Author Topic: [GB]YMD-75% Split 84 RGB Aluminum Kit(Production Time)  (Read 6731 times)
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
« on: Fri, 13 January 2023, 02:09:17 »
GeekHack IC
Order Place
Discord
After finish the IC,we open the GB with our production time.This times,still use our website with shopify of system.
GB Time: Jan 14-Feb 14
Production Time: Feb 15-Mar 15
Checking And Shipping Time: Mar 15-Mar 31
Images below(Add switches and keycaps for photos,it is not included)
295377-0295379-1295381-2295383-3295385-4295387-5295389-6295391-7295393-8
Special note:
1)Because IC and shipping fees of reasons,we can only provide FedEx for it only this times.(FedEx just need more 5 usd in basis of standard shipping)
2)Will prepare 100 cm C-C cable for middle of connection.
3)About the split keyboard next times,we will still consider do GB when we finish the designing fristly.
Package Included(139.9 usd+FedEx fee)
YMD-75% Split 84 Aluminum RGB Kit: Split 84 Aluminum Case+RGB Split 84 Hotswap South Facing PCB+PCB Stabilizers+Screws+Aluminum Feets+Cables
Details
From standard 75% 84 to split 84,we add the number keys in keyboard of left side.But acrylic kit is not enough in material of function.So we list the IC and GB For split 84 aluminum kit.
We just upgrade the old split 84 acrylic kit be the aluminum one,so there change the material and designing for it.But still keep the split designing for Ergonomic.
PCB use the newest RGB south facing hotswap designing with VIA VIAL Programmable,upgrade it be Type C Port now.
Anodized split 84 Layout black aluminum case with acrylic layer,aluminum feets for ergonomic angle.Special indicator light designing for case and pcb.
Integrated plate of top part make switches of pressing directly.
We will provide two cables for connection,so don't worry this part of problem.
Note
We prepare four ports for the keyboard,so you can use the left side and right side alone in different computers.
When you connect the middle cable,you can use the left side or right side port for USB-C cable,but can't connect the two ports with USB-C cables together at a computer.
We had flashed the right file before shipping,so you can just open VIA or VIAL to use it normal.
Hotswap kit need not soldering.Use some fomas for screws of connection better,so we will provide some when shipping.
PCB manuals
VIA and VIAL,can just open VIA or VIAL to use and design it directly.Because we had flashed the right file before shipping.
Email Working:david.chen@ymdkey.com
« Last Edit: Wed, 15 February 2023, 02:15:06 by vincent88928 »
Have Fun Everywhere
Re: [GB]YMD-75% Split 84 RGB Aluminum Kit
« Reply #1 on: Fri, 13 January 2023, 12:06:48 »
Approved :thumb:
    • YMDK
« Reply #2 on: Tue, 14 February 2023, 01:54:27 »
Last one day for GB,production time is coming.
Have Fun Everywhere
Offline FaptasticPlanet
Re: [GB]YMD-75% Split 84 RGB Aluminum Kit(Production Time)
« Reply #3 on: Wed, 22 February 2023, 07:33:45 »
Will these be going on general sale after the group buy is over? I would love to upgrade my acrylic split 75%, but am finding out about this group buy a little late!
Is there any place I can monitor, or give my email address for notification on this specific product (split 75% with metal case)?
