Author Topic: Two split pcb's into one case, can I solder the trrs's with simple wires?  (Read 4025 times)
Offline Nuigurumi
Hi,
I'm going to put a set of split keyboard pcb's into one case, to make one 'big' keyboard'.
Normally split pcb's are connected with a trrs cable, which would be redundant in my case..
Can I just solder 4 wires between the trrs points on the pcb? Or am I overlooking anything?
Thank you :)
Offline simplycanada
Re: Two split pcb's into one case, can I solder the trrs's with simple wires?
« Reply #1 on: Tue, 27 December 2022, 06:18:13 »
welcome to the forum nuigurumi :-)
as for your question, I think that as long as you were sure you were going to keep this big keyboard as it was for quite a while then I don't see any real problem in using a more permanent bridge re wires instead of trrs cable
(in fact I've been wondering a bit about tkl+numpad pcbs in one single case too so you're probably not that too unique there!)
Offline Nuigurumi
« Reply #2 on: Tue, 27 December 2022, 06:26:48 »
Good to hear, thanks!  :thumb:
Offline Leslieann
« Reply #3 on: Tue, 27 December 2022, 10:58:59 »
Sometimes they fail to flash properly while connected and need to be flashed separate, especially the first time.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Nuigurumi
« Reply #4 on: Tue, 27 December 2022, 12:17:13 »
Is this controller dependent?
Or something all controllers have?
I'm going to use Elite-Pi's.
Offline Leslieann
« Reply #5 on: Tue, 27 December 2022, 21:33:05 »
A QMK issue in general, I think.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline Nuigurumi
« Reply #6 on: Wed, 28 December 2022, 06:44:31 »
Thank you for the info, I might hold off soldering until I'm fully satisfied with the layout and it doesn't need flashing anymore.
