Author Topic: [IC] WSPBT Senkou | 28 May - colour samples  (Read 11304 times)
Offline keepoto
  • HHKB top for TKL pls
« on: Thu, 06 April 2023, 15:52:10 »
WS Senkou
This set is inspired by Asuna. I have always been motivated by her courage and resolve. For a longer rant, feel free to read my previous post.
New IC Form
If you have filled out the previous IC form, I shall be grateful if you could take a moment to fill out the new IC form as well!
Foreword
WS Senkou is an overhaul of PBT “The Flash”. I have received quite a lot of feedback after posting the initial IC, and have since made a lot of changes to the design. As the set is essentially completely overhauled, I believe it would be adequate to start a new IC post.
Why WS/dyesub? The set was originally designed with doubleshot in mind. As I progressed with the design and liaised with manufacturers, I came to realise dyesub is probably the more adequate method of production given the relative complexity of the novelties and the need to use multiple colours. Further, this allows for lower price and relatively quick fulfilment time.
Wuque Studio has offered to produce this set using their special all-sided dyesub technique. This technique produces crisp, clear legends, and ensures all sides of the keycap are uniform in colour, with little variance or blemish. Although Wuque is mainly known for its keyboards and doubleshot keycaps, it has also produced dyesub keycap set – most notable, and also utilising all-sided dyesub, is WS Camping. The fact that Camping’s designer chose WS is a powerful testament of its quality.
Basic info
Profile: Cherry
Material: All-sided Dyesub PBT
Manufacturer: Wuque Studio
GB date: TBD
Fulfilment time: 3 months after GB
Pricing
TBA.
Kitting
kitting and board renders by Pensa73 (Pensa73#0073)
Base kit (Katakana)
Latin alphas
Numpad
Spacebars
Accent (Lake)
Accent (Rose)
Novelties
Renders
Zoom75 by Meletrix
Ayleen TKL by Tea House
Fuji65 by CMM.Studio
Promise87 by Wuque Studio
Quetzal by Pensa73
Z60 by ZMG
Deskmat
Colour samples
Room lighting
Outdoors - overcast, no direct sunlight
Direct sunlight
Vendors
Global vendor: Wuque Studio
Regional vendors: TBD
If you are interested in collaborating, please contact me on Discord (Keepo#3439) or through e-mail (keepo.and.meepo@gmail.com).
Feel free to join our discord server for updates!
Please note that the colours shown on screen and in render may not fully match that of the colour chips / samples. The colours are selected with reference to physical colour chips, but I do not have a good camera to take accurate photos at the moment.
Updates
07/04/2023 - posted IC.
08/04/2023 - updated renders of Fuji65, Quetzal and Z60.
05/05/2023 - minor kitting update. In the process of obtaining samples.
28/05/2023 - obtained colour samples.
My thanks to semi_clock for the deskmat, Lynn and Nindroid for helping with the novs, Pensa73 and MoMoBoy for the renders, Mr. Keebaholics and Divine for advice/opinion along the way, the Wuque team, as well as the folks in a certain server for their support.
« Last Edit: Sun, 28 May 2023, 03:40:13 by keepoto »
Offline keepoto
Re: [IC] WS Senkou
« Reply #1 on: Thu, 06 April 2023, 15:53:51 »
Reserved
Offline dededecline
    • Linktree
Re: [IC] WS Senkou
« Reply #2 on: Thu, 06 April 2023, 15:58:40 »
Some kitting suggestions:
* I'd move R1 End and Pg Dn to Numpad kit as they're used for 1800 layouts
* you can cut one of the 1u and one of the 1.25u bars in each bar color
GLWIC!
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [IC] WS Senkou
« Reply #3 on: Thu, 06 April 2023, 16:09:25 »
nice renders.
GLWIC  :thumb:
Offline AnonyMoose_
Re: [IC] WS Senkou
« Reply #4 on: Thu, 06 April 2023, 20:26:19 »
nice looking set, glwic
Offline aicyborg
Re: [IC] WS Senkou
« Reply #5 on: Thu, 06 April 2023, 22:32:36 »
disappointed that the move to WS will mean no international support whatsoever (the previous iteration has iso-uk in base) but gl
Offline sososoya
Re: [IC] WSPBT Senkou
« Reply #6 on: Fri, 07 April 2023, 01:42:33 »
好耶
 :D
Offline tactilesbad
Re: [IC] WS Senkou
« Reply #7 on: Fri, 07 April 2023, 02:57:09 »
good
iso-uk still meant no international support
Offline xLeHoy
  • weeb board enjoyer
« Reply #8 on: Fri, 07 April 2023, 08:10:48 »
Hey I know this guy
GLWIC
Offline keepoto
Re: [IC] WSPBT Senkou | Extra renders
« Reply #9 on: Sat, 08 April 2023, 09:34:51 »
08/04/2023 update
1. Updated some extra renders, including an extra shot of lake accents on Fuji65
2. Thank you for your feedback on GH / in IC form; currently considering minor kitting adjustment and will finalise after more feedback, hopefully by next weekend
Offline Raravin
« Reply #10 on: Sat, 08 April 2023, 10:52:10 »
GL with IC, I mostly never made an asuna yet with my SAO line due to just being so close to basic white and red sets. I do hope I was wrong and this sells nicely.
I will say you are taking a major risk with the Aincrad novelty and the straight up asuna deskmat.
Again, Good luck with IC I will be skipping asuna with my set line because I dont think I can do better then this :)
« Last Edit: Sat, 08 April 2023, 11:08:47 by Raravin »
Offline Vintage
« Reply #11 on: Sat, 08 April 2023, 20:14:06 »
Maybe not aligned with the theme, but I think this set would look better with matching red alphas instead of white. GLWIC
CM QFR w/ MX Reds  | Logitech G900
Offline keepoto
Re: [IC] WSPBT Senkou | 5 May update
« Reply #12 on: Fri, 05 May 2023, 08:52:06 »
5 May 2023 updates:
Minor kitting updates:
  • Moved R1 End and PgDn from Base to Numpad kit.
  • Included extra Backspace and Tab in Latin Alphas kit.
  • Removed 1 1.25u bar from Spacebars kit.
Currently obtaining samples from Wuque - expected to take a bit of time as Labour Day holiday just ended in China.
Pricing will be announced after samples / colours are confirmed.
Offline keepoto
Re: [IC] WSPBT Senkou | 28 May - colour samples
« Reply #13 on: Sun, 28 May 2023, 03:41:35 »
28 May Update:
Logistics took a bit more time than expected - finally have the colour samples!
The room lighting / outdoors photos are taken by friend using camera; the direct sunlight photos are taken by me using phone camera.
Room lighting
Direct sunlight
Pricing and vendors will be announced in due course.
