Author Topic: [IC] VØID • 65% Layout Top Mount + O-Ring Keyboard (GB in Q3 2024 )  (Read 43029 times)
Offline Anorexus
  • Designer
    • Anorexus Web
VØID
65% Top Mount + O-Ring Keyboard
0. Status
Group buy starts on 9th Sep to 30th Sep 2024
Based on the feedback we've received from the community, we know how important the use of metal inserts is. After giving it some thought, we’ve decided to include metal inserts for the polycarbonate version to improve the durability and lifespan of the screw threads—especially since custom keyboards tend to be built and rebuilt often.
GB thread
1. Intro
Hello everyone! Allow me to introduce Void, a 65% layout mechanical keyboard kit with a dual mounting system, top mount and o-ring mount.
Void provides an adjustable typing experience that allows users to customize the stiffness and sound characteristics. Users can choose between a top mount for a stiffer typing experience and sound, or an o-ring mount for a softer typing experience and isolated sound.
2. Index
0. STATUS
1. INTRO
2. INDEX
3. DESIGN
4. SPECIFICATIONS
5. CONSTRUCTIONS
6. DIMENSIONS
7. MOUNTING SYSTEM
8. COLOR OPTIONS
9. LAYOUT
10. PRICING
11. VENDOR
12. MEDIA & TYPING TEST
13. DESIGN CHANGELOG
14. KEEP IN LOOP
3. Design
With a design language similar to my past work on the stacked acrylic keyboard Vertizon, Vøid offers an aggressive look while still maintaining a clean design.
Render Images
Prototype photos
Prototype #4 Polycarbonate
Prototype #4 Red and Blue
Prototype #3
Prototype #2
Prototype #1
4. Specifications
- Layout: 65%
- Mounting system: Top mount and gummy o-ring mount
- Typing Angle: 7.5°
- Effective keyboard height: 23.35mm
- Plate: 1.5mm Aluminium, Polycarbonate, POM, Carbon Fiber, FR4 (1.6mm)
- PCB: In-house design PCB void65 1.6mm thickness solder or hot-swap - configurable with QMK/VIA
- Weight before assembly: ± 1019g aluminum kit, 1639g copper kit
- Weight after assembly: ± 1355g aluminum kit, 1962g copper kit
Parts included with the kit:
- Keyboard case: (Top case, Bottom case, Rear bumper, Bottom plate)
- Plate (Aluminium, Polycarbonate, POM, Carbon Fiber, FR4)
- 1.6mm Hotswap/Solder PCB; layout information will be shared later
- Daughterboard JST Cable
- 1x O-ring (50a) 1x O-ring (30a)
- 4x Custom-designed rubber feet
- Hand-carry keyboard bag
- Other accessories
5. Constructions
Vøid consist 4 major parts:
1. Top case with aluminum 6063
2. Bottom case with aluminum 6063
3. Rear bumper with aluminum 6063 or Stainless steel
4. Chassis/bottom cover with aluminum 6063 or Copper
In the 4th iteration, we optimized the height of the overall board to find the ideal typing height, as we believe typing height would be a crucial factor in achieving comfortable typing. We reduced the EKH height from 25.49mm in the previous iteration to 23.35mm, which is a decrease of approximately 2.14mm.
We also added some gutter to optimize the travel distance for SMT components from the PCB, such as diodes, micro controller, and hotswap sockets, while keeping the overall board volume.
6. Dimensions
7. Mounting System
Top mount
With 7 mounting point
O-ring
Friction fits o-ring mount with inner wall for isolated sound
8. Color Options
9. Layout
Solder layout provides more flexibility, including stepped Caps Lock, ISO, split Backspace, 7u + 6.25u spacebar, and the "cursed" layout. The cursed layout allows users who don't like arrow keys to experience the Void.
While hotswap will offer less flexibility compared to the solder version, it still supports stepped caps lock and split backspace compatibility.
10. Pricing
Aluminum kit:
starts from $280
Case: Aluminum 6063
Back weight: Aluminum 6063
Bottom weight: Aluminum 6063
Stainless steel + copper kit
starts from $385
Case: Aluminum 6063
Back weight: Mirror polish stainless steel
Bottom weight: Sandblasted copper
Price Simulation
11. Vendor
USA and Rest of the world: Click Clack
United Kingdom: Prototypist
Europe: Delta Key
Indonesia: Kukey Studio
Singapore: Ktechs
Thailand: Aiglatson Studio
Vietnam: Uniqmeck Store
Australia & Oceania: All Caps
Canada: Ashkeebs
China: NEXT
12. Media and Typing Test
13. Design changelog
Prototype#4
1. Redesign bottom case for lower typing height
2. Add gutter for better clearance and travel distance for smt component on the PCB
Prototype #3
1. Add inner wall for friction fit o-ring
2. Try other material than aluminium, such as copper, stainless steel, and carbon fiber
Prototype #2
1. Remove gasket leaf mount options
2. Redesign exterior design due to leaf mount removal, side bezel is thinner
3. Custom molded rubber feet
4. Changed case screw size from M2.5 to M3
5. Move jst cable gutter to back side of the case for better cable management
Prototype #1
1. Initially, Void is designed to support multiple mounting such as gasket leaf mount that supports poron, silicone socks, and silicone gasket.
14. Keep in loop
Any feedback and question are welcomed!
Follow our instagram
Join our discord server
« Last Edit: Mon, 23 September 2024, 19:09:30 by Anorexus »
Offline irithyll
Re: VØID • 65% Top Mount + O-Ring Keyboard
« Reply #1 on: Sat, 25 March 2023, 07:42:52 »
Is there a bottom weight?
If there is, what's the material?
GLWIC!
Offline Akele
« Reply #2 on: Sat, 25 March 2023, 08:32:27 »
Very nice design. What layouts will the PCB support?
GLWIC
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #3 on: Sat, 25 March 2023, 08:50:54 »
GLWIC!
Still exploring, currently we only focus on aluminum 6063 for all parts
GLWIC
Will share, there will be hotswap and solder
hotswap supports step caps, split backspace, tsangan bottom
while solder should covers all hotswap layouts + 6.25u spacebar, ISO backspace, split L shift
Offline HungHingDaiLo
  • 無間道
« Reply #4 on: Sat, 25 March 2023, 10:46:01 »
GLWIC. Great board!
Offline whitewolf154
« Reply #5 on: Sat, 25 March 2023, 17:18:22 »
Very nice! How tall is the front height? (EKH as well)
Offline brviggs
« Reply #6 on: Sat, 25 March 2023, 20:55:56 »
Looks great!
GLWIC.
Offline aicyborg
« Reply #7 on: Sat, 25 March 2023, 21:17:58 »
Is 1.5mm PCB a mistake? Please consider using 1.6mm (or 1.2mm if you must).
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #8 on: Sat, 25 March 2023, 21:22:09 »
Looks great!
GLWIC.
Will provide later
Yes it's a typo, I use 1.6mm
Offline itsundone
« Reply #9 on: Sat, 25 March 2023, 23:07:15 »
this is amazing, consider brass or ss weight :D
Offline Akele
« Reply #10 on: Sun, 26 March 2023, 04:32:42 »
Thanks for including more info on the layouts the PCB will report. That cursed hotswap PCB looks crazy.
Might want to consider updating the IC form to ask people if they have any suggestions or comments on the board (like different weights options) or to ask them which version they'd buy (e.g. hotswap, solder). Also, not sure why you're asking people for their real name on the IC.
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #11 on: Sun, 26 March 2023, 04:41:55 »
Fair point for name field, previously we have it on our local community, it's removed now
Offline Wheland
« Reply #12 on: Sun, 26 March 2023, 08:28:40 »
amazing design, cannot wait to get this board !
I'm pretty interesting also with the sound, especially with the spacebar.
Offline Rilow
« Reply #13 on: Sun, 26 March 2023, 10:58:21 »
Since it's inspired by automotive design, I hope we'll get a Ferrari red option
Offline PlayBox
« Reply #14 on: Sun, 26 March 2023, 12:30:02 »
sadly the target price is way out of my range especially if the taxes included.
anyways GLWIC
propably sent from my amazon kindle 10th gen
Offline Vulcan
« Reply #15 on: Sun, 26 March 2023, 17:41:40 »
anyways GLWIC
I think the price is already fair, considering it's a 4-part machined case, almost impossible to get lower than this price unless the MOQ is above 500 or more
Offline Caishipeng
« Reply #16 on: Sun, 26 March 2023, 19:23:03 »
Looking good
GLWIC
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #17 on: Sun, 26 March 2023, 20:26:51 »
To achieve Ferarri red color I think it would need electrophoersis coat instead of anodization, currently we limited on that
but we're not limiting for any possibilities, we had exploration on red color as you can check here
anyways GLWIC
anyways GLWIC
Yes for the pricing unfortunatelly it's really difficult to lower the price considering it has 4 parts for the case it self
We initiate this thread is to meassure the demand, at this stage with current IC data, we only confident producing 100pcs
Offline PlayBox
« Reply #18 on: Mon, 27 March 2023, 10:40:49 »
anyways GLWIC
im aware and im not asking to bring the price down. im just saying its sadly impossible for me to buy
« Last Edit: Mon, 27 March 2023, 10:43:28 by PlayBox »
Offline involuntarysoul
« Reply #19 on: Mon, 27 March 2023, 11:09:30 »
way too expensive for an all alu board, need at least brass weight for the price
Offline mr_foggy
  • neue = nope
« Reply #20 on: Mon, 27 March 2023, 15:56:51 »
this. nonetheless the design is very sleek and I like it a lot.
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #21 on: Mon, 27 March 2023, 18:00:08 »
Point taken, I understand the concern and we will figure this out although it’s difficult as we mentioned the reason earlier, but we understand the pricing could be better so we will working on that
Also yes we exploring other material as well
Offline Flybeck
« Reply #22 on: Mon, 27 March 2023, 18:37:35 »
I dig the board. Well done, good luck!
Something I just noticed,
I think you should poll for skeleton plate, vs non. :D
« Last Edit: Mon, 27 March 2023, 18:44:52 by Flybeck »
Offline Anorexus
  • Designer
    • Anorexus Web
Re: [IC] VØID • 65% Top Mount + O-Ring Keyboard
« Reply #23 on: Mon, 27 March 2023, 19:23:40 »
might update this, especially for flex materials such as Polycarbonate, POM, etc
The flex-cut design is for stiffer materials such as aluminum, carbon fiber, etc to make it less rigid and achieve acoustic that we desire
as stated above, the default plate will be polycarbonate but we planning to provide more materials to play with
more updates on the content will come time to time
« Last Edit: Mon, 27 March 2023, 19:26:27 by Anorexious »
Offline dantambok
« Reply #24 on: Tue, 28 March 2023, 00:15:41 »
love the side profile
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / Duck Viper v3 / HBCP / Noxary 280 / LZ Physix / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 350 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT / LZ Erghost /  Finder Works Hyphen / 2x Singa Kohaku / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / QK80 / Keycult No 2 TKL / FLX Virgo r2 / Matrix Navi / JJW Derivative / TGR Lena
Coming --   Lynx50 (wixx scammed us) / Ladybird60 / TGR Shi
100+ GMK sets
Offline Flybeck
« Reply #25 on: Wed, 29 March 2023, 18:25:52 »
Sure sure, something you could always do is just demonstrate skeleton plate vs non. Give the people some insight.
Offline IconlabsOfficial
  • Where makers make art!
    • Iconlabs
« Reply #26 on: Sun, 16 April 2023, 09:05:03 »
Really dope. Keep updating :) GLWIC
Offline tactilesbad
« Reply #27 on: Mon, 17 April 2023, 10:07:43 »
saw the proto on instagram, INSANE
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #28 on: Tue, 18 April 2023, 06:25:01 »
Thanks, haven't got time to update the thread ;D
For quick updates I mostly update it on my instagram by the way, for complete log on discord channel
Offline Akele
Re: [IC] VØID • 65% Top Mount + O-Ring Keyboard (Prototype #3 tested)
« Reply #29 on: Wed, 19 April 2023, 02:16:47 »
Is the intention for this board to come with an ISO compatible plate, or to offer an ISO compatible plate for for sale as an extra? I notice the prototype 3 board has an ANSI only plate installed.
Really hope this isn't going to be another instance of a board with an ISO compatible PCB, but an ANSI only plate.
BTW prototype 3 looks fantastic.
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #30 on: Wed, 19 April 2023, 02:33:18 »
I tried a lot of plates till losing counts but since proto #2, we already supports ISO, in #3 we supports 6.25u
changes log is scattered right now since I'm focusing on finalizing the design but once finallized I will provide better clarity on everything
Offline Akele
« Reply #31 on: Wed, 19 April 2023, 11:00:18 »
Great to hear the board will support ISO builds. Good luck finalizing the design.
Offline hzh0525
« Reply #32 on: Fri, 21 April 2023, 09:44:17 »
The layout of the most right row is interesting!
Offline touch
« Reply #33 on: Wed, 26 April 2023, 06:52:32 »
Could you do 2.75 + 1.5 + 2.75 for the spacebar as well?
Offline conternecticus
« Reply #34 on: Thu, 27 April 2023, 21:11:06 »
Personally I'd much prefer the cursed layout to be on the solder PCB only.
Offline Anorexus
  • Designer
    • Anorexus Web
« Reply #35 on: Thu, 27 April 2023, 21:26:18 »
after several test and few design iteration, yes we might change the cursed layout to solder PCB only due to interference on R3 and pcb clearance issue on hotswap version
Offline ppatches24
Looks awesome! If a dark gray color comes out ill buy it! I hope that after the first round of just all black you offer a second round of different colors.
Offline yz
love the all black look, great renders too!
Offline Anorexus
  • Designer
    • Anorexus Web
PROTOTYPE #4
Polycarbonate
Offline Akele
Good to see this is still alive: I thought maybe you'd lost interest and moved into the Øbliviate.
Are there more rounds of prototypes planned, or will you be progressing with a GB soon?
Offline Anorexus
  • Designer
    • Anorexus Web
Haha sorry to keep waiting, still not sure if we need another round of prototype, we will test it first before deciding
Can't say when the GB start for now
Offline Zahul
Any plans on european vendors? Very excited for this board. GLWIC!
Offline EdgeOfInfinity
been following since this was posted. really enjoy this design, especially the all black! i would prob have to opt for the all alu to achieve this.
have you thought about offering any coating/PVD for the stainless steel/copper parts? i'm good either way, just a possible option for those who want the increased weight of copper or brass.
Offline Anorexus
  • Designer
    • Anorexus Web
No plan yet
We want to keep options simple as of now
Offline Akele
That's fair enough. Better to get the board right than rush it. I'm expecting great things after all these iterative revisions and rounds of prototypes.
« Last Edit: Sun, 03 December 2023, 04:22:41 by Akele »
Offline Zahul
No plan yet
That's a shame, but understandable. Please consider it if possible.
Offline Rob27shred
  • Insane in the Membrane! 👻
The cursed layout is actually awesome IMO, never thought of it, but using the 2 long stabilized keys from numpad kits fits the 65% right column perfectly!
Offline Anorexus
  • Designer
    • Anorexus Web
That's fair enough. Better to get the board right than rush it. I'm expecting great things after all these interactive revisions and rounds of prototypes.
Hopefully this is the last so we can wrap it soon
For sure
Thanks a lot
Offline aicyborg
I don't mind if you don't get a European vendor in particular, but please ensure at least one vendor you get is capable of shipping to Europe! (I don't mind paying international shipping with a reputable courier like DHL or something.)
I'd absolutely love a polycarbonate one. IC done. Couldn't vote for PC in the form but that's lovely to see.
Offline Anorexus
  • Designer
    • Anorexus Web
Our lead vendor is Clickclack, will update on the thread
They have experience shipping to the rest of the world
I might need to discuss for which vendor we will work with near the GB
We always open for discussion for vendors who interested to work together
