Author Topic: [IC] Series KP | esc lab — Keycap Puller  (Read 7513 times)
Offline Cubic | esc lab
    • esc lab
« on: Sat, 27 August 2022, 07:58:12 »
SERIES KP
Artisan Protector. Ergonomic Handle. Stainless Steel.
Please take the IC survey
Hello everyone!
After a long period of sketching, experimentations, sourcing and prototyping, we’re ready to show everyone the next tool for your keycaps.
This interest check is for Series KP, a CNC machined stainless steel keycap puller that protects your artisans/novelties/keycaps. The triangular profile is designed for better ergonomics, with a rubber layer over the wire for cushioning and protection.
Today, we’re pulling the curtains to show you Series KP.
We hope you like what you see, and as always, feel free to leave any feedback.
0. CONTENTS
⠀1. DESIGN CONCEPT
⠀2. SPECIFICATION
⠀3. DESIGN DETAILS
⠀4. GALLERY
⠀5. VENDORS
⠀6. TIMELINE
⠀7. OUR COMMUNITY
⠀8. THANK YOU
1. DESIGN CONCEPT
This is the story of how and why we came up with the design of Series KP. When we first received prototypes of Series 00 (our first metal novelty keycaps), we were all excited about the prototypes and couldn’t stop playing with them. We tested them on some switches for fitting and the sound they produced. It was a great satisfaction to finally turn an idea from paper to digital to physical prototype. Right when we were about to test them on other switches, we all stumbled upon the same dreadful question — How do we remove them from the switches without scratching or damaging them?
This is a big problem with the current state of keycap pullers within the market. They are affordable tools for removing plastic keycaps, but are terrible at protecting your artisans. Metal wires on resin artisans and metal novelties are not a good idea. We eventually used a plastic spudger to pry the prototypes at the bottom away from the switches’ top housing to avoid scratching them and succeeded in separating them. This experience was both unpleasant and terrifying; however, this process revealed to us the potential experience our customers will face and led us to the discovery of a design opportunity — a protective keycap puller for artisan keycaps.
Hence, Series KP is born.
2. SPECIFICATION
Color-Material-Finish
Design A
Material          Color        Finish          Coating        Dimensions                    Dimensions (Without Wires)     Weight
Stainless SteelSilver/RawSandblastNone23.7 X 23.3 X 172.8 MM23.7 X 21.2 X 90.5 MM137.7 g
Stainless SteelBlackSandblastPVD23.7 X 23.3 X 172.8 MM23.7 X 21.2 X 90.5 MM137.7 g
3. DESIGN DETAILS
We designed Series KP with a triangular profile for better ergonomics. The traditional 3 fingers grip will form a natural triangular shape, like a vice chuck on power drills or metal lathes.
Better ergonomics means better comfort. Pulling one keycap is easy, but imagine longer sessions like removing 87 keycaps from a TKL keyboard. What about streamers who have to remove the full keycap set multiple times for testing different build configurations? The improved wire design also allows Series KP to hold significantly more keycaps in one setting, reducing interruptions whereas traditional keycap pullers can only hold a maximum of two keycaps.
The wires are made from stainless steel with a rubber layer at the tip. The rubber layer on the wires protects your artisans and novelties. They extend at a height where it cushions and protects the bottom, bottom edges and sides of your keycap. This is full protection.
Finally, there is one more thing.
Yes, Series KP has a hidden mechanism where it is also a stem adjustor. Due to manufacturing tolerances, both switches and keycaps will have slight differences where they may not fit perfectly and requires minor stem adjustments.
4. GALLERY
Additional assets can be viewed here.
5. VENDORS
Series KP is intended to be an unlimited GB with major regional vendors which will be confirmed at a later date.
6. TIMELINE
This is an estimated timeline for Series KP. We will update the timeline when it’s time for GB, and we will keep everyone informed with updates in our Discord and Research Facility.
7. OUR COMMUNITY
Discord
Instagram
Website
8. THANK YOU
Thank you all for taking the time to read this IC.
CONSIDER SERIES KP
    • esc lab
Re: [IC] Series KP | esc lab — Keycap Puller
« Reply #1 on: Sat, 27 August 2022, 07:58:53 »
Reserved!
Offline oilpapers
« Reply #2 on: Sat, 27 August 2022, 08:11:26 »
About time! I'm in for two.
Offline well_cooper
  • Turn metal in to typing machine
    • Thocc Supply
« Reply #3 on: Sat, 27 August 2022, 08:11:56 »
Nooice :thumb:
Offline Yuinth
« Reply #4 on: Sat, 27 August 2022, 09:53:24 »
Love it. The rubberized tips will get rid of the stress of scratching my keyboard when removing keycaps. Have you considered other materials (brass, Cu) possibly on future rounds?
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #5 on: Sat, 27 August 2022, 10:19:05 »
inb4 it's a $40 keycap puller
Offline Anthixious
« Reply #6 on: Sat, 27 August 2022, 11:12:05 »
Finally this project will see the light of day. This is THE ONE keycap puller I've been waiting on.
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #7 on: Sat, 27 August 2022, 11:56:19 »
save the keps
Offline SDKCAMPING
« Reply #8 on: Sat, 27 August 2022, 13:49:14 »
I bet it is closer to $100
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Sylanthra
« Reply #9 on: Sat, 03 September 2022, 19:01:33 »
Needs a way to detach the wires to handle large keycaps like spacebars.
Offline b.m.c
« Reply #10 on: Sun, 04 September 2022, 21:05:55 »
brilliant! I'm in
Offline Hentoys
« Reply #11 on: Wed, 07 September 2022, 00:41:35 »
Awesome I have been waiting for a higher quality Keycap puller
Offline TyPo.mk
« Reply #12 on: Wed, 07 September 2022, 10:45:33 »
Hard to decide how interested I am with no price estimate
Offline TypeBis
« Reply #13 on: Wed, 07 September 2022, 19:48:17 »
actually cool idea! hope it will be a decently priced keycap puller option. GLWIC!
Offline infinitum
  • i buy expensive plastic
« Reply #14 on: Thu, 08 September 2022, 10:41:04 »
nice. will cop if good price
Offline Friendship
« Reply #15 on: Mon, 10 October 2022, 17:38:49 »
Still interested in this :)
Has production finished up on this? Have I missed it?
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
