Author Topic: Overclocking  (Read 32593 times)
Offline chimera15
Overclocking
« on: Mon, 04 October 2010, 05:13:05 »
I suppose I should reread some of the stuff on overclockers.net or elsewhere, but I thought I'd try to get some more specific help to my system since I know there are a lot of overclockers here.
So I just built my first 1366 system.  This is the first system I've had that I really built to try to overclock.  It's a 2.13 ghz base cpu.  It currently has a 133mhz  bclk frequency, a 100mhz pcie frequency.  It has an unlocked cpu ratio, but is currently on the highest setting of 16 for 133x16=2.13.
If I wanted to run my system at 2.4 ghz, should I just increase the bclk fequency, or should I lower the cpu ratio to 12, and set the bclk to 200?
I've never had an unlocked multiplier chip before that I intended to look at for overclocking, so this is a bit new to me.  In c2d era all you could do really is increase the fsb which is the same as the blck a bit at a time right?
If it let me I could increase the multiplier to 18, and I could 2.4 that way right?  That would leave everything else as it is on the board, and just stress the processor.  If i increase the bclk it'll stress the entire system/board?
 But it doesn't seem to be in the available settings, only lower numbers.....
Also my memory only seems to be showing up as 800mhz, even though it's at least 1333mhz memory...so I don't quite get that.  I don't see a setting to change that at all...but maybe just haven't explored enough yet.
« Last Edit: Mon, 04 October 2010, 05:22:12 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
Overclocking
« Reply #1 on: Mon, 04 October 2010, 05:40:40 »
Alright, going with this then.  It seems to suggest setting the multiplier to 12 and bclk to 200 is what I need to do.
Alps boards:
Offline chimera15
Overclocking
« Reply #2 on: Mon, 04 October 2010, 05:55:04 »
Well that didn't work.  Tried a setting of 12 and 200 right off and it won't boot.  Oops.
Alps boards:
Offline chimera15
Overclocking
« Reply #3 on: Mon, 04 October 2010, 06:02:47 »
Phew! Look like it reset itself after 3 times failing to boot.
Alps boards:
Offline Scarzy
    • http://enecutive.blogspot.com/
Overclocking
« Reply #4 on: Mon, 04 October 2010, 06:23:29 »
It always reverts back to original settings so don't be worried about checking things out. You need to read up on changing volts probably to get more out of your CPU. It was quite easy with mine, my E2160 (1.8ghz at stock) is on 2.69ghz stable nearly all the time. Let us know how it goes!
Offline Rajagra
Overclocking
« Reply #5 on: Mon, 04 October 2010, 08:50:40 »
I've always found overclocking to be unrewarding, even when it worked. The extra speed will never recover the time you spent working to get it! :smile: I see it as something to be done for fun rather than getting performance on the cheap.
Having said that, my i7 system was designed for overclocking so I should give it a try.
Offline Phaedrus2129
Overclocking
« Reply #6 on: Mon, 04 October 2010, 09:03:41 »
Just a note, DO NOT touch the PCIe frequency. Depending on your motherboard and drives, somewhere between 101MHz and 120MHz it'll start frying your hard drives, because your southbridge is run off the PCIe clock, and your hard drives' circuitry is run off the southbridge. It gives no performance boost at all since PCIe 2.0 X16's bandwidth is more than enough for even a Radeon 5970.
I haven't had a chance to overclock an LGA1366 system yet, so I can't help with that. Have you tried actually asking at OCN?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline chimera15
Overclocking
« Reply #7 on: Tue, 05 October 2010, 03:40:28 »
Nope, not yet.  I kinda got scared after my first failure. lol  I have school to do now, so maybe after I get my homework done for this week in a few days or something.
On a side note I actually got this system to run the game I play, Warrock, to run perfectly on it, with no jerkiness, frame lag, or framerate slowdowns I was having on my other systems.  It wasn't by any overclocking, or because this system is a lot more powerful than my c2ds, but because I tested this system with putting in old junk 8600gt video cards in it.
I found that the game had 0 problems by running one old graphics card.  With a more powerful card the game actually has frame lag.  I can use the system right now with 8600gt's in sli config and it'll actually increase the frame lag.
I've since confirmed this by reading the warrock bulletin boards where others have reported that older graphics cards provide higher framerates, and actually measured it to be so.
It's really counter intuitive, and even the game designers are clueless about the problem, as it's not 100% across the board for everyone, and they can't recreate the problem themselves.  If anyone has a clue as to that on this board, I'd appreciate it, cause I really am confused by it.
People report a higher frame rate with a 128mb 5 year old, super low mhz card, than a 1 or 2gig brand new super gpu.
This is actually pretty interesting if it stays this way.  It's like for the first time a game might actually require you to downgrade to play it. roflol
« Last Edit: Tue, 05 October 2010, 04:03:40 by chimera15 »
Alps boards:
Offline alec
Overclocking
« Reply #8 on: Tue, 05 October 2010, 05:30:53 »
Nothing wrong with that if engine is very old and was optimized for GPUs of that time.
New GPUs are mostly about pixel shaders and memory size/bandwidth and Warrock usues neither.
When starting overclock I like first to know limits of each individual component.
In your case 12x200 failed probably because of memory or motherboard limit rather than CPU.
Start with 12x133 and raise bclk gradually until it won't work
Then lower memory divider and see if it works at those settings. That would mean memory was the limiter.
After I learn the limits I see how much can I gain by adding voltage. Usually the gain is not worth extra power and heat and noise.
And only then I decide at what setting can my system run optimaly.
Noppoo Choc Mini
Offline chimera15
Overclocking
« Reply #9 on: Tue, 05 October 2010, 06:06:31 »
Warrock is about 3-4 years old, but has been upgraded continuously. I understand why if that was the case it wouldn't be any better, but why would it be worse with a newer graphics card? That makes no sense at all.
I'll try 12x133 next then when I get the nerve up again. lol  That'll severely underclock it right?
Alps boards:
Offline alec
Overclocking
« Reply #10 on: Tue, 05 October 2010, 06:34:48 »
Quote from: Rajagra;229535
Can't say it wastes much time, but it does occupy the mind quite a bit.
Once set up I'm using this system for a year without change
But if I didn't waste couple days doing it, I'd be constantly thinking about underperforming, blaming every slowdown on this.
12x133 is guaranteed to be working just as 16x133 is. And if you raise bclk gradually, say 20MHz at a time you get more information than just "its not booting at 12x200".
Could run a simple cpu/memory test every time too. I used prime95 to find instability. Sometimes it would boot but give errors in prime95, then I know that memory is at the limit.
Noppoo Choc Mini
Offline lam47
Overclocking
« Reply #11 on: Tue, 05 October 2010, 07:15:26 »
I find a good starting point is to find the max for the CPU and Ram independently. You downclock one to find the top of the other.
My 955 will run 24hours at 3.8
The gains will depend very much on what you are doing.
My brothers PC I made him was all gain. Its a triple core unlocked into a quad! Its perfectly stable too.
For some games a CPU overclock will help FPS. Others it will do nothing and you will need to look at clocking the GPU up.
There is so much to go into its hard to write anything short that will be helpful.
Good luck with it all though.
I would say that Overclocking rewards for time effort a lot more than water cooling does!
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline EverythingIBM
Overclocking
« Reply #12 on: Tue, 05 October 2010, 09:02:01 »
Quote from: chimera15;229885
Sometimes older hardware just performs better for certain software. A quick example I can think of is the new computers hate changing MIDIs in games, so the CPU pauses, whereas in older computers this wasn't so.
So maybe your question is why didn't the programmers update the code to handle new graphics cards better? Laziness?
Offline zefrer
Overclocking
« Reply #13 on: Tue, 05 October 2010, 09:11:23 »
Quote from: chimera15;229490
That is not an unlocked cpu ratio. It's like this, most CPUs Intel sells are "unlocked" ratio wise if you're going down but not up. Which means your 2.13Ghz CPU has a maximum ratio of 16 but can go down.
A truly unlocked ratio like you get on the 980X (and all extreme edition cpus) for example can go both up and down with no restrictions.
In your case, don't touch the ratio just increase BCLK. The reason being that lowering the ratio means you need a much higher BCLK to reach the same speed. However, you cannot increase BCLK indefinitely. For 4.0Ghz for example with a 12 ratio you'd need a 330 BCLK. If you find a motherboard that can do that let me know.. :)
Yes exactly. That's why it's not unlocked.
You seem to be confusing bus speeds with memory speeds. What is your cpu and memory exactly?
Here's a few things to get you started.
1) Lock the PCIe and memory frequency. There should be a setting in your motherboard to lock the PCIe frequency to 100mhz (standard PCIe frequency, do _not_ increase). Likewise for memory. Start with your memory locked at it's default setting.
2) Increment BCLK slowly and test stability with something like super-pi or similar.
3) Once you find a frequency that is not stable in super-pi you have two options. Either accept that as a free overclock with no other adjustments needed or continue.. To continue means to increase cpu core voltage. As you go up in frequency the CPU needs more juice. More juice means more heat expelled however so at this point you need an aftermarket heatsink (which you should have anyway).
4) Continue 2 and 3 until you find a stable frequency at acceptable temperatures for you. Acceptable is anything lower than 70C. Keep in mind that the stock Intel heatsink is woefuly poor and will do 70C in _stock_ settings. Get a good heatsink.
Once that is done you now have your stable CPU overclock. You can do the same steps for your memory overclock.. Increase memory frequency in bios via the locking mechanism, don't touch BCLK after you've done your CPU. Once you find instability increase memory vdimm a little at a time and keep going.
Go slow with voltage increases, 0.1 at a time. Do not exceed ~0.5V total voltage increase unless you really know what you're doing if you ask me.
How much you can do with overclocking is mostly dependant on the motherboard these days. If you have a good motherboard it's super easy, some even have overclocking "wizards" that work suprisingly well.
If you don't have a good motherboard it is but an exercise in frustration. Get a better board.
Offline chimera15
Overclocking
« Reply #14 on: Tue, 05 October 2010, 10:38:00 »
Quote from: zefrer;229931
Ah, ok interesting that answered some questions.  There's nothing definite I could find on the bus speed since it's a 1336 system.  I believe it's an 800mhz processor that I found data about on it, in a really obscure place,  but I was told that 1366 systems don't have fsb's anymore so there isn't a bus speed really since it's in the chip.
The memory is 1333mhz, and or I have 2 sets of memory right now, the other is 1600mhz dominator, but only 2 gigs.  I'll probably pull out the 1333 stuff, but was hoping I could just get them both up to 1333, and still have 4 gigs.  They both seem to be lowered to 800mhz right now.
So to clock the processor at 2.4, I'm going for 16x150 right?
« Last Edit: Tue, 05 October 2010, 10:41:04 by chimera15 »
Alps boards:
Offline J888www
Overclocking
« Reply #15 on: Tue, 05 October 2010, 11:03:43 »
I just do not comprehend the necessity to do this , do that, do this etcetera. With my Core i5 750 + ASRock P55 Deluxe mobo, I set it to 4GHz and viola, it's overclocked + stable. Most modern mobo have auto overclock settings.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline J888www
Overclocking
« Reply #16 on: Tue, 05 October 2010, 11:24:51 »
Quote from: ripster;230006
Yeah but where is the fun in that.
I never thought of it in those terms, now I'm flabbergasted, to think those manufacturers are becoming killjoys.
Offline zefrer
Overclocking
« Reply #17 on: Tue, 05 October 2010, 11:28:59 »
Quote from: chimera15;229982
Yes, keep ratio at 16, raise BLCK to 150. But do lock pcie and memory frequencies before raising BLCK.
I don't know where you're getting this 800mhz number from but I suspect it is not what you think it is. If you can post a cpu-z screenshot that would be very helpful.
I was referring to QPI speed btw. Not to confuse you too much but while there is no such thing as a front side bus on i7s there's still 'a' bus that connects cpu to memory. Even if the cpu and memory controller are on same chip there still needs to be a connection from one to the other, ie a 'bus' of some sort. On i7s that's called the QPI or Quick Path Interconnect. Its speed is also a result of multiplying a ratio with BCLK.
How memory frequency is calculated on i7s is.. weird - and might be a bit confusing depending on what motherboard/bios you have.
Here's a very good article on overclocking i7s.
At stock your i7 920 should have a memory speed of 1,066MHz (memory multiplier on 920 is 8, times the BCLK of 133)
Offline chimera15
Overclocking
« Reply #18 on: Tue, 05 October 2010, 11:51:23 »
Here.
The memory is pretty funky.  I'm not sure I understand what it's telling me at all.
Why does it say the frequency is 1600mhz?  I have 1333mhz rated ram in there?  The bios is telling me it's only 800mhz?
The geil sticks are the junkier ones, but they're showing they can be clocked higher than the corsair dominator 1600mhz according to that...doesn't make much sense.
« Last Edit: Tue, 05 October 2010, 12:01:58 by chimera15 »
Alps boards:
Offline zefrer
Overclocking
« Reply #19 on: Tue, 05 October 2010, 11:57:48 »
Quote from: chimera15;230020
Here.
And the memory tab please. Cpu-z says you have a Xeon btw. Do you? :)
Offline chimera15
Overclocking
« Reply #20 on: Tue, 05 October 2010, 12:09:31 »
Quote from: zefrer;230024
yes, it's a l5506 es, as it says.  Intel confidential. It was about $150 cheaper than an i7. lol  Not as powerful of course, but looks like it's about as powerful as a socket 775 quad.  I edited my post for the memory.
http://browse.geekbench.ca/geekbench2/view/296551
« Last Edit: Tue, 05 October 2010, 12:21:37 by chimera15 »
Alps boards:
Offline zefrer
Overclocking
« Reply #21 on: Tue, 05 October 2010, 12:58:39 »
Your memory speed is indeed ddr3-800, memory tab/dram frequency * 2 for DDR.
The NB frequency on i7s is the uncore frequency ie cache/memory controller etc frequency and should be roughly twice your memory frequency (uncore ratio is exactly twice of memory ratio on i7s).
The SPD timings are just pre-programmed settings on the stick of ram itself. It's what the bios uses when it's set on auto. They do not necesarily represent the maximum the memory can do, for that go the manufacturer and find out what the memory you bought is rated for and at what voltage. The manufacturer may rate the memory at a higher speed with an increased voltage. Corsair are known for this, especially the dominator range (it's a good thing).
If you go above what that manufacturer has specified the memory to run at, only then are you overclocking it, obviously.
First off, are you using different sticks of ram in the same channel? If so that's probably what set the memory to ddr3-800 in the first place.
Offline chimera15
Overclocking
« Reply #22 on: Tue, 05 October 2010, 13:02:10 »
Quote from: zefrer;230045
I had 2 sticks of the geil first.   Then I decided to try it with the dominator separately, and that worked, then I decided I'd try both at the same time.  They were all 800mhz in the bios.  I couldn't see any easy way to change that like I can with my 775 systems.
Yeah I got the 2 dominators on the first channel, then 1 stick of giel on that same channel, then 1 stick on the second channel, which is how the motherboard manual said to populate it.  But even without this configuration, just 2 in there by themselves they were always 800mhz.
« Last Edit: Tue, 05 October 2010, 13:08:10 by chimera15 »
Alps boards:
Offline zefrer
Overclocking
« Reply #23 on: Tue, 05 October 2010, 13:09:34 »
Ok, well that Xeon cpu must have a stock memory frequency of 800 then. I am not familiar with Xeon memory settings so not sure. If so, it also means your memory ratio is 6x (6*133 = 800). You can confirm in bios.
Stick the corsair in there (just corsair), hopefully you have 3 sticks of it, and just raise the BCLK. It's that easy really.
If you can't find a setting to change the memory frequency in bios (may not have one, don't know/depends) you're still ok. With a 6x memory ratio you can go right up to 200 BCLK (3.2Ghz) and still be at ddr3-1200 so it's not like you're going to run out of memory headroom anytime soon :)
Edit: I noticed you said you have 2 sticks of each. It's generally not a good idea to mix different sticks of ram in the same channel. You have a tripple channel motherboard/cpu which means each channel is made out of 3 dimm slots on the motherboard. For your testing you can just use the two corsairs, or one, then once you have your stable cpu overclock try two corsair one of the other in same channel. If it works it works.
« Last Edit: Tue, 05 October 2010, 13:15:32 by zefrer »
Offline chimera15
Overclocking
« Reply #24 on: Tue, 05 October 2010, 13:13:29 »
Quote from: zefrer;230051
Hmm, ok, that's interesting info then.  That's probably what I was seeing the 800mhz for and assuming it was the fsb speed.
Alps boards:
Offline Rajagra
Overclocking
« Reply #25 on: Tue, 05 October 2010, 20:17:00 »
Quote from: alec;229890
It does if you run thorough tests like you're supposed to. If you don't run Prime95 for a minimum of 12 hours, or similar, then you haven't tested it properly. I'm not doing that at every stage that seems to work. Sod that.
Offline zefrer
Overclocking
« Reply #26 on: Tue, 05 October 2010, 20:47:30 »
You do that at the highest frequency, not every stage. A single run is enough to judge stability at any speed. Errors usually show up in a couple minutes.
Offline chimera15
Overclocking
« Reply #27 on: Tue, 05 October 2010, 23:28:42 »
The one time I tried to overclock one of my 775 systems before as I recall, I could barely get any performance enhancements without constant bsods, so I just set it back to stock. lol  I probably needed to raise voltages or do something I wasn't aware of.
Alps boards:
Offline Rajagra
Overclocking
« Reply #28 on: Tue, 05 October 2010, 23:47:35 »
Or drop voltages (to make it run cooler.) Ah the mysteries of overclocking!
Offline audioave10
Overclocking
« Reply #29 on: Wed, 06 October 2010, 00:15:34 »
It helps if the motherboard is made for it. My Gigabyte UD3L 775/ Intel E8500 combo was easy (with 1066 RAM). Set the bus to 400Mhz plus add one .025 voltage to the CPU and you get 3.8Ghz (stock was 3.16). Its been that way for a year and a half now.
Its always easier on the mobo if you have only 2 dimms populated instead of all four (at least it used to be that way).
That's 400 x 9.5 multiplier = 3.8Ghz.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline Hak Foo
  • Make America Clicky Again!
Overclocking
« Reply #30 on: Wed, 06 October 2010, 00:42:52 »
Years ago, it mattered:
486DX-33@40, DX2-66@80.  That 40MHz FSB made those 1Mb "Super-VGA" cards really run.
A K6-233 at 225 would actually outperform stock due to the higher bus speed; I had a lucky one which would run at 250 (3x83) or 262 (3.5x75) passably; it would POST at 292 (3.5x83) with a voltage tweak but not run.
Duron 1.6 at 1980MHz was the last big one I did.  One clock tick higher and it went to a new memory timing regime which blew out my DDR266 memory.
I couldn't get much more than 100MHz more out of my old S939 4600+, but it might have been the weird ULI M1695 mobo I used.
My Core 2 stuff did better- an E6750 could go to about 3.5 on a kamikaze run; an E7200 could hit 4.0 but barely.  (50% over stock).  The 7200 was nice since I got it for no charge- modded my 1391401 and earned a contest prize for it.
You've got a P35-UD3L?  I had one, traded it in when I got an Asus M3A78 (sucks) and later a MA790X-UD4 (nicer)
I have the black-label Phenoms but don't do much with it- both a 9950 and a 940 are at stock.
Overton130, Box Pale Blues.
Offline audioave10
Overclocking
« Reply #31 on: Wed, 06 October 2010, 01:03:55 »
Its a P45 - UD3L.
I also have the MA790X-UD4L and it runs my Phenom II 945 quad (95 watt version) at 3.4Ghz. I haven't pushed it much yet.
« Last Edit: Wed, 06 October 2010, 01:06:35 by audioave10 »
Offline zefrer
Overclocking
« Reply #32 on: Wed, 06 October 2010, 05:32:36 »
Quote from: Rajagra;230297
If your aim is to overclock dropping voltage can only make things _worse_ :)
In overclocking the answer is always this. "If it won't run, it needs more voltage." I'm sure you've seen or heard about Pentium4s being run at 8Ghz and etc.
Of course those pesky laws of physics get in the way and past a certain point you get diminishing returns. For example a 0.5V increase may get you a 1Ghz overclock but to go another 500Mhz you would need another 1V. Then for another 500Mhz another 1.5V and so on. Eventually you can't cool it fast enough. You can get better cooling but the cycle just repeats.
As far as being "worth it", it's so easy these days I don't see why you shouldn't do it. A decent motherboard can do it for you if you don't want to bother, the rest of us do it for fun as well as 'profit' :)
A decent overclock for a core2 would be 3Ghz to ~3.8Ghz, for an i7 3Ghz to ~3.9-4.0.
A 30% increase in frequency with minimal effort is pretty significant.
But yeah Hak Foo, I also remember the joy of overclocking a 300Mhz processor to 450Mhz and getting almost twice the performance you had before and better performance than anything you could buy.
Offline timw4mail
    • https://timshomepage.net
Overclocking
« Reply #33 on: Wed, 06 October 2010, 07:25:10 »
Hehehe...50%...
I've got my Phenom II 1090T x6 at 4.0GHz from a stock 3.2GHz on air cooling.
http://valid.canardpc.com/show_oc.php?id=1416368
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline Rajagra
Overclocking
« Reply #34 on: Wed, 06 October 2010, 11:05:03 »
Oh my. Currently testing my 2.6 i7 920 running at 4.2GHz!
Only Memtest so far, but it's looking good.
Base clock is at 210 and I only stopped there because the video said that was the high target.
Edit> Spoke too soon, Memtest froze. Knocking it down to 3.8GHz (210*18).
« Last Edit: Wed, 06 October 2010, 11:09:16 by Rajagra »
Offline zefrer
Overclocking
« Reply #35 on: Thu, 07 October 2010, 06:34:46 »
How'd it go chimera15? Did you blow your power supply or something? :heh:
Offline chimera15
Overclocking
« Reply #36 on: Thu, 07 October 2010, 06:55:40 »
Haven't tried it yet.  I'm still kinda scared, but busy with school mostly.   I'll probably try again on sunday or monday.
Also there's only 12 days till the release of New Vegas... so sort of wanting to at least try to play it on this system before I take a chance of ruining it.
One thing I was wondering about was in OS overclocking software/tools?  I know intel chipset motherboards have os based overclocking utilities that make it apparently really easy.  Is there anything that might work for all motherboards, or all x58 systems or something?
Hmm might have found something.
http://www.asrock.com/feature/OCTuner/
yeah looks like my mobo is supported. x58 extreme.
http://www.asrock.com/mb/download.asp?Model=X58%20Extreme&o=Win7
This makes it super easy.  I'm up to about 140 right now from within the os.   I guess I need to benchmark/memtest it once I get to 150, or 2.4 which is where I think I'll stop.
« Last Edit: Thu, 07 October 2010, 07:14:21 by chimera15 »
Alps boards:
Offline chimera15
Overclocking
« Reply #37 on: Thu, 07 October 2010, 07:27:24 »
Alright, got it up to 2.4.  The little meter on oc tuner shows that it's really in the red.  So I guess I'll stop.  I got 500 more points on geekbench than my stock.  Up to 4800
http://browse.geekbench.ca/geekbench2/view/297644
It's strange it still says it's at 2.13 ghz though...
qpi frequency is now 4800
Broke the 7 mark for the windows experience rating for the first time for my processor. lol  Rated a 7.1.  Was at 6.9 before.  Strangely the memory is still only a 5.5.
nb frequency for the memory is now 1800.
I got a memory error when I went to reboot the system...  Also Warrock wouldn't stay open.  So it's either octuner that's closing it or there are problems.  I guess I need to raise the processor voltage or something?  Any suggestions what to raise it to?  I don't know what would be too much or too little.
Alright, I reset the bios since it seemed to be ok except for that one error with octuner.  There didn't seem to be any heat issues anyway.  It only raised the temperature by 1 degree when I ran prime95 and maxed the processor out for a while.
It didn't boot initially, then came up when I restarted.  The system seems to be noticeably snappier.  Warrock is working.
« Last Edit: Thu, 07 October 2010, 07:57:16 by chimera15 »
Alps boards:
Offline zefrer
Overclocking
« Reply #38 on: Thu, 07 October 2010, 08:19:10 »
Eh, I'd avoid those software tools if I were you. Too finicky..
But really don't be so worried, it's perfectly safe. If the cpu gets too hot it'll just shut it self down.
You won't see much of a difference in temperature without a voltage increase.
Run prime95 for at least one full run to test stability. It will tell you if it finds errors, an error means instability. Just cause it boots doesn't make it stable.
See how high you can get (while being stable) without changing the voltage first I'd say.
Offline Brodie337
Overclocking
« Reply #39 on: Thu, 07 October 2010, 08:27:46 »
OK, I'm not overly familiar with overclocking Intel's stuff, but you should be doing it through the BIOS. Way less likely to screw up.
You dont mention if you have any sort of aftermarket cooling?
Intel stock coolers are pretty cruddy, so watch your temps very closely. Now, I know it's almost a cardinal sin to link to OCN here, but have a read of this:
http://www.overclock.net/intel-cpus/538439-guide-overclocking-core-i7-920-930-a.html
VERY comprehensive.
Offline chimera15
Overclocking
« Reply #40 on: Thu, 07 October 2010, 08:39:35 »
Quote from: Brodie337;230808
VERY comprehensive.
I have an intel fan, but it's from one of the higher end i7's, so I think it should be fine for this processor.  It's pretty beefy.  It's at about 45 degrees on average.
Alps boards:
Offline Rajagra
Overclocking
« Reply #41 on: Thu, 07 October 2010, 09:12:59 »
have a read of this: http://www.overclock.net/intel-cpus/538439-guide-overclocking-core-i7-920-930-a.html
VERY comprehensive.
Looks useful. I ended up dropping mine from the flaky 4.2GHz to 3.48GHz (205*17) with almost standard voltages (1.256V VCore). I have 33% more CPU speed and 66% higher memory speed than before! But if I follow that guide I know I can get more.
I don't really need more performance for games, but Vista sure as hell seems less sluggish, hehe.
« Last Edit: Tue, 12 October 2010, 04:51:34 by Rajagra »
Offline Hak Foo
Overclocking
« Reply #42 on: Thu, 07 October 2010, 10:10:35 »
Quote from: audioave10;230339
Its a P45 - UD3L.
I had the P35 version; I think it was the first board I specifically desired, rather than 'does it meet my specific minimums'.
It was sold out when I first built, so I got an Abit IP35-E, which ate RAM, so I turned it in and got the DS3L.
Found old validation link for the best run:
« Last Edit: Thu, 07 October 2010, 10:13:24 by Hak Foo »
Overclocking
« Reply #43 on: Thu, 07 October 2010, 10:19:59 »
Ack! Do not want!
This is better:
Offline zefrer
Overclocking
« Reply #44 on: Thu, 07 October 2010, 11:31:30 »
Quote from: chimera15;230811
No. Buy an aftermarket heatsink ASAP. As mentioned multiple times in this thread, Intel's heatsinks are ****, to put it bluntly.
Intel's heatsinks are only good enough for cooling stock CPUs, not overclocked ones.
See here for example.
Even at stock a good heatsink is more than 10C cooler at load than Intel's. At overclocked settings almost 30C cooler. Meanwhile Intel's is hitting 70C.
You have been warned :)
Overclocking
« Reply #45 on: Thu, 07 October 2010, 11:43:17 »
I think he means one of the Extreme Edition CPU coolers, that are packaged with the 980X and 975. They perform pretty well, not really enthusiast level, but they're tower coolers with heatpipes. A bit worse than a TRUE 120.
Offline zefrer
Overclocking
« Reply #46 on: Thu, 07 October 2010, 12:00:31 »
He's running a Xeon 2.13Ghz and getting ~45C? Somehow I doubt he's using the 980X (which you can't buy by itself) :)
Offline chimera15
Overclocking
« Reply #47 on: Thu, 07 October 2010, 13:10:17 »
Quote from: zefrer;230887
Yes, that's it.  I bought it off ebay from someone who used aftermarket coolers on his and sold the stock ones on ebay.
They don't have heat pipes and stuff.  I forgot which one it is.  It's in the should I go to Japan or build an i7 thread though.   I think it's working fine.  I don't have any spare money right now, so it's ok if it runs a bit hot for a while.  I'm not going to push it past 2.4 for now.   It seems to be stable at this setting without any increase in heat.
I just fired up speedfan for the first time.  It's reporting temps around 40 degrees.
But the big shock is that it has a temp3=127c!  wth is that???
Actually it's got core0-3 = 30c
gpus=57c
temps 1&2 = 40c
hd=40c
temp 3 =127c
geesh  I don't think I want anything on my board that hot.
Interesting, from another board.  "Speed fan is dodgy with some motherboards and gives bogus readings such as temp 3 & temp which arent really connected to any device, its just picking up signals from something it thinks is a temp sensor"
« Last Edit: Thu, 07 October 2010, 13:24:28 by chimera15 »
Alps boards:
Overclocking
« Reply #48 on: Thu, 07 October 2010, 14:06:02 »
+/-127/128 anything means a bad reading, those are the min/max of an 8-bit integer variable.
Use RealTemp for CPU temperatures and GPU-Z for GPU temperatures.
Offline alec
Overclocking
« Reply #49 on: Fri, 08 October 2010, 05:17:49 »
Quote from: Phaedrus2129;230843
This is better:
I also have "copper mohawk" Thermaltake V1
Noppoo Choc Mini
