Author Topic: Modding Realforce with MX sliders  (Read 5909 times)
Offline phinix
« on: Sun, 29 January 2023, 17:51:03 »
I wanted to ask you guys whoever did mod his Realforce with any type of MX sliders.
How do you find it? Do you like the mod? What exactly did you do and is there anything that you would like to change after the mod?
Offline PlayBox
Re: Modding Realforce with MX sliders
« Reply #1 on: Mon, 30 January 2023, 15:17:35 »
im not into topre but if mx slkders for topre exist then its propably possible also if you are into spending a lot of money novatouch tkl and realforce rgb exist but i doubt they are worth it now
propably sent from my amazon kindle 10th gen
Offline Tempest790
« Reply #2 on: Fri, 03 February 2023, 10:28:06 »
If you get the RGB version of the Realforce, it has MX compatible sliders built in. No need to mod it.
Offline Riverman
« Reply #3 on: Fri, 03 February 2023, 11:41:58 »
The RGB is the way to go if you want MX keycaps on a Topre board. Older Realforce keyboards didn't have a standard bottom row, but the RGB does, along with all other R2 models.  The last I checked, it was difficult to make the space bar compatible with an MX type using aftermarket sliders.   The RGB has no issues with that, either. The RGB is also typically the cheapest way to get a uniform 45g Topre, and they sell for less on eBay than other models because of a misconception that they're someone worse than other Realforce keyboards. I've owned both, and it's just not true.
Offline phinix
« Reply #4 on: Fri, 03 February 2023, 12:55:03 »
For the last 8 years I've been modding topre keyboards, so even 6u spacebar isn't really a problem :)
https://geekhack.org/index.php?topic=93802.msg2554714#msg2554714
But easiest way is to do R2 keyboards nowadays.
I was wondering, did anyone lubed pcb in Realforce? I heard its good to fix springs issues, lubing pcb, not actual springs (using 205g0, cause dia-elec will kill domes).
