Author Topic: I definetly need to press all keys on my keyboards. Art installation.  (Read 5437 times)
Offline SFR75
Hello,
I had this art installation idea, where I can cover a certain area on the floor with cheap old USB keyboards put together to form sort of a rug.
When people walk over the keyboards I expected to detect the pressed keys and determine their position and shape of their feet (or bodies if they lie down).
That was all good, till I ran a simple test on my notebook and discovered the existence of n-key roll-over... which is obviously a very bad news for my project.
So now I'm trying to think of what options do I have left... and I don't see too many
Since I don't care about exact/precise keys being pressed, is it possible to hack/rewire keyboards to allow ghosting effect and remove KRO limitation ?
M
« Last Edit: Sun, 28 August 2022, 03:53:32 by SFR75 »
Re: I definetly need to press all keys on my keyboards.
« Reply #1 on: Sat, 27 August 2022, 20:23:17 »
It is not possible to convert a non-NKRO keyboard to have NKRO.
Although for this project you may not actually need full precision, and therefore not any ghost key avoidance, but the only way around that would be to replace the physical microcontroller hardware in the keyboard with a new one that is programmed differently. And those would need to be made different for each specific keyboard model.
That would be an involved hardware-hacking project. And IMHO if you're doing your own hardware, then you might just as well have a simpler solution from scratch anyway.
There are lots of ways to detect people on a floor: not just through buttons. For instance, you could use overhead cameras: or the opposite: translucent floor with cameras or simple light sensor from underneath.
« Last Edit: Sat, 27 August 2022, 20:25:09 by Findecanor »
Offline Sup
« Reply #2 on: Sat, 27 August 2022, 20:54:04 »
Why not just use a camera and a Python script??? Your idea seems way to simple that takes too much effort.
current
Coming soon
Offline Leslieann
« Reply #3 on: Sun, 28 August 2022, 03:03:47 »
Sure it is... Not pretty and a bit silly but it's doable.
Remove the PCB and just use a plate full of switches, hand wire them to a bunch of pro micros with firmware. Ugly, hacky and expensive, but it would work.
On the other hand, as you said, you don't really need N-key, feet are big, so just use a single pro micro and do several zones. Still a lot of work.
An easier Idea might be to use simple pressure sensors/switches or whatever under the keyboards wired up to a Pi or something.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline SFR75
« Reply #4 on: Sun, 28 August 2022, 03:37:16 »
Hello.
Thanks for your replies!
Indeed it's a PCB plate full of switches, as you correctly mentioned.
Ugly is not a problem, hacky either.. expensive probably more of a problem, but depends on the scale.
The biggest problem is that each keyboard has different wiring, so if I go this direction, I would need to find keyboard of same brand and probably model as well. Right ?
Yes, I thought about putting pressure sensor under the keyboards, but of course then my resolution drops ten-fold (1 key vs 101 keys!). The idea behind this installation was to determine the shape of feet and trace the steps of the person. Or for example somebody can lie down on the floor and I could then detect the shape of their body.
To answer comments above about cameras. Of course one can trace somebody with the camera, but it would be totally different experience. First of all feeling of "walking" over thousands of keys just by itself gives a particular experience. The sounds and the feeling. Plus I can't trace the footprints with same precision  with cameras. So yes, I can achieve "similar" effect, but definitely not the same sensation/experience.
This is an art project around "computer keyboards" after all and traces that we leave in digital world.
Any thoughts are welcome on how to solve this and I really appreciate your help.
M
Offline SFR75
« Reply #5 on: Sun, 28 August 2022, 03:40:53 »
Well, as I mentioned above I need to trace what happends on the surface and not in the volume.
I need to trace steps and body shape, if somebody sits or lies down.
In a way it should work like this pin-art toy
« Last Edit: Sun, 28 August 2022, 03:43:20 by SFR75 »
Offline SFR75
« Reply #6 on: Sun, 28 August 2022, 03:52:14 »
Thanks for your thoughts on this.
Well, this project is about physical detection. Or at least make believe the visitors that they are detected physically/mechanically. Stepping and walking over field of keyboards suppose to provide a particular experience, which I wanted to give to the visitors. When you sit down or lie down, you were supposed to see the video-projection on the wall in front, sort of a "keyboard viewer" that outlines your shape. So yes, it needs to be detected on surface level and that's why I can't achieve the same effect with cameras and I don't have translucent floor  :)) The field of light sensor is not a bad idea, btw... I like it!  :thumb:   but then there will be no keyboards anymore..
Now back to keyboard mods, yes.. I understand that replacing microcontroller is not easy task, but what makes it much worse is that each model/make is different. So it's pretty much impossible it seems.
Would it be possible to hack existing firmware at least for one brand (lets say Del)l rather than modifying it ?
Thanks much
M
Offline Sup
Re: I definetly need to press all keys on my keyboards. Art installation.
« Reply #7 on: Mon, 26 September 2022, 08:06:34 »
A bit late on this Topic but, i doubt a switch can survive that heavy load being pressed ontop of it.
current
Coming soon
Offline PlayBox
« Reply #8 on: Mon, 26 September 2022, 14:46:28 »
pen springs could help but not much
propably sent from my amazon kindle 10th gen
