Author Topic: ceramic keyboard?  (Read 3073 times)
Offline PlayBox
ceramic keyboard?
« on: Sat, 10 December 2022, 16:06:30 »
so i got a not bad idea about making a ceramic keyboard (not for gb though) because i have resources for it. what geekhackers think of this idea?
propably sent from my amazon kindle 10th gen
Re: ceramic keyboard?
« Reply #1 on: Sat, 10 December 2022, 16:44:00 »
Me, being someone who has sculpt and cast things, as well as hand-made custom cases for myself, I would be worried about keeping things straight to avoid deformation away from the tolerances needed.
If you could find a good method to make it happen, and you enjoy the process, then why not? It would be interesting to see just if it could be done.
Offline PlayBox
« Reply #2 on: Sat, 10 December 2022, 16:48:16 »
yeah the deformations was what i was thinking i could propably use clay that doesn't shrink as less as possible and get thick bezels
Offline Leslieann
« Reply #3 on: Sun, 11 December 2022, 18:48:23 »
Yep, precision will be an issue, make sure to make the chassis then make your plate to fit however it comes out.
Personally, I'd also worry about accoustics, I suspect they will be attrocious.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
