Author Topic: [IC] LZ : bold F13 TKL  (Read 9790 times)
Offline LifeZ
  • LifeZone
« on: Wed, 31 August 2022, 01:42:21 »
Hi @everyone
LZ : bold F13 TKL
This is made in S.KOREA
290969-0
◎ proto type (unedited photo)
   https://imgur.com/a/GisGzFs
   https://imgur.com/a/j0oBoO8
◎ underglow leds moving
   https://imgur.com/ij9XMDU
   https://imgur.com/uIeIoAG
◎ Discord : https://discord.gg/JUYP5eFACy
[Layout]
F13 TKL, ANSI & ISO
Winkeyless & Winkey
290971-1
[Spec.]
◎ Aluminum Top case
◎ PC bottom case
◎ Aluminum weight
◎ 5 deg angled
◎ Switch plate (MX only) - Alu, PC, FR4
  ▷ Switch plate mount : Rubber mount Technology.
      ( https://imgur.com/a/zxG1iSU )
◎ PCB : Ghost T88 (1.6mm, USB-C, Daughter_B/D)
◆ Kit includes
  ▷ 1x Case (Top+Bottom with Alu Weight)
  ▷ 1x Switch plate
  ▷ 1x PCB
  ▷ 1x Daughter_B/D
  ▷ 1x Logo plate
  ▷ 1x Screws, Grommets, Bumpons
◇ Extra parts
  ▷ Switch plate : Alu, PC, FR4(White)
  ▷ PCB
  ▷ PCB Mount Cherry Stabilizer : Winkeyless or Winkey 1kit
[Color option]
◇ Case
  ▷ Silver
  ▷ Navy
  ▷ Gray
  ▷ Red
  ▷ Rose
  ▷ Gold
   ※ However, one-tone color is possible (may not match 100%)
◇ Switch plate
  ▷ Silver
  ▷ Black
  ▷ Red
  ▷ PC
  ▷ FR4(White)
   colors sample -> https://imgur.com/a/Hj3J143
[Price]
Keyboard Kit ~ $530 (still sourcing and negotiating)
« Last Edit: Wed, 31 August 2022, 01:45:46 by LifeZ »
LZ Limited
Offline Lysol_
Re: [IC] LZ : bold F13 TKL
« Reply #1 on: Wed, 31 August 2022, 01:54:34 »
surprised to see the initial price is lower than the REs TKL tbh.
« Last Edit: Wed, 31 August 2022, 01:57:57 by Lysol_ »
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Wed, 31 August 2022, 02:05:28 »
Does a screw go through the grommet (similar to burger top mount) in the plate or is it held in just by the top and bottom compressing?
Offline tngpq
« Reply #3 on: Wed, 31 August 2022, 02:10:16 »
No screw. The rubber grommets fit into the plate cutouts and inserted into the top housing pin. Then when assembled, the grommets compress between the top and bottom housings.
Offline Sissy
« Reply #4 on: Wed, 31 August 2022, 02:11:26 »
I miss the days of underglow and side glow on boards
Offline wigol2506
    • Instagram
« Reply #5 on: Wed, 31 August 2022, 02:12:23 »
Pictures suggest that there are ledges on the bottom case for the grommets to sit on
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #6 on: Wed, 31 August 2022, 02:40:32 »
could you take any worse pics
Offline Nonnegaard
« Reply #7 on: Wed, 31 August 2022, 05:26:26 »
if you've ever been in lz's discord you'd know they definitely can
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #8 on: Wed, 31 August 2022, 06:29:52 »
Honestly, this just looks plain fun! I think if you're going to diffuse RGB lighting this is one great way to do it! Good luck with the IC
« Reply #9 on: Wed, 31 August 2022, 10:47:01 »
sort of like frog tadpole? i'm intrigued at least
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #10 on: Wed, 31 August 2022, 13:43:39 »
This looks promising
Offline pixelpusher
« Reply #11 on: Wed, 31 August 2022, 15:32:21 »
Will take one in silver please.   :thumb:
Offline Riizmaa
« Reply #12 on: Wed, 31 August 2022, 20:56:38 »
SO GAMER I WANT TO SEE THIS IN NINJAS SETUP WHILE HE IS DESTROYING LITTLE KIDS ON FORTNITE  :p :p :p :p :p :p :p CRANKING 90s 420 BLAZE IT!!!!!!!!!!!!!
Offline tngpq
« Reply #13 on: Wed, 31 August 2022, 23:35:06 »
Not quite like tadpole. Tadpoles replace screws, literally, at least in the W1-AT. LZ's grommets are like rubber gaskets that prevent direct contact between the plate and housings. The pin is for alignment purpose only. At least that's what I felt after two LZ boards with this grommet system. Don't expect any soft typing feel. But they are enjoyable.
Offline Fraaaan
« Reply #14 on: Thu, 01 September 2022, 04:25:36 »
I wouldn't really compare grommet mount to tadpole mount but I also wouldn't call it top mount either. There's a big misconception that tadpole mount is just top mount but with tadpoles instead of screws. This is not correct. Tadpoles rest on the bottom case which means it's a form of isolated bottom mount.
The reason tadpoles go into the top case is for top-bottom case alignment and easy of assembly.
Offline tngpq
« Reply #15 on: Thu, 01 September 2022, 04:43:51 »
Yes, you are correct. Tadpoles rest on the bottom housing just like the LZ grommets do. It's been a while since I built the Frog..
Offline LifeZ
  • LifeZone
« Reply #16 on: Thu, 01 September 2022, 20:13:03 »
Don't be fooled by exaggerated photos. HAHA :p
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #17 on: Thu, 01 September 2022, 20:14:55 »
If the plate is attached to the top, it is a top mount, if it is attached to the bottom, it is a bottom mount.
If not, a sandwich?
LZ Limited
Offline NightFox99
« Reply #18 on: Sun, 02 October 2022, 14:26:50 »
Yes please
