Author Topic: Model F AT on ebay.co.uk  (Read 2739 times)
Offline hoggy
  • * Ergonomics Moderator
Offline ch_123
« Reply #1 on: Sat, 25 September 2010, 17:31:47 »
Of some note, this is a UK layout version.
Offline JBert
« Reply #2 on: Sun, 26 September 2010, 08:21:39 »
It's still a steal even if you can't use the keyboard feet. It only ships within the UK though.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ch_123
« Reply #3 on: Sun, 26 September 2010, 09:22:35 »
The interesting thing is that the UK layout is identical to the US layout, except that the keys are located in different places. Although, if you set a US layout AT to UK, I'm not sure if the key to the left of 1 becomes |\ like on that keyboard, or the logical NOT/grave/half-pipe key that you usually get on a regular UK keyboard.
Offline NewbieOneKenobi
« Reply #4 on: Sun, 26 September 2010, 11:33:30 »
I've used a UK layout keyboard with the US layout no problem (the one in my avatar), even when I still had to look at the captions. You can also do what I have with my M and remove the key caps (they should be double-shot in the F too but I'm not sure). It changes the typing feel to more crispy and F is already more so than M. The result should be funny, like getting zapped by electricity on your fingers. ;) Naturally, if the only difference is key placement, not key number, you can just switch the key caps and forget it had come the other way.
Offline ch_123
« Reply #5 on: Sun, 26 September 2010, 11:45:42 »
Quote from: NewbieOneKenobi;226968
I'm talking about the AT keyboard here. On the AT, the \| key is moved beside 1. This is not where it will appear if you set a standard US keyboard to have the UK layout. So I'm wondering if the UK AT Model F has a special controller.
On the flipside, the UK layout could have been different back then.
I think you mean 'double part' (double shot is something completely different). The AT Model F does not have double part keys, only single part ones.
« Last Edit: Sun, 26 September 2010, 11:48:12 by ch_123 »
Offline Soarer
« Reply #6 on: Sun, 26 September 2010, 12:26:42 »
Hmm, interesting... it could do with a bath though!!
Are the feet the same as on the XT model F?
Ditto for other bits - basically is an XT version useful for spares when fixing an AT version up?
Offline hoggy
« Reply #7 on: Sun, 26 September 2010, 15:26:55 »
If you aren't in the UK, I would be happy to receive it and forward it on - costs only.
Offline Soarer
« Reply #8 on: Sun, 26 September 2010, 17:21:37 »
That's very generous of you! :)
If that was @ me... no need thanks, I'm in the UK ;)
