Author Topic: Blue Screen: Driver Power State Failure  (Read 5322 times)
Offline Naweo
« on: Sun, 26 March 2023, 13:08:34 »
I am getting this weird crash ever since the latest windows update. It seems every time my PC has been idle, it will get a blue screen, as seen below. Any fix to this?
Offline Darthbaggins
  • PC Cannibal
Re: Blue Screen: Driver Power State Failure
« Reply #1 on: Tue, 28 March 2023, 06:29:22 »
Sounds like a sleep/idle state issue - I swear you have the worst luck when it comes to issues w/ your builds.
Offline Leslieann
« Reply #2 on: Tue, 28 March 2023, 13:30:11 »
90% of the problems I see with Win10 is due to bad updates, specifically a bad driver from MS.
The fact that this happened right after an update points to this situation yet again.
Roll back the update or wait for them to fix it is your only option unless you want to get down and dirty with drivers which can be a huge rabbit hole, and that's if it's your own system, let alone a customers where it's an intermittent problem.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Naweo
« Reply #3 on: Mon, 24 April 2023, 10:27:38 »
I unfortuantely opened a new thread and managed to pin porblem a bit.
Its a "memory management" blue screen, and the memory diagnostic called for a hardware problem.
Hmm
