Author Topic: [IC] Moesode Ode 60% Keyboard  (Read 9551 times)
Offline elli
« on: Mon, 26 September 2022, 11:39:24 »
Hey, elli from Moesode. Ode is meant to be a reimagination of the OTD Mini.
When I first started on this over a year ago I wanted to recreate the look and feel of the Mini.
This board's mounting is a gummy worm o-ring gasket mount, and uses a 1.2mm CEM3 PCB with flexcuts.
With the combination of mounting, PCB, and plate choice you will be in for a nice typing experience.
A full plate gives a very even feel across the whole board, while with a half plate will having the alphas feel very bouncy.
Minimum order quantity is 100 boards.
Want to know whether or not people are interested in this board, want to know if people would be interested in a WKL top possibly.
Also if any other plate materials I should offer. My only concern is plastic plates will probably require you to have shelf liner under the PCB.
IC Form: https://forms.gle/uLzDDCctXu6Mav718
Sound Tests:
  • Cherry MX Blacks (Hyperglides filmed and lubed w/ GHv4)
  • OG Cherry Doubleshots
  • Full Plate
  • CRP Tulip
  • Half Plate
Specifications:
  • Colors Available: Red, Black, or Silver
  • 8 Degree Typing Angle
  • 18mm Front Height, 33.35mm Back Height
  • ~1.25kg Unbuilt, ~1.5kg Built
  • O-ring Gasket Mount (AS568-263, 50a Durometer)
  • Full / Half Red Aluminum Plate
  • 1.2mm CEM3 PCB (Flex Cuts, USB C, QMK/VIA Compat)
Layout:
  • Full or Split Backspace
  • Stepped or Unstepped Caps
  • Full or Split Right Shift
  • ANSI / Tsangan Bottom Row
Target Pricing:
  • Base Price ~375$
  • Extra Plates ~35$
  • Extra PCBs ~35$
Contents:
  • Ode Case
  • Brass Weight (Uncoated Brass)
  • 1 * Plate (Full/Half)
  • 1 * PCB (1.2mm, CEM3, QMK/VIA, USB C)
  • 1 * O-ring (AS568-263, 50a Durometer)
  • Bumpons (3M SJ5302)
  • Extra Screws (Black Oxide)
Renders:
Feel free to join the Moesode Discord for future updates https://discord.com/invite/3jKPs6g
« Last Edit: Mon, 26 September 2022, 11:58:08 by elli »
Offline rookb
Re: [IC] Moesode Ode 60% Keyboard
« Reply #1 on: Mon, 26 September 2022, 11:47:27 »
Seems a little expensive, how much does the board weigh when fully built and unbuilt? Can we see some pictures of the internals? Also your renders of the board don't have a seam.
GLWIC
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Mon, 26 September 2022, 11:51:19 »
While the plate may look different from the 356mini's, I think the overall external look (bezels, proportions, etc) is just too close to it.
Offline The0rigina1
  • fumoposting
« Reply #3 on: Mon, 26 September 2022, 11:55:56 »
is this not just a clone?
are you making a copy cat?
Offline niicao
« Reply #4 on: Mon, 26 September 2022, 12:00:16 »
Aside from the CEM3 1.2mm PCB, i don't see any reason to join your GB when i can get a UTD 356mini and receive it next week with the same design, same mounting style
Offline yuuyashun_
« Reply #5 on: Mon, 26 September 2022, 12:02:39 »
isn't utd has been doing this for years with half of this price
Offline elli
« Reply #6 on: Mon, 26 September 2022, 12:08:33 »
Yeah I agree it definitely is close. This was the third prototype I did for a 60% and it was the best internally, but from the sounds of things a case redesign should be in the works.
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #7 on: Mon, 26 September 2022, 13:11:21 »
I love the idea of designing a board with the intent of paying homage to the original. However, I would love for it to be different aesthetically, but with similar mounting as you have there. Would love to see some funky aesthetics with some OTD design queues, rather than the board being pretty much the same as the original, but with some stuff here and there tweaked. Either way glwic
Offline zekth
« Reply #8 on: Mon, 26 September 2022, 13:21:23 »
Consider adding ISO support as Mechlovin did few month ago for the UTD release
Offline treeleaf64
    • treeleaf64
« Reply #9 on: Mon, 26 September 2022, 13:27:14 »
Check my levels
Levels is good
Everyone must pay the cat tax
Offline elli
« Reply #10 on: Mon, 26 September 2022, 15:04:11 »
Noted.
Yeah I have a few ideas looking back at some of my other prototypes I was working on. Will probably also do something different for the weight. But yeah the internals are what really make the board.
Offline roostrc0gburn
  • its just plastic
« Reply #11 on: Mon, 26 September 2022, 15:14:53 »
send in the CLONES! also, I would like to see other plate materials pls
Offline Nuap
« Reply #12 on: Mon, 26 September 2022, 17:00:36 »
How about offering HHKB and WKL tops?
Offline atkins
« Reply #13 on: Tue, 27 September 2022, 02:09:03 »
Hey its a clone, but with a different weight. So its a "reimagination".
Offline selsik
« Reply #14 on: Tue, 27 September 2022, 16:53:55 »
looks boring and uninspired, far too many boards attempting the same formula, and it's not like this brings anything new to the table
alu with weight and oring mount, no WKL/HHKB (and if you were to add hhkb i'm 99% sure it'd be with 7U spacebar anyway), typing angle is too high (why is literally every board on ic/gb 6 degrees or higher these days?), design is basically a tofu, back side is full of holes which is definitely not my cup of tea... almost 400 buckaroos for this?
consider me not interested, at all
Topre >>> MX
Offline gilbert
« Reply #15 on: Thu, 29 September 2022, 14:46:59 »
glwic
Offline Cookiecurls
« Reply #16 on: Fri, 30 September 2022, 09:08:38 »
In my opinion I would hope changing the external design doesn’t impact the sound, because it sounds amazing right now and actually somewhat close to a real 356 mini which is not something I can say for any UTD I’ve heard. For me sound is the most important and I would prefer that a clone prioritize sounding like the original.
Offline Its_Ash
« Reply #17 on: Sat, 01 October 2022, 03:40:57 »
Yep
« Reply #18 on: Sat, 01 October 2022, 12:40:33 »
Don't you own multiple Irons?
Offline Ensaum
« Reply #19 on: Sat, 01 October 2022, 14:13:17 »
I really like the idea of this board. If you want to add some flair to it, I think that a cherry style front chamfer and a Keycult No. 2 style rear fillet would look really nice. Maybe make the top and bottom bezels just slightly bigger?
I have been looking for a simple 2 piece o-ring board for a while though, so I am very interested in this.
« Last Edit: Sat, 01 October 2022, 14:16:04 by Ensaum »
