Author Topic: Best keyboard for working in a secure area.  (Read 5431 times)
Offline BareSphereMass
« on: Wed, 19 October 2022, 19:03:47 »
I got a job as a software engineer for a defense contractor and I work in a secure room.
This means I can't use any of my custom keyboards. I am currently using a $10 HP keyboard.  The switches are bad, but the normal 104 key layout with no layers is torture.
I am looking for a keyboard that:
- Is NOT programmable (no QMK, no VIA, no custom software)
- Does not need special firmware
- No Wifi / Bluetooth
- No ability to record anything
I would like:
- Split spacebar (Left: backspace, Right: space)
- IJKL arrow keys on a 2nd layer
Everything else is negotiable.
The IT people said that I can use a HHKB pro classic, but I hate how they do the arrow keys, and I want a split space bar.
I can't find anything that has a split space bar and is not programmable, so here I am.
Any recommendations?
« Last Edit: Wed, 19 October 2022, 19:33:03 by BareSphereMass »
Current Keebs:  Atreus 42 (hand wired)  |  Anne Pro 2  |  Prime_E  |  Prime_Meridian
Next Keebs:  Polycarbonate Alice  |  Type-K  |  Wood Case Keeb
Current Keycaps:  OEM (POM & PBT)  |  SA R3 (PBT)  |  DSA (PBT)  |  MT3 Camillo  |  GMK Apollo  |  Deskr Canyon Caps  |  MT3 LotR Elvish  |  GMK Civilizations
Current Artisans:  Dwarf Factory Artisans (2x)  |  Rama x Keycult Brass (1x)  |  Holyoops D.VA Aluminum (cherry R4)  |  Walnut OEM R4  |  3D Printed Pikachu
On Order:   GMK Pharaoh (est. April 2024)
Other:   ZealPC Clickiez
Offline Leslieann
Re: Best keyboard for working in a secure area.
« Reply #1 on: Wed, 19 October 2022, 20:50:26 »
You're pretty much only going to get split spacebar on a custom.
Vortex has the Core (40%?) Cypher (60%), and Mistel offers the MD650L, a splitable 65%.
I doubt any of these use open source firmware but you probably won't find many more.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Wed, 19 October 2022, 21:22:31 »
If you are willing and patient enough (and willing to live with other pre-millennium oddities) to track down an NMB "Right-Touch" it has great switches and a split space bar.
- D Trump 2026-10-24
Offline lakeboredom
« Reply #3 on: Tue, 25 October 2022, 22:29:59 »
What does split-space actually do if you can't program it... Is this a comedy post? Do you simply want two buttons for spacebar? Lol
« Last Edit: Tue, 25 October 2022, 22:35:05 by lakeboredom »
« Reply #4 on: Wed, 26 October 2022, 19:02:45 »
Some keyboards have alternate layouts.  The best example is the HHKB that has layered arrow keys and the back space in an alternate location.  I was hoping the collective mind of the internet would find a keyboard that had split space bars for backspace and space, or IJKL arrow keys, already baked in, but I'm not too hopeful at this point.
Offline Nuap
« Reply #5 on: Wed, 26 October 2022, 19:08:45 »
Just get a HHKB Pro Classic and call it a day...
Offline lakeboredom
« Reply #6 on: Wed, 26 October 2022, 19:40:25 »
Yeah split space isn't a thing rlly. Vortex Cypher might be your only decent option. I think the newer vortex boards have better options for customizing layouts tho. They have onboard programming, that might fit your bill.
Sent from my moto g power (2022) using Tapatalk
