Advanced search
wanna switch?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
macintosh-like pcb?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: macintosh-like pcb? (Read 4027 times)
simplycanada
Thread Starter
macintosh-like pcb?
on:
Sat, 24 December 2022, 20:17:01 »
sorry if the subject wasn't the best one I could come up with late at night here in canada but anyhow to cut to the actual point..
for a while I was looking at the keychron q6 barebone kit regarding just using the first key to right of spacebar as a "dummy second spacebar" leaving the actual apple key just somewhat almost in the same position as on an old macintosh keyboard .. but the one slightly sore issue was the big plus key on numpad instead of separate square-shaped minus and plus keys. I nevertheless kept looking a little bit on and off for a while especially through some of the sample photos from on /r/mechanicalkeyboards/ .. but then by some chance I ran into a photo of an assembled 87% kit that had only three instead of four keys to right of spacebar and I was like 'uhh hey where did that come from now?' .. sure enough I kinda got myself into a little bit of a rabbit hole with the web from that point there
but anyhow back to the actual question..
so far I've found these but just had to wonder if anyone already knew of more that I had not seen yet?
https://kprepublic.com/collections/xd87-80/products/xd87-xd87-xd80-custom-mechanical-keyboard-kit80-supports-tkg-tools-support-underglow-rgb-pcb-programmed-gh80-kle
https://www.cftkb.com/shop/mysterium-tkl-diy-keyboard-kit
(I'll admit I'm not too sure I'm fond of the casing tho)
https://www.apexkeyboards.ca/products/galatea-tkl-pcb-x-apex
https://customkbd.com/en-ca/collections/other-keyboards/products/tkrielle-tkl-keyboard?variant=43447567974624
(as a small sidenote yes I've noticed the tiger 80 lite from customkbd.com but theres too many things I don't like about it cosmetically, sorry!)
on a related note to the same question;
I wasn't going to mind trying a physically separate numpad, and so far I'm thinking of this one:
https://kprepublic.com/collections/cospad-xd24/products/cospad-20-numpad-xd24-xiudi-custom-keyboard-pcb
unless I'm wrong (which may be likely) this seem to be the only one on a not-$100cad kind of budget that could actually fully emulate the layout of a macintosh numpad what with the square-shaped minus and plus keys being present unlike the one big plus-only key in same space on typical windows numpads?
as a final note I've done breadboard soldering (beside a bit of woodburning pencil works, not same hobby but similar enough physical experiences tho) on and off in the past so I'm ok with if the pcb is not a hotswap-ready one if it has to come down to that
Logged
Sup
Exquisite Elder
Doing university was a mistake
Re: macintosh-like pcb?
Reply #1 on:
Sun, 25 December 2022, 11:11:24 »
The layout you are describing is the TSANGAN bottom row. Basically 1,5u, 1u, 1.5u 7u 1,5u, 1u, 1.5u. Almost any custom keyboard kit has the option for that layout unless it's hot swap then it's usually your normal ANSI layout.
In this case you would have to most likely solder if you want your perfect layout on your numpad/TKL. The option for nice in stock TKL keyboards are pretty rare. Maybe you can wait for the extras for the Safa TKL?
https://geekhack.org/index.php?topic=116273.0
For the PCB's i would look for ones that run QMK and if better are VIA compatible to make reprogramming user friendly.
Logged
current
Filco Zero - NOS Yellow Alps | Canoe R1 Gateron Red |
AEK II JP Cream dampend |
Filco Majestouch 2 Tex case Gateron Yellow |
HHKB Pro 1 2003 Rev AO Serial 000171 |
HHKB Pro 1 2003 Rev A1
s|DZ60 OG Panda's with Fei spring and stem. | Sentraq S65_Plus OG Invyr Panda's | A17 Gateron Black TX 65G 3204 | Lubrigrante Wildcard Cherry MX silent blacks 3204 58.5G Springs | Rukia Everglide Tourmaline Blue 58.5G Springs | MGA Standard Greetech brown |
Coming soon
simplycanada
Thread Starter
Reply #2 on:
Sun, 25 December 2022, 11:43:09 »
thanks sup, seem I learned yet one more tidbit about mechanical keyboards. had never heard of tsangan word till now
I'm ok with soldering, going keep looking a bit more before I finally decide on one or two to pick from. cheers [and merry xmas?]
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
macintosh-like pcb?
