Author Topic: [IC] PBTfans-Retro Dark Lights (New Renders | Production Completed soon)  (Read 21202 times)
Offline Jr.Mars
Production is nearing completion! Coming very soon!!
All the renders have been redone based on real pruducts!
Hi geekhacker,
I’d like to introduce you this new keyset: PBTfans-Retro Dark Lights
Different from MW-Retro Lights, the inspiration of Retro Dark Lights is Mac OS Dark mode.
The novelties comes from the window buttons in macOS.
Same as MW-Retro Lights, this set will be an in-stock set and will be sold through vendors early next year.
>>>> Interest Check Form <<<<
- Please help me to fill out this form and provide any feedback that you have.
◎ Inspiration
- The inspiration comes from the Dark Mode of MacOS, and the novelties comes from the window buttons in macOS.
◎ Kittings [Renders]
◎ Renders
◎ Metal Keycaps Manu by KBDfans
R1 1U x Stainless steel PVD (Black)
ANSI Enter x Alu Anodised (Black)
◎ Vendors
Worldwide: KBDfans
◎ Contact
◎ Information
☆ Manufacturer: PBTfans
☆ Material: PBT material
☆ Production Method: Doubleshot
☆ Profile: Cherry profile
※ Signature
Please consider adding this to your signature to support this set:
Code: [Select]
[url=https://geekhack.org/index.php?topic=118283.0][img]https://imgur.com/Le6xqQb.jpg[/img][/url]
« Last Edit: Mon, 13 February 2023, 00:16:55 by Jr.Mars »
Offline Jr.Mars
Re: [IC] PBTfans - Retro Dark Lights (IN-STOCK)
« Reply #1 on: Tue, 06 September 2022, 02:12:30 »
◎ Changelog
1. Add couple of metal keycaps (ESC and Ansi Enter)
2. Separate the metal ansi enter from base+nov kit.
3. Add a base kit without novelties and a novelties kit separately, give you more choice :thumb:
4. Remove the red dots ansi enter novelty.
5. New renders.
« Last Edit: Sat, 08 October 2022, 09:14:31 by ElvisXSS »
Offline aliden
« Reply #2 on: Tue, 06 September 2022, 08:58:26 »
Cool set! Do you mind giving us what RAL / Pantone colour you used?
Offline MSA_Vision
« Reply #3 on: Tue, 06 September 2022, 10:27:58 »
Cool set, glwic
Sic Parvis Magna
Offline zhol
  • zhol
« Reply #4 on: Tue, 06 September 2022, 17:30:42 »
blue alice B in base kit would be fun
« Last Edit: Tue, 06 September 2022, 17:53:35 by zhol »
i'm zhol
Offline santela
« Reply #5 on: Thu, 08 September 2022, 22:48:49 »
Definitely in. Love PBTfans stuff and I'm sucker for dark sets. Spacebar set seems to have some redundant keys though.
Offline Jr.Mars
Re: [IC] PBTfans-Retro Dark Lights (New kittings and 2 Metal Keycaps)
« Reply #6 on: Sat, 08 October 2022, 09:13:21 »
◎ Changelog
5. New renders.
Offline santela
« Reply #7 on: Tue, 18 October 2022, 23:51:03 »
Did the spacebar set get removed?
Offline NihonCK
« Reply #8 on: Wed, 19 October 2022, 14:40:53 »
you have to expand the post, its with the international/numpad/40's section
Offline arr1
  • Ñ supporter
« Reply #9 on: Thu, 27 October 2022, 15:42:01 »
Really cool and original. Looking forward to knowing the set’s evolution
Offline lonewolf4
« Reply #10 on: Thu, 03 November 2022, 12:27:51 »
Relegendables for all rows and I'm in
Offline guill3m
  • Shut up and take my money
« Reply #11 on: Sun, 06 November 2022, 13:11:50 »
For proper Mac compat on the RGBY kits you need to:
  • Make the Command/Cmd keys yellow, or
  • Add yellow Option/Alt keys
As it is now you'd be using Red Command with Red Alt.
Alternatively: just remove the Command keys from those kits, one can just use Super instead of Command. Same for the base kit. R3 Command is not a thing.
Not sure about the Green Fn keys. The 1u being next to the Shift, fine. But the 1.25u Fn doesn't make much sense to be Green. Either remove or use a different color.
Offline Cawfee
« Reply #12 on: Mon, 07 November 2022, 17:26:32 »
I think this is a pretty clean set, love the subtle hint of colors here and there in the kits, but imo there should be another blue B key to use with Alice boards imo, spacebar kit having 2 3u keys is interesting, but overall I really like the set and GLWIC!
Offline airs
« Reply #13 on: Wed, 09 November 2022, 16:20:44 »
Such a great set, can't wait for this!
Octagon v2, LZ CLS
Offline XiXora
« Reply #14 on: Thu, 10 November 2022, 11:22:35 »
I will echo guill3m, need yellow alt/option keys to compliment the red command keys. I'm good with the green fn though.
I wish PBTfans had stepped control R3 mould though.
Offline dcsenjoyer
« Reply #15 on: Wed, 04 January 2023, 21:55:56 »
n9 alpha base / cr modi base colors?
Offline Jr.Mars
Re: [IC] PBTfans-Retro Dark Lights (New Renders | IN-STOCK GB soon)
« Reply #16 on: Sun, 12 February 2023, 23:29:15 »
Coming very soon!
« Last Edit: Mon, 13 February 2023, 00:17:32 by Jr.Mars »
Offline Nukz
  • ig: nukzak
Re: [IC] PBTfans-Retro Dark Lights (New Renders | Production Completed soon)
« Reply #17 on: Mon, 13 February 2023, 03:49:00 »
love the colorway, gl
