Author Topic: [GB] Theca x Rubrehose | updated 24/12/22  (Read 15187 times)
Offline densus designs
  • * St. Jude Supporter
« on: Mon, 07 November 2022, 05:42:47 »
Theca x Rubrehose by Densus Design & KLC
Updates As of 24/12/22
1. Case
- Raw materials are instock and started to prepare mass production
2. Carrying Case
- Prototype confirmed and tooling fixed.
- All orders are made. It will take 2~3 month.
3. PCB
- Final Prototype PCB have been ordered and will take 2 weeks to get the prototype.
- Once prototype pcb’s are confirmed, mass production will start.
4. Gaskets have been ordered
5. Cleaning Cloth
- Prototype on the way.
6. Wrist Rest
- Prototype ordered. Will take 1 month for the prototype.
7. Topre Kits
- Toolings in progress.
- Looking forward to get the prototype in Jan. 2023.
KLC Store (international)
Cafege (Australia only)
More Pictures
Pics taken by jtqx#8261, @joshkeyboards on instagram
My Discord My Instagram
KLC's Discord KLC's Instagram
Board Features:
- F12 WKL or WK TKL layout with ANSI and ISO Support
- 18mm front height without feet
- 2.8KG Built
- Custom Silicone Gasket Mount or Top Mount
- 8-degree typing angle
- “Seamless” Sides
- Recessed USB-C port parallel to your desk
- Internal Brass Weight
- External Silver coloured brass or Brass Weight
- MX or Topre PCB
Final GB Information:
Theca GB will start on November 16th and be open for two weeks, closing on the 30th. GB may close early if soft cap is met.
Please note that the EC Kit and EC Bundle will go for sale in Q1 2023, you will be able to bundle them with your current Theca order!
Current ETA is Q2 2023, please keep in mind that there can be delays.
Mounting:
V1 Gaskets Left, V2 Gaskets Right. Only 20A in Black (matte) for final production.
Theca can be mounted in two ways: Top Mount or Gasket Mount.
Unlike most other gasket mounted boards, Theca utilises custom injection moulded silicone gaskets to achieve a smooth and flexible typing experience, accompanied by the recessed areas on the bottom case for increased flex.
After manufacturing and testing prototypes using different gasket thicknesses, I am extremely satisfied with the resulting typing feel and flex. Gaskets will be available in only 1 hardness: 20A Durometer (Black). Due to the lack of adhesive between the gaskets and plate/case, harnesses can be seamlessly installed and swapped without frustration or clean-up.
As well as this, Theca can also be mounted to the top case using 8 screws for a more classic typing feel.
Topre Addon Kit:
For Theca, we will be offering an addon kit for topre compatible parts, this kit will include PCB, plate and screws. Designed by the Talented Cipulot, this pcb allows for multi-layout options including 7u & 6.25u bottom rows along with stepped and regular capslock. Above are some pictures of the PCB with artwork by Rubrehose!
Internals:
Theca's Internals have been updated since the initial prototype, this will provide a cleaner look and should give a more even sound.
Please note that all brass weights will be clear-coated.
Included Carry Case:
This premium carry case included with Theca has been designed to make it easy to place and pick up boards with wide side openings for hands. This bag uses two custom moulded eva parts to hold Theca while also separating extra parts such as plates, PCBs and extra gaskets. Sponge foam has been adhered to the top of the case to prevent damage during shipping and daily use.
Colours Available:
Black Ano, Brown Ano (same as rotor) & Beige (E-coating)
PCB & Layouts
- Winkeyless or Winkey
- ANSI and ISO Support
- Regular and Split Backspace Support
- Regular and Split Left and Right Shift Support
- Regular and Stepped Caps Support
- 6.25u & 7u bottom row options
Build Stream(s) and Typing Tests
Xanniard - DONE
Ruminative- DONE
GymLeaderNathann - DONE
XinXinWong- DONE
Georen-  DONE
StarFirePenguin- DONE
TimKeyLess- DONE
WarmThoughts- DONE
Enomooshiki- DONE
Lighting keyboards- DONE
« Last Edit: Sat, 24 December 2022, 04:06:11 by densus designs »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Theca x Rubrehose | GB November 16th until 30th, MX and Topre PCBs
« Reply #1 on: Mon, 07 November 2022, 08:21:03 »
Need ETA for fullfillment and production to be able to approve. Get back to me via PM when done!
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Mon, 07 November 2022, 10:22:37 »
Approved, Gl w GB
Offline whirlwind
« Reply #3 on: Mon, 07 November 2022, 10:31:23 »
Wow! What a nice keyboard! GLWGB!  :eek:
Offline clik_clak
« Reply #4 on: Mon, 07 November 2022, 10:41:26 »
Very cool board. The EC option has me interested.
Are there going to be unique artisans available to people that buy the board?
Offline Unlucky
« Reply #5 on: Mon, 07 November 2022, 11:05:01 »
WowBuddy
Offline Eftynio
Re: [GB] Theca x Rubrehose | GB November 16th until 30th, MX and EC PCBs
« Reply #6 on: Mon, 07 November 2022, 12:08:46 »
That is one sick looking weight  :cool: GLWGB!!
Offline ankit
  • Formerly ankit-sachdeva
« Reply #7 on: Mon, 07 November 2022, 13:29:22 »
GLWGB  :thumb:
Offline puggo69
« Reply #8 on: Mon, 07 November 2022, 13:35:43 »
i like the board glwgb  :-*
Offline The_judge_168
« Reply #9 on: Tue, 08 November 2022, 16:37:24 »
Board looks great! Looking forward to seeing the EC version
Offline ketuso
  • Ketsuo!
« Reply #10 on: Wed, 09 November 2022, 07:55:58 »
Can't wait to get this!
Offline Plurrkeebs
« Reply #11 on: Wed, 09 November 2022, 19:07:48 »
Can't wait for this. Going to go toper in this fosho.
Offline nostr
« Reply #12 on: Sun, 13 November 2022, 04:45:31 »
WowBuddy
Re: [GB] Theca x Rubrehose | GB starts in two days!!! MX and EC PCBs
« Reply #13 on: Mon, 14 November 2022, 04:16:36 »
16th November 2pm korea time
Re: [GB] Theca x Rubrehose | GB tomorrow!!! MX and EC PCBs
« Reply #14 on: Tue, 15 November 2022, 01:15:07 »
Group buy starts tomorrow!
Seen here with the built topre proto, sound test will be posted tonight
« Reply #15 on: Wed, 16 November 2022, 00:47:41 »
Group buy is now live, for addons and extras please head to the main page to add them and checkout together!
Offline neojonathan
Re: [GB] Theca x Rubrehose | GB LIVE NOW!! MX and EC PCBs
« Reply #16 on: Wed, 16 November 2022, 19:09:38 »
How do we know if we had added a topre pcb or not?
« Reply #17 on: Wed, 16 November 2022, 23:18:58 »
You can’t, it now goes on sale Q1 2023 along with the EC bundle
« Reply #18 on: Thu, 17 November 2022, 23:41:24 »
Update bump
Offline CONIN
Re: [GB] Theca x Rubrehose | GB live now! MX and EC PCBs, Don’t miss it
« Reply #19 on: Mon, 21 November 2022, 16:37:38 »
Seems like I've found my next TKL and would even consider placing my order today, but I have a small question regarding the available PCBs: their listing (in the store's link) shows four images that are exactly the same (these), while at the right I can choose from three options: "Soldered", "Hotswap WinKey" and "Hotswap WinKeyLess", now, I'm might be a little bit confused since English is not my language, but I would like to know if both the Soldered and the Hotswap WinKeyLess PCBs support Tsangan layout: split Backspace and split Right Shift. Thanks a lot in advance for your time and attention!
Offline daeyul
« Reply #20 on: Tue, 22 November 2022, 00:10:59 »
Where can I find the Topre soundtest??
« Reply #21 on: Tue, 22 November 2022, 01:51:31 »
My discord
« Reply #22 on: Fri, 25 November 2022, 01:11:20 »
Slightly more than halfway through GB. Don’t miss it!
Group buy ends on November 30th
Re: [GB] Theca x Rubrehose | GB Closed, Updates Soon
« Reply #23 on: Sat, 24 December 2022, 04:05:11 »
Theca x Rubrehose Update
1. Case
2. Carrying Case
3. PCB
5. Cleaning Cloth
6. Wrist Rest
7. Topre Kits
