Author Topic: Micro USB to USB C connector  (Read 3202 times)
Offline Subdromat
« on: Wed, 14 December 2022, 02:12:33 »
Hey folks,
just a technically question. I just bought myself a rare WASD Code 87, because of its ISO design. Through that it is equipped with Micro USB.
Just planning to mount cnc case . The cnc case has USB C. Do I will get problems using the case with different connector type.
Tx
Offline PlayBox
Re: Micro USB to USB C connector
« Reply #1 on: Wed, 14 December 2022, 14:22:03 »
Hey folks,
Tx
if its the case for this exact keyboard go ahead and try. if not it won't work
propably sent from my amazon kindle 10th gen
Offline Leslieann
« Reply #2 on: Thu, 15 December 2022, 12:12:07 »
WASD sells an adapter to convert from micro to type C for their aluminum cases, it was available as an upgrade option for the case.
If you lack the part get in touch with them they may still have some.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Subdromat
« Reply #3 on: Thu, 15 December 2022, 14:22:34 »
I just connected the case and it works:
Both keyboards are provided with 4 wires (ground, minus, plus, data) , the old board with additional shield, actually USB 2.0. The USB-C controller of the cnc case is doing the same... as the old Micro USB controller. Was a littel confusing because of different wire colours, but the plug was in identical order.
Thanks for your advice !
« Reply #4 on: Fri, 16 December 2022, 07:35:10 »
Both keyboards are provided with 4 wires (ground, data +, data -, VCC (5v power))
USB is designed to be backwards compatible so good to hear it works :)
The pinout is as "quoted" though :thumb:
