Author Topic: any "floating" keyboard shells recommendation?  (Read 3843 times)
Offline barooca
« on: Sun, 20 November 2022, 04:03:40 »
i really like floating keyboards (aka corsair k70-like) and recently getting into custom boards.
currently im using a cheap chinese board called irok fe87, this is a quite unique board cuz you can remove the frame and make it a "floating" board. the issue is that, it's not a very good looking board, with ugly indicators and exposed screws. the chassis is not big enough for sound dampening as well.
pic: imgur.com/a/iQrZrpg
switches: gateron yellow, keycaps: unknown pbt (same height, i dont like the shape)
(sorry for dust, havent touch it for a week)
i want something can house a generic hot swappable pcb (87/104/108, i dont like smaller layouts), with floating surface, has room for sound dampening. most importantly not too expensive, over 100usd is no-go for me. thx in advance
Offline PlayBox
Re: any "floating" keyboard shells recommendation?
« Reply #1 on: Sun, 20 November 2022, 12:27:59 »
you gonna learn that floating keys aren't popular or liked in here. you either gonna have to get a high profile keyboard or just get a mid cheapo board like tecware phantom 87 (though the only person saying its good has invalid opinions). so if you want anything good you would have to get a tall keyboard
propably sent from my amazon kindle 10th gen
Offline barooca
« Reply #2 on: Sun, 20 November 2022, 16:01:37 »
thx that board looks quite smart and seems like a quality product, shame its not available in my region
Offline Leslieann
« Reply #3 on: Mon, 21 November 2022, 00:28:50 »
Most lower end use low profile because it's cheap, one less part to make.
Most users prefer taller because it's usually a better board plus it keeps the led's from shining right in your eyes.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
