Author Topic: [IC] Think6.5 V3  (Read 17784 times)
Offline AIRPOTTER
  • Owner of Gray Studio
[IC] Think6.5 V3
« on: Mon, 03 April 2023, 13:53:48 »
Greetings friends! I would love to introduce Think6.5 V3, a new collaborative between Oldcat, @迷途的J, and Graystudio. It is almost four years since Think6.5 V1 was launched, and we thank everyone who has joined this amazing journey.
Think6.5 V3 was designed after oldcat moved to Miami, the city of sunshine and beaches. The new city inspired new design approaches and we set out to improve the V2 on both the exterior and interior. For example, to avoid monotonicity, we added an additional arc in the bottom piece to coordinate with the top piece.
The weight is a redesigned one that kept the soul of the V1, the gear. We designed a polished PVD stainless steel with a slope design that symbolizes sailing boats arrive at the harbor. The front badge also follows the V1 design with simple tweaks that symbolizes “G” which is another logo for the Gray Studio. The translucent inserts fills the cutouts with PC material, which will make sure the lights shine through. Further Think6.5 V3 badge will be compatible with V2 badges.
For the interior, we adopted the improved structure for Space65 III, which allows for a perfect gasket-based system with screwless bottom.
Here are some of the specifications:
1.   Case is top-quality 6063 aluminum, custom molded. Surface treatment is anodization or Electrophoresis. The weight is polished stainless steel with PVD.
2.   65% layout, 2U badge. Front height is 19.5mm. Typing angle 6.5 degrees. All optimized for an ultimate typing experience.
3.   Leaf spring + gasket mounting system
4.   Plate material: FR4 or PC. Plate file will be open sourced after the Group Buy.
5.   PCB mother-daughter board system. Mother board is 1.2mm thick with a choice between Hotswap and soldering. ESD protection, supporting QMK, VIA, and VIAL.
6.   3.5mm pad, 0.5mm ixPE switch pad, 2mm silicone sound dampening pad, and 0.5mm electric shock prevention pad. All custom designed and manufactured, included in the package.
7.   Installation manual will be posted to the Graystudio website.
Please join the Gray Studio discord or follow my Instagram for updates of the project!
Discord:https://discord.gg/ckeXNRr
Instagram:https://www.instagram.com/graystudio01/
« Last Edit: Fri, 27 March 2026, 00:15:01 by AIRPOTTER »
Offline oldcat
  • 65% is Life
Re: [IC] Think6.5 V3
« Reply #1 on: Mon, 03 April 2023, 13:58:33 »
 :thumb: :thumb: :thumb:
Offline DaaDaa
« Reply #2 on: Mon, 03 April 2023, 14:02:48 »
What are the colors available?
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline HOBI3CAT
  • FraktalKaps.com
    • Fraktal Kaps Website
« Reply #3 on: Mon, 03 April 2023, 21:07:24 »
Will this support split spacebar? That was what kept me from getting the v1 or the v2...
Eat, Sleep, Resin, Repeat.
Offline rookb
« Reply #4 on: Tue, 04 April 2023, 05:29:39 »
little late for an april 1st submission
Offline ottagerreip
« Reply #5 on: Tue, 04 April 2023, 07:31:09 »
I really liked the anchor weight from the previous gen.
Will you offer some nautical themed weights in the GB ?
Offline ABlazinBlueToe
« Reply #6 on: Tue, 04 April 2023, 14:55:09 »
Would like to see a Think6.0 or something new.
Offline Designerstudio
  • Keeb-related producer
« Reply #7 on: Tue, 04 April 2023, 18:41:17 »
Love the appearance! Definitely reserved!
Discord:https://discord.gg/3TqZ2M8Hw2
Email: designerstudio@126.com
Wechat: DesignerStudio7
Offline Darthbaggins
  • PC Cannibal
« Reply #8 on: Tue, 04 April 2023, 20:50:01 »
Loving the curvature in the case seen in the side profile, would love to get my hands on one.
Offline LASERman Projects
  • Soldering is my native language.
« Reply #9 on: Wed, 05 April 2023, 04:06:46 »
Are you sure about 1.2mm PCB thickness (not 1.3mm)?
Will we need another stabiliser variant for this?
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #10 on: Wed, 05 April 2023, 07:36:41 »
There is no 1.3mm. It's either 1.6mm (normie thickness) or 1.2mm (meme thickness). You're either gonna need stabs for 1.2mm pcbs or stab shims.
Offline EdgeOfInfinity
« Reply #11 on: Wed, 05 April 2023, 13:30:47 »
i'll think about it...
jokes aside, i like the new design!
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #12 on: Wed, 05 April 2023, 19:33:44 »
I would like to get in on a new Think but I would hate to see a PCB with tons of flex cuts. Great design though. An alu plate would also be pretty nice.
Offline KiserDesigns
    • Kiser Designs Store
« Reply #13 on: Thu, 06 April 2023, 09:19:11 »
As a PCB designer, I appreciate the plated through-holes on the switch poles, it is a really nice touch. The layout is very sensible too.
Really glad to see Vial being supported on more boards, it deserves more time in the spotlight.
How are you doing hotswap with 1.2mm PCB? What sockets are you using?
The badge appears to be illuminated in the renders, will it be backlit? RGB?
Offline AIRPOTTER
« Reply #14 on: Thu, 06 April 2023, 09:35:25 »
Many color combinations will be provided. More information to come!
And please check out some of the live streamer's videos!
Offline involuntarysoul
« Reply #15 on: Thu, 06 April 2023, 12:26:22 »
the badge takes up way too much space, looks tacky
« Reply #16 on: Sat, 08 April 2023, 05:15:02 »
The blocker is very useful for those not accustomed to additional keys next to Enter.
Offline AlexMcD0
« Reply #17 on: Mon, 10 April 2023, 08:32:00 »
Looks awesome! Love my Think6.5 V2!!
Please send a prototype to Andy V Nguyen, he does really good reviews.
Offline hzh0525
« Reply #18 on: Tue, 25 April 2023, 05:44:19 »
I like the tiffany color of V2!
Offline raiNmeister
« Reply #19 on: Tue, 25 April 2023, 13:27:47 »
is there any chance an e-white badge option can be added to this GB?
Offline Hawksmoor
« Reply #20 on: Tue, 25 April 2023, 19:41:47 »
There is yeah. For the 2U badge.
The GB is open rn
