Author Topic: [IC] Fira Code Keycap Set - Unmarked Design(Updated Mar 9)  (Read 22731 times)
Offline Unmarked Design
« on: Sun, 04 December 2022, 08:35:53 »
293943-0
Hello, everyone. This is Unmarked Design. We are going to present our first keycap design - Fira Code.
This design is based on the famous opensource font Fira Code, https://github.com/tonsky/FiraCode
Here is the kit details:
Dark Theme
293945-1
293947-2
293949-3
293951-4
293953-5
293955-6
293957-7
293959-8
293962-9
293965-10
Light Theme
293967-11
293969-12
293971-13
293973-14
293975-15
293977-16
293979-17
293981-18
293983-19
293985-20
March 9:
So sorry that some progress haven't been updated for a while. We asked EPBT for sample before and they responded really quick. The sample turns out good. But we heard that folks do worry about EPBT so we haven't decided the final manufacturer yet. And it's true that they can't confirm schedule. We didn't give the groupbuy info to KBD too. That's a mistake that KBD launched the fira code groupbuy info themselves.
We are still looking for the manufacturer. Hope we can update the manufacturer and vendors soon.
« Last Edit: Wed, 08 March 2023, 22:03:24 by Unmarked Design »
Offline conternecticus
Re: [IC] Fira Code Keycap Set - Unmarked Design
« Reply #1 on: Sun, 04 December 2022, 08:38:34 »
Please work on your pictures formatting
Who is the manufacturer?
Offline Ella
  • Why is it called an oven
« Reply #2 on: Sun, 04 December 2022, 10:18:44 »
who da manu dawg???
Offline craftbondpro
« Reply #3 on: Sun, 04 December 2022, 11:26:48 »
This is kinda hot.
Offline aicyborg
« Reply #4 on: Sun, 04 December 2022, 23:27:36 »
Why does the base kit have the ISO-UK specific keys ~# and @' but not the 2" and 3£? If you're going to give us ISO-UK in base - which you should - please give us all of it. Otherwise put those two in the international kit - which you shouldn't, imo.
Offline AshF
« Reply #5 on: Mon, 05 December 2022, 01:23:33 »
Love the design of this set, great work.
Please clarify on the UK ISO point, put in base fully or move it to international.
Sent from my ASUS_I003D using Tapatalk
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #6 on: Mon, 05 December 2022, 01:54:28 »
I like it, would really appreciate size markings on >1u keys in your flatlays, especially on novelties and bars.
Offline lonewolf4
« Reply #7 on: Mon, 05 December 2022, 04:56:46 »
Loving this set, any chance PT, ES and IT support is added?
Offline bansheetango
« Reply #8 on: Mon, 05 December 2022, 06:11:58 »
Awesome.
Offline KeyBros_
« Reply #9 on: Mon, 05 December 2022, 08:56:48 »
Tell me It's not EPBT
Offline marcusant
« Reply #10 on: Mon, 05 December 2022, 12:40:52 »
I love the Fira Code font, but would appreciate text-only modifiers in the base set, or normal modifier icons
Offline Plurrkeebs
« Reply #11 on: Mon, 05 December 2022, 19:16:37 »
Love the design but will have to learn more about this style of keycap.
Offline epicdesk.shop
« Reply #14 on: Fri, 09 December 2022, 22:51:38 »
Ooooo super cool!
Offline aicyborg
« Reply #15 on: Sun, 11 December 2022, 19:40:19 »
Can you respond to feedback at all, please? I don't really want to buy a set if all you do is drop the renders, ignore feedback, and then expect us to buy on GB without any communication from you.
Your ISO-UK situation requires addressing. You have two keys exclusively used within the UK included in the base kit (useless to various other European regions) but don't have 2" and 3£. You can't do it both ways.
Offline yui_
« Reply #16 on: Fri, 16 December 2022, 14:14:43 »
the design means nothing if we dont know the manufacturer.
fira code is my preferred font for coding too, but this set is worthless until we know how it'll be made and what quality we can expect.
Offline ggggggg
« Reply #17 on: Fri, 16 December 2022, 14:35:05 »
As posted above, zfrontier has this listed as epbt.
Offline ggggggg
« Reply #18 on: Mon, 16 January 2023, 04:44:10 »
Had a look at this again:
  • as it stands you're forcing Mac users, who want correct legends, to buy into the extension kit and get loads of 40s keys they might not have a need for
  • unless I'm missing something else you're one 1.25u shift away from having a 40s kit that together with alt alphas one can kit 40s boards with without having to buy into base (1.5u mods would be appreciated though)
If you want to go the 40s mod kit+alt alphas route modifiers shouldn't be Mac-centric.
Offline mr_foggy
  • neue = nope
« Reply #19 on: Tue, 17 January 2023, 08:07:19 »
epbt = hard pass
Offline alper_maestro
« Reply #20 on: Tue, 17 January 2023, 09:41:05 »
Is epbt so bad?
Offline rMxGTR
« Reply #21 on: Fri, 03 February 2023, 13:43:58 »
epbt = hard pass
Same. ePBT is so a$$. The feel and the sound. After I bought ePBT Soju, I was done. I wish they made that kit with another manu.
Offline Aiur
« Reply #22 on: Thu, 23 February 2023, 06:31:01 »
Ok, so i made an account just to say this. This set needs lower case alpha legends! Please! ;)
Offline zekth
« Reply #23 on: Thu, 23 February 2023, 10:55:33 »
Did Tonsky approved this? https://github.com/tonsky
Offline AuthenticDanger
« Reply #24 on: Thu, 23 February 2023, 21:29:08 »
OFL 1.1 grants commercial use without express permission.
F Keys belong on the left.
Offline zekth
« Reply #25 on: Sun, 26 February 2023, 05:05:01 »
That was not the question.
Offline Nuap
« Reply #26 on: Sun, 26 February 2023, 18:44:11 »
Using alter for 1.5u alt keys is ugly. Not that my opinion matters here, this is not a real IC, you just dropped some renders and it went straight to sale.
Offline vhaarr
« Reply #27 on: Thu, 02 March 2023, 15:01:43 »
Yes, it was. My native language isn't english either, but he did answer your question.
Tonsky approved this project by explicitly applying the license they did to the font. They could have picked any license for their font. They picked this one. He approves anyone to use it for commercial use explicitly by applying that license, which is something they did knowingly, wilfully, and with express knowledge of the implications.
What you probably meant to ask was either "has he endorsed this product?", or "what does he think of this product?", or "was this product made in cooperation with tonsky?" or something similar.
That said, since ePBT is producing it, I'm not touching it with a 10 foot pole. I bought "Less, but better", and I'm never buying another ePBT set unless someone tells me they've retooled their factory.
Even then I would not buy this set, because the designer has cut way too many corners, has no idea how to produce decent kits, and has completely ignored community feedback, and hasn't posted an actual IC at all.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline dededecline
    • Linktree
« Reply #28 on: Tue, 07 March 2023, 11:09:10 »
1) Why are you using ePBT when they're still trying to get through sets run in early 2020?
2) This kitting is genuinely awful
3) Your lack of any sort of IC feedback reception is at best lazy and at worst really arrogant for someone's first IC
4) Your lack of updates to this IC (still doesn't even show the manu despite KBDFans listing it as ePBT) makes it seem like yes, genuine laziness
5) Why in the world would you run a set with vibrant/neon legends on a dark base key through reverse dyesub
6) You haven't shared colors, and given everything else mentioned here I'm putting money on you matching this to hex codes
Offline mk
« Reply #29 on: Tue, 07 March 2023, 17:28:08 »
I'm having a hard time understanding some of the legends.
- Is the litigature kit just random symbols without any connection to even an obscure syntax of a kind?
- Is the 4#_lib kit just a random assortment of keywords slightly related to computing, ranging from proprietary tools, to bash commands, to cryptopoop, to assorted keywords?
Offline NihonCK
Re: [IC] Fira Code Keycap Set - Unmarked Design(Updated Mar 9)
« Reply #30 on: Wed, 29 March 2023, 03:02:20 »
Look, we get it that you are using an alt account for this keycap set.
Not sure why you are ashamed to associate your previous set, Less But Better.
Sure, this set can only be run with dye-sub... but who else is going to do this and get you the QC that you would like? Switch to Keyreative!?!? MW?
Good luck, maybe consider investing in getting custom molds and doing doubleshot instead. You might have a better chance at producing a better product that way.
Offline Nuap
« Reply #31 on: Wed, 29 March 2023, 05:44:13 »
Was this cancelled? The KBDFans page now returns a 404.
I am not surprised if it was cancelled, considering how you treated this ""IC"".
Offline zekth
« Reply #32 on: Thu, 30 March 2023, 08:07:04 »
He did not
Offline involuntarysoul
« Reply #33 on: Thu, 30 March 2023, 18:48:34 »
just go GMK please
Offline CONIN
« Reply #34 on: Sun, 20 August 2023, 15:35:03 »
Dark Theme
Any updates for this set?, would love to grab a few kits from the Dark Theme.  :cool:
Offline El Kinoflop
« Reply #35 on: Sun, 20 August 2023, 16:04:35 »
The GB is open on zFrontier. Legend Keys rather than epbt.
https://en.zfrontier.com/products/group-buy-legend-keys-pbt-fira-code
Offline aicyborg
« Reply #36 on: Sun, 20 August 2023, 17:46:04 »
They call 'em Unmarked Design because this thread has been unmarked by them since it was announced
kitting blows
hard pass
