yes
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #133 on: Sun, 04 December 2022, 12:13:38 »
soon?
Offline ankit
« Reply #134 on: Sun, 04 December 2022, 12:41:10 »
soon?
Possibly this month but more likely Q1 2023. :cool:
Offline VXQN
« Reply #135 on: Tue, 06 December 2022, 05:50:25 »
Any info about the "unifried" daughterboard? Looks like a nicer design than the C3 daughterboard.
Offline AlexMcD0
« Reply #136 on: Tue, 27 December 2022, 13:03:18 »
How many units are left after fnf?
thanks!
