Author Topic: [IC]Sweet60 - Gummyworm O-Ring Mount 60% Based on the DZ60 PCB  (Read 7435 times)
Offline Thumbkins
289551-0289553-1289555-2289557-3289559-4289561-5289563-6289565-7289567-8289570-9
Case Specifications
Typing Angle: ~7 Degree
Front Height: ~20mm
Mounting: GummyWorm O-Ring mount keyboard
Case Material: Polycarbonate
Finish: Sandblasted
PCB
Solder PCB
Currently Plan to use dz60 flexcut as the PCB for this keyboard
Hot-Swap PCB
Switch = Cherry-Style Switches only
Facing = South Facing Switches
RGB = 12 RGB Underglow
Thickness = 1.2mm
Firmware = QMK/VIA/VIAL
What's Include in the package
- Hard Carrying Case
- 50A O-ring
- Screw
- Silicon Feet
Price
Quote from the manufacturer that the whole kit should be around 150 to 170 USD
Supported Layout
- Solder PCB as DZ60 Flexcut supported layout
- Hotswap PCB Standard 1.75u shift with stepped capslock supported (Original caps lock south facing hot-swap socket, stepped capslock north facing hot-swap socket)
Additional Stuff
- Slot - 50 to 100 pieces
- The sales format will be GB and an FCFS
- Vendor - TBD
- The one prototype in the picture is printed in resin to test out the fitment of the case. Currently, a proper PC CNC case is under production and the picture will be updated once the keyboard arrives.
IC FORM
https://forms.gle/ikjKhUm5jF1M5hrU7
*UPDATE*
1. Since china government is locking down some places again and apparently the prototype manufacturer is right at the lockdown place, the prototype will now have a delay. When I will receive the prototype is still Unknown according to the manufacturer.
2. After approaching to KBDFans, the pricing for dz60 is not suitable for the GB pricing therefore will now use a different design PCB.
PCB specification
  • VIA/VIAL/QMK support
  • Support WKL, Standard 60, Short shift for solder pcb
  • Tsangan Layout for hotswap
  • Alps Support for solder pcb
  • 1.2mm PCB thickness
  • Come with stab shims
Solder PCB Support
290055-10
Hotswap PCB Support
290057-11
« Last Edit: Tue, 09 August 2022, 21:55:05 by Thumbkins »
Offline rookb
Re: [IC]Sweet60 - Gummyworm O-Ring Mount 60% Based on the DZ60 PCB
« Reply #1 on: Thu, 28 July 2022, 21:32:59 »
This is a render.
Offline Thumbkins
« Reply #2 on: Thu, 28 July 2022, 23:54:55 »
Sorry about the prototype part. The picture is updated into the original post
Offline ankit
  • Formerly ankit-sachdeva
Offline stewfayew
« Reply #4 on: Fri, 29 July 2022, 07:44:11 »
So you designed it around this ONE pcb. If you just used the publicly available, non-copyrighted Bakeneko v3 you would have DOUBLED your pcb compatibility.
Offline Backspace2
  • Third most used key on the keyboard is Backspace!
« Reply #5 on: Mon, 01 August 2022, 14:58:47 »
So... A PC Ciel, essentially?
Yes
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« Reply #6 on: Wed, 03 August 2022, 00:20:28 »
The thickkk plastic case is impressived! Would be nice to have other version like 65% as I personally need arrow keys  ;D ;D
Offline Kaitodesu
  • Chief of Custom Keyboards(COCK) at Mecha Malaysia
    • I take photos and videos of Keyboards
« Reply #7 on: Thu, 11 August 2022, 09:24:17 »
OP is in Asia, and they can get DZ60s easily from kbdfans Taobao which is way cheaper than the website shipped. And when you compare this to paying 40usd in shipping from CK or NK just for bakeneko/h60 makes no sense.
So tailoring this keyboard to the dz60 V2 with gummy o-ring cutouts that 0 boards currently use is a pretty sensible move for OP's local market.
Yes, OP can double/triple/quadruple PCB compatibility with the h60/bakeneko ecosystem sounds good to an o-ring enthusiast (like me) but looking from OP's perspective NONE of those PCBs are reasonably priced and accessible to them compared to the DZ60s, which is the whole point of this board. So just like how bakeneko is affordable to NA/EU but kbdfans is super expensive, it's vice versa for people in Asia/SEA/OCE
