Author Topic: [IC]YMD-75% Split 84 RGB Aluminum Kit(Production time now after GB)  (Read 6585 times)
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
IC Click Here
This times,we want to upgrade our acrylic split 84 kit be full aluminum with the new designing.
We finish the first designing for it now.Use the integrated plate top parts like before,and upgrade the soldering pcb be the new hotswap south facing rgb one.
Here is some images for the keyboard that we add the switches and keycaps for photos.Of course,it is not included for kit parts.
294943-0294945-1294947-2294949-3294951-4294953-5294955-6294957-7294959-8
When only add the switches,the kit will be like this.
294961-9294963-10294965-11294967-12294969-13294971-14294973-15294975-16294977-17294979-18
Many thanks for your advices.
Details
CNC anodized aluminum case with acrylic layer for RGB underglow.Integrated plate top part for PCB of fixing.
Aluminum feets for ergonomic angle,special acrylic designing for indicator leds.
South facing hotswap RGB split 84 PCB,support split spacebar(2u and 2.75u).Type C port,VIA and VIAL programmable.
OEM PCB mounted stabilizers,can still change it to screw in stabilizers.
« Last Edit: Wed, 15 February 2023, 02:34:45 by vincent88928 »
Have Fun Everywhere
Offline ATB
Re: [IC]YMD-75% Split 84 RGB Aluminum Kit
« Reply #1 on: Sat, 31 December 2022, 06:20:11 »
When do you plan to have these available for sale?  :D
I have the existing (non-RGB) bersion and just 1 thing I don't like: the plastic case is too thick (I removed the top layers): I prefer much more when there's no additional vertical thickness around the keys like in the Keebio Sync
« Last Edit: Sat, 31 December 2022, 06:27:37 by ATB »
    • YMDK
« Reply #2 on: Mon, 02 January 2023, 18:59:59 »
After GB,about April or May this year.
Have Fun Everywhere
Offline Engedi_
« Reply #3 on: Tue, 03 January 2023, 17:10:18 »
Finally! I was waiting for this!
    • YMDK
« Reply #4 on: Fri, 13 January 2023, 18:26:42 »
IC finshed,GB open now.
Have Fun Everywhere
    • YMDK
« Reply #5 on: Tue, 14 February 2023, 01:54:43 »
Last one day for GB,production time is coming.
Have Fun Everywhere
