Author Topic: What causes unreliable keypress? [DIY keyboards are like gambling]  (Read 8632 times)
Offline vatin
« on: Sun, 13 November 2022, 22:15:24 »
I build myself a Corne keyboard with hotswap support as per the build instruction.
But one switch produce unreliable keypresses. Sometimes it act normally, sometimes I need to mash real hard for it to produce a key, sometimes it register double keypresses either from mashing or even light touch.
If I replace with new keyswitch, that switch will be dead for a day or two. I need to disconnect and leave it, then it will come back but works unreliable still.
What is causing this. I'm getting so tired. I want stuff to work. I don't want typos..... This is not a cheap 2 dollars keyboard. This is ergo split keyboard that suppose to save my career. Not causing more frustration.
[Update] I tried reflow and add some more soldier to the problematic hot swap socket. It worked fine for a while. And now it's dead. No amount of mashing will produce a keypress. And I don't want to replace the hot swap socket since I don't know how to desolder. And even if I do, it is a risk overheating and melting the solder pad altogether. The only place this keyboard belongs is the trash.
« Last Edit: Sun, 20 November 2022, 07:53:44 by vatin »
HHKB Professional Classic
Offline pixelpusher
Offline vatin
Re: What causes unreliable keypress?
« Reply #2 on: Wed, 16 November 2022, 00:16:06 »
Sometimes when I mashed the affected button, it produces not double, but 3 characters in a row. Let's see if I could make it 4 or more. Let's set some record with this baby, so every working day is a challenge. I also need to put some kind of meter under it to measure the force required to make it register.
Offline thocciness
« Reply #3 on: Thu, 17 November 2022, 10:06:08 »
It sounds like the the switch isn't making a complete circuit so from my experience it could be a loose Hotswap pin.
Offline vatin
Re: [Solved] What causes unreliable keypress?
« Reply #4 on: Sun, 20 November 2022, 04:19:49 »
« Last Edit: Sun, 20 November 2022, 07:54:16 by vatin »
Offline Leslieann
Re: What causes unreliable keypress? [DIY keyboards are like gambling]
« Reply #5 on: Mon, 21 November 2022, 00:25:26 »
Is this board using a daughter board for the controller, I.E. a Pro micro that snaps in or soldered in?
You may be looking at the wrong end of the path, every time you fiddle with it it re-seats and you think it's a switch that's the problem.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline fortissim2
« Reply #6 on: Tue, 22 November 2022, 09:28:22 »
I've had the same issue with my Corne INB4. Try re-flowing the solder on the diode, and if that doesn't work, just replace it.
Offline vatin
« Reply #7 on: Sun, 27 November 2022, 04:59:06 »
I tried reflow and even add more soldier and that doesn't work so I just trashed the entire board. I don't know how to desolder cause it looked already messed up. I just ordered the painter keyboard (Diodeless Corne).
