Author Topic: [GB] Series 6xx | Starting October 2nd  (Read 12257 times)
Offline paulgali
    • SKME
« on: Sat, 01 October 2022, 10:45:24 »
Series 6.xx is here!
GB Confirmed to start on October 2nd, available at SandKeys.ME
This is something I am very proud of. I hope you like it as much as my cat wants to steal it!
6xx GB will go live on Sunday October 2nd, 6pm UAE Time for 1 week (last day October 9th)
FCFS. MOQ & capped @ 150 units. ETA Q1-2 2023
Price: $420
Shipping: DHL Express with a fixed cost of $35 [read after this] for international sales. Fuel surcharges are currently higher and DHL have told us next month will be closer to 40. We will fix the price based on Septembers fuel surcharges..
Vendors: Sandkeys only. So the process can be sped up 🙂
Timeline: 4 months production timeline, lets say 6ish months including QC
----Base Kit includes----
Top WK, WKL - A6063
Bottom  - A6063
Internal Brass Sheet
External brass weight
Alu plate - A5052. Colormatch with case unless stated otherwise
1.2mm PCB  + JST + AI03 C3 DB
Orings & mounting hardware
Each unit ships with hard cases, and a plain cardboard box around it. Recycle that box, I'm not wasting your GB money on fancy packaging.
----Optional Extras----
1.6mm pcbs, 1.2mm PCB
Plates - A5052, black ABS MX, Alps Alu plates
Internal sheet addons - i will give you access to the file instead to cut / 3d print your own.
Specs
  • 6 degree, 60% with xt column
  • Adjusted front height of 19.1mm (see below)
  • 7.8mm plate to top case clearance
  • WK and WKL options available
  • MX + Alps compat (with mx stabs)
  • Stock Alu 5052 plate with 1.2mm pcbs
  • 1.6mm pcbs with ABS plates available, as well as addon ALPS Alu plates
  • Internal brass weight/sheet. This is interchangeable with PC bottoms - reasoning below
  • GB edition will have clear coated brass external weight
  • Top mount standard, with optional gummy mount included. Uses 190x4mm orings
  • 1433g with current build (photo below)
No foam. With this much surface area covered in brass, its not needed.
Anodization options
  • Red (current proto)
  • Navy
  • Green
  • Silver
  • Purple
  • Pink
Measured without feet as I am changing the feet being used. Measured from the inside edge of top case to external case floor.
PCB Support
Each unit comes with the necessary C3 Unified daughterboard + 150mm medusa cable.
There are SMD LEDs on caps lock, and the 2 top left keys (acting as layer indicators)
Prototype images
This unit came with some particularly poor anodization - something I am working on to improve. Note - I take horrible photos  :p
GMK Red Devils
Sides - i love corsa sides, but wanted something with a much "softer" aesthetic.
Back (yikes it was a sunny day)
Internal brass weight - can't take a photo right now, heres a screenshot from a previous build stream. Yeah, that's covering a large surface area.
The gap is present on the divider between the XT columns and main alpha/mod cluster, to affect sound as little as possible.
Note the USB port is also aligned along this divider.
Soundtests
I'll post some more when I sit down to record a few. Remember, soundtests are a meme  :thumb:
DCS WOB, Jwicks and Alu Plate in Gummy
Gummy Mounted SP Stars, 1.2mm pcb + alu plate, GMK Metropolis
Credits
Maelk - the phenomenal PCB work. Highly recommend!
The MENA community - always have my back
Boyos - you know who you are, thank you for the constant encouragement
Discord
Don't let memes be dreams
« Last Edit: Thu, 06 October 2022, 14:21:31 by paulgali »
Offline paulgali
    • SKME
Re: [GB] Series 6xx | Starting October 2nd
« Reply #1 on: Sat, 01 October 2022, 10:47:03 »
Reserved
Offline of_sam
« Reply #2 on: Sat, 01 October 2022, 10:59:20 »
buddy....
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Alessio
    • YT Channel
« Reply #3 on: Sat, 01 October 2022, 10:59:31 »
SIUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
Offline Fnzzy
« Reply #4 on: Sat, 01 October 2022, 11:00:36 »
GL
Offline akira7
  • akirabutter
    • akiratypes
« Reply #5 on: Sat, 01 October 2022, 11:01:25 »
raiding my savings for this, gl paul <3
Offline nostr
« Reply #6 on: Sat, 01 October 2022, 11:01:51 »
Lets gooo. Soo hyped
Offline BlivionIaG
« Reply #7 on: Sat, 01 October 2022, 11:02:44 »
I am quite thrilled for it, saw some tests and it also look sick, can't wait <3
Offline ankit
  • Formerly ankit-sachdeva
« Reply #8 on: Sat, 01 October 2022, 11:03:07 »
glwgb baul! you're the best! :p :thumb:
Offline ryoh
« Reply #9 on: Sat, 01 October 2022, 11:03:39 »
nice board, GL paul <3
Offline LMarci
« Reply #10 on: Sat, 01 October 2022, 11:03:44 »
Great keyboard by a great designer :thumb:
Offline mundhra
« Reply #11 on: Sat, 01 October 2022, 11:11:23 »
what a cutie!
board's nice, too.
Offline whirlwind
« Reply #12 on: Sat, 01 October 2022, 11:11:54 »
Buddy so lit :D
Offline beelzking
« Reply #13 on: Sat, 01 October 2022, 11:13:24 »
HAPPY THOCCING, good luck with the GB!  :thumb:
Offline MK47
  • Don't talk to me
« Reply #14 on: Sat, 01 October 2022, 11:15:42 »
Good luck with the GB, buddy.  :thumb:
Offline clik_clak
« Reply #15 on: Sat, 01 October 2022, 11:16:55 »
If this had a pen rail, it'd be perfect.
GLWGB
Offline ej6
« Reply #16 on: Sat, 01 October 2022, 11:18:51 »
Hot stuff!
Instagram: Azi Keycaps | ej6.kb
Offline TjarleN
« Reply #17 on: Sat, 01 October 2022, 11:20:00 »
are you making a copycat
<3
Offline kyuut
  • i just learned a new dance
« Reply #18 on: Sat, 01 October 2022, 13:07:00 »
having had the chance to own one of the prototypes i gotta say this board was a great surprise in terms of feel and aesthetics, while also sounding nice.
anyone looking for a 60XT should be going for this. best of luck with the GB paul :thumb:
TGR Jane v2 | TGR Jane v2 CE | TGR x SINGAKBD Unikorn 2.2 | SINGAKBD Kohaku R2 Prototype | HHKB Professional 2
Offline mrvpixel
« Reply #19 on: Sat, 01 October 2022, 13:50:27 »
So in for this
Offline el_lento
« Reply #20 on: Sat, 01 October 2022, 15:28:19 »
Lovely board
Offline Thebloodyez
  • Just a random keyboard builder.
« Reply #21 on: Sun, 02 October 2022, 10:46:42 »
Such a nice rectangle! :thumb:
« Reply #22 on: Sun, 02 October 2022, 12:17:48 »
pog
Offline 4milk
« Reply #23 on: Sun, 02 October 2022, 22:40:11 »
Very nice
Offline Phractals
« Reply #24 on: Sun, 09 October 2022, 09:36:46 »
I would buy this if I had the money right now, 6xx very lit
Offline brayderlee
« Reply #25 on: Thu, 03 November 2022, 03:41:42 »
What a lovely rectangle!
Offline xebecglory
« Reply #26 on: Tue, 06 December 2022, 11:20:42 »
That's awesome
Offline phaxin
« Reply #27 on: Mon, 16 January 2023, 17:07:01 »
Very cool, will pick up an extra!  :thumb:
Offline Seunghyun Lee
« Reply #28 on: Tue, 17 January 2023, 07:48:37 »
waiting extras...
