Author Topic: qmk/via daughterboard?  (Read 4162 times)
Offline PlayBox
« on: Wed, 17 August 2022, 15:29:00 »
is it possible for daughterboard that will make your keyboard qmk/via/vial compatible to exist? if yes does it exist?
reminder: not looking to make it i lack the experience and ability to make it.
propably sent from my amazon kindle 10th gen
Offline Tactile
Re: qmk/via daughterboard?
« Reply #1 on: Wed, 17 August 2022, 20:40:27 »
Not exactly what you're asking about but here's a gadget which will make your USB keyboard programmable. No soldering or other mods needed. You don't even need to open the keyboard case.
REΛLFORCE
Offline Tactile
« Reply #2 on: Fri, 19 August 2022, 14:56:02 »
Some additional info: if you're interested in the device I wrote about, it's listed as in stock at 1UP keyboards, so you can buy direct from USA.
REΛLFORCE
