Author Topic: [IC]MKC75 Customize Keyboard - Full pricing, Vendor list, Pre-order is live now!  (Read 50682 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hello everyone,
We want to express our heartfelt gratitude for your unwavering interest and patient anticipation of MKC75 over the past few months.
We are also deeply appreciative of the valuable suggestions you have provided to us.
Now, with great excitement, we are thrilled to announce that MKC75 Pre-order is finally going to meet everyone!
Please take a moment to review the Pre-order information provided below.
MKC75 Pre-order Information
MKC75 Pricing
MKC75 Pre-order Page
Pre-order Time: From August 5th to August 31st.
Estimated Delivery: Start packing and sending to vendors and Mykeyclub direct customers around November based on the final order QTY.
Packaging Upgrade:
The current sales DATA is very WELL, so our team has upgraded the packaging to a NICE Carrying Case for this pre-order, allowing everyone to use our keyboard anytime and anywhere.
Vendor List
US: KeebsForAll 7 PM PDT 4th August
US: Cannonkeys 10 PM ET 4th August
Canada: Ashkeebs Midnight PST (GMT-8) 5th August
UK: Prototypist 9 AM BST (GMT+1) 5th August
Germany: Candykeys  6 PM (GMT+2) 6th August
Spain: ELOQUENTCLICKS 10 AM (GMT+1) 5th August
Italy: Coffeekeys 12 AM (GMT+2) 5th August
AU: SwitchKeys  5th August
South Korea: Geonworks 7 PM (GMT+9) 8th August
Singapore: Mecha.Store 10 AM (GMT+8) 5th August
Japan: Basekeys 5 PM (GMT+9) 5th August
Vietnam: MOKB STORE  8 PM (GMT+7) 5th August
Philippines: Zion Studios 8 PM (GMT+8) 5th August
Malaysia: Rebult Keyboards 8 PM (GMT+8) 5th August
Indonesia: KeebsMark  21:00 PM WIB (GMT+7) 5th August
Thailand: NTCH Keys 5th August
Bangladesh: KeyB 8 PM (GMT+6) 5th August
Argentina: LATAMKEYS 6th August
Colombia: Stiutech 9:00 PM (GMT-5) 4th August
Taiwan: 鍵盤好貴  9-10 PM 5th August
International: Mykeyclub 10 AM (GMT+8) 5th August
MKC75 Information
MKC75 Renders
Milky White        E-White
Pink        Lilac
Orange        Orange&Black
Black        Brown
Grey        Grey&Black
Wine Red&Black        Deep Blue&Black
Green        Green&Black
Silver        Silver&Black
E-White&Black        Black
Features
-Supports Caps Lock Indicator Light
-100% processed using CNC machining with 6063 aluminum case
-Compact 75% layout
-Three-in-one structural design( Top Mount, Plate Gasket Mount and PCB Gasket Mount )
-Supports tri-mode PCB(Wired, Bluetooth and 2.4ghz)
-Supports Plate, Half Plate, and Plateless Build
-Supports Rotary Knobs components and Light Signs, which are also compatible with JRIS75 Rotary Knob/Badge/LED Light Sign
-Supports Alu Internal Weight
-Multiple configurations available
-2 x 2200mha large battery capacity
MKC75 Specifications
- Typing angle: 7°
- Front height: 18.5 mm
- Material: Full CNC 6063 aluminum
- Dimensions: 320*134.4*33mm
- Three-in-one Structure: TOP Mount / Plate Gasket Mount / PCB Gasket Mount
- QMK/VIA Supported(wired)
- Support PCB stabilizers
- Unbuilt Weight
  With PVD WEIGHT: 1.693kg
  With Alu WEIGHT: 1.425kg
- Built Weight
  With PVD WEIGHT: 1.86kg
  With Alu WEIGHT: 1.592kg
We have adopted a three-in-one structural design for the internal structure, which can support regular positioning plate gaskets, PCB gaskets, and the long-disappeared TOP Mount structure.
Thanks to the consistent frame of the compact 75% layout, we can make the three structures perfectly compatible.
-TOP Mount
-Plate Gasket Mount
-PCB Gasket Mount
Case Colors Options:
-4 E-coat case: E-white, Milky White, Pink, Lilac
-6 Anodized Case: Orange, Black, Brown, Grey, Silver, Green
-7 color combose case:E-White&Black, Orange&Black, Grey&Black, Silver&Black, Wine Red&Black, Deep Blue&Black, Green&Black
Weight Options:
Designs:
- Blank Weight (Default)
- Cursive Text Weight (Add-on only)
Colors:
-4 Alu Weight: Gold/Silver/Black/Rose Gold
-6 PVD Weight: Gold/Silver/Black/Blue/Rose Gold/Chroma
PCB Options:
-Wired Flex Cut Hotswap PCB( 1.2mm, Multi Layout ,7u split spacebar, No Per-key RGB, support QMK and VIA )
-Wired Solder PCB / Wired Non-Flex Cut Hotswap (1.6mm, Multi Layout,7u split spacebar, No Per-key RGB, support QMK and VIA )
-Wired Per-Key RGB Hotswap PCB (Add-on only, 1.6mm, Non-Flex Cut, ANSI Layout, support QMK and VIA )
-Tri-mode ANSI+ISO Hotswap PCB (1.2mm, Non-Flex Cut, No Per-key RGB, support Mykeyclub Software)
Tri-mode ANSI Hotswap PCB upgraded to be compatible with ISO.
Noted: The Tri-mode technical support is provided by IRISLab. Really appreciate their support and help.
7 Plates are available
-Plateless
-Flex Cut Plates: FR4, ALU, Brass (Add-on only)
-Non-flex Cut Plates: PC, POM
-Alu and FR4 Half-plate (Add-on only)
Noted: We highly recommend using a PC/ POM/FR4 plate for Tri-mode PCB because the Brass and ALU plate will have a little affection for connectivity.
What's Included in MKC75?
- Full CNC Aluminum Top case *1
- Full CNC Aluminum Bottom case *1
- Weight(Anodized Alu Weight or Stainless steel PVD Weight) *1
- Internal Alu Weight (Only for the Tri-mode Version Case) *1
- PCB  *1
- Plateless or Plate  *1
- IXPE Foam *1
- Poron Case Foam *1
- Poron Plate  Foam *1
- Type-C Daughterboard with JST Cable *1
- PCB GAS Silicone Column *12
- Plate GAS Silicone Sock *18
- Top mount screw and spacer *12
- PCB stabilizers o-ring *12
- Footpad *6
- Poron case strip *6
- 1.6mm hex key *1
Gift(will not send make-up or replacements)
- 1 Pack of Extra Screw
  M2x3mm cylindrical head screw *2
  M2x8mm cylindrical head screw *2
  M3x12mm countersunk screw *2
  M3x6mm countersunk screw *2
- 2200mha battery (Only for the Tri-mode Version Case) *2
- Silicone pad of battery compartment (Only for the Tri-mode Version Case) *2
MKC75 Review Links (Stay Tuned for More)
Content-------------Creator Prototype
Switch and Click-------------Green Case+Chroma PVD Weight
Hipyo Tech-------------Lilac Case+Chroma PVD Weight
Simulator Tech-------------Green Case+Gold PVD Weight
whnkeys - Soundtests-------------Green Case+Gold Alu Weight
Rx003-------------Pink Case+Rose Gold Alu Weight
KSJ KeeB-------------Silver&Black Case+Chroma PVD Weight
MechTech Keyboards-------------Deep Blue&Black Case+Blue PVD Weight
Captain Sterling (Prototype)-------------Orange Case+Black PVD Weight
승업키보드 SeungupKBD -------------Brown Case+Silver PVD Weight
apiarykeyboards -------------E-White Case+Chroma PVD Weight
Mykeyclub Team
We are a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys.
Please participate in our MKC family for more discussions and future updates.
MKC75 IC Form
Mykeyclub discord
Mykeyclub Ins
Best Wishes
Mykeyclub Team
« Last Edit: Thu, 10 August 2023, 04:23:45 by Mykeyclub »
Offline kmnov2017
For that price point, this should sell like hot cakes.
A few suggestions:
The cursive writing at the back does NOT look nice, consider replacing with your MK logo instead.
Green & Yellow appear to be missing, these are quite a popular colour options
If you want to increase interest (And demand), opt for non standard colours. Examples: blueish green (Refer to Tind's Ultramarine), anodized bronze, anodized copper, dark charcoal, etc.
Offline Boyten8
This kind of reminds me a lot of the Jris but with more mounting styles. Estimated typing angle? Protos?
Offline tactilesbad
provide a teal variant and I'll buy 2
teal and orange
Offline alper_maestro
According the pictures above, it is 7 degree
Offline aicyborg
Please get rid of the writing on the back weight. You got it right on Jris75, blank weight is just fine.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
A few suggestions:
Thank you for your feedback and suggestions,please also fill in the IC form of the color you like, thanks!
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
The typing angle is 7°, and we will update prototype photos later.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
teal and orange
Please also fill in the IC form of the color you like, thanks.
Offline Kooks
Price is crazy. Having all the options like plateless, gasket, top, and half-plate is pretty impressive. Change the engraving at the back and this is would be better. Interested to see how it sounds but even so still really good board from what I see.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thank you for your suggestion!Please stay tuned for future updates.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thank you for your suggestion.
Offline Robert.Lussier5
Filled out the IC
Also included teal or dark teal as a color.
Would highly recommend a fair or forest green too.
Austin R3 - Green // Austin R3 - Purple // Custom Acrylic Austin - Clear // Rekt1800 - Blue // Cypher r4 - Black // Boston - Sparkle Black // Balance - White // Glitch - Green // Shelby80 - Navy // Odin - Silver // Zoom65  Red // QK65 - Black // Link65 - Lilac
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Filled out the IC
We will consider it,thanks!
Offline EdgeOfInfinity
i too prefer this to the JRIS stuff. & agree on removing the text on weight, has never looked good imo.
at that price though, i'll def be keeping an eye out for build streams!
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thank you for your support, and please also kindly provide your feedback in the IC form.  ;)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi everyone, we have made the following updates to MKC75, please see below:
1.Caps Lock Indicator Light
2.Due to feedback received through the IC form indicating a preference for green, we've added Green and Green & Black as available case colors.
3.We have added 7u split spacebar layout to the Hotswap PCB and Solder PCB, as well as the Plates.
4.As the voting results showed that majority of participants preferred Alu and FR4 as the two materials for the Half-plates, therefore we have chosen Alu Half-plate and Fr4 Half-plate.
Offline Dmitri
What material is the PVD weight?
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
The material of PVD weight is stainless steel.
Offline Mykeeb
Can't wait for the GB :thumb:
Offline aerbag
Side tab mounting for top mount????
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thanks for your support :D
Offline Rhienfo
  • GOTHETIGES
Assuming you maintain that price point this seems interesting, +1 on the text removal, even on the frog it doesn't look very good.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi, MKC75 is a traditional Top mount structure, you can refer to this picture:https://imgur.com/dzTac3u
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thank you for your suggestion, and please also kindly provide it in the IC form.
Offline Deer
I see its the same colors being used for the jris80, other than brown I dont remember seeing that, but that being said I wish the greens for either wasn't so bright and more of a dark pine green or so, I know generally colors aren't altered or changed often
« Last Edit: Tue, 16 May 2023, 18:04:10 by Deer »
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
These two colors of green won't be too bright, they both belong to the dark green spectrum. You can follow up by checking out the content creator's videos and our prototype for further reference.
Offline LosTaquitos
  • Professional Procrastinator
    • Keebs.gg Profile
I am very interested in the milky white case color, how does it compare to the Noctua beige color?
E-White & Brass Sonnet | Black Sesame V2 | GMK Civilizations
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Currently, I don't have any specific products in the Noctua beige color. However, based on the images I found, in terms of a direct comparison between the two colors, Milky white of MKC75 is a brighter and more pristine white, while Noctua beige is a warmer and earthy beige color. (Please note that this conclusion is based solely on the images I found of the Noctua beige color, so it can be considered as a reference.)
Additionally, you can also check out videos of prototypes in Milky White color created by content creators later on. We will also provide updates with prototype images of the MKC75 as soon as possible, so you can compare their differences then.
Offline Rhienfo
  • GOTHETIGES
Looking back at this project, I just realized there were side mounting points. Is there any reason for this and I think they should be removed from the final product if you can.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
The side mounting points in the MKC75 are primarily designed for people who prioritize stability over achieving a softer typing feel. These mounting points help evenly distribute typing forces across the keyboard, resulting in a more stable and consistent typing experience. It's worth noting that whether you use a Top Mount or PCB Gasket Mount, you have the option to choose whether or not to install the side screws or gaskets based on your personal preference for typing feel and sound.
Offline vhaarr
Please stop using imgur for image hosting. I can't see the images at all. imgur.com returns http 429 ("too many requests").
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
I apologize for the inconvenience you've experienced. You can try changing your network to see if it helps. Additionally, we will also search for alternative image hosting websites. If you have any better website recommendations, please let us know. Thank you!
« Last Edit: Mon, 22 May 2023, 00:46:15 by Mykeyclub »
Offline nessMINI
Everything about this keyboard is fabulous! Everything expect for that absolutely hideous logo on the back plate. Who's idea was that?? yuck!
its almost as bad as the "JRIS" logo on the back of their keyboards.
Offline vhaarr
Thank you! I found https://postimages.org/ via https://old.reddit.com/r/imguralternatives/comments/lxpd2h/list_of_community_verified_and_safe_imgur/ and it seems to work find but I have no idea how much bandwidth they can handle or whatever.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Much appreciated!
Offline Mykeeb
Any updates
Offline sketch3v
  • Sketch (astro-keys)
    • Astro
In my opinion the most functional and good-looking layout. I also love the fact that it's 7 degrees angle cause most of the boards are flat af.
Offline Typel
The GB will be around july as mentioned by themselves on Reddit, can't wait to have my first budget gb keyboard :D
Hope it comes in a carrying case aswell like their Jris series :thumb:
I'm the Typel
Offline aicyborg
Specifically is there any update on final pricing that you can share? You proudly touted $99 as the price tag for this. Does that still seem possible?
Offline nessMINI
That logo on the back is butt ugly.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Any updates
The prototypes have been sent to content creators one after another, and we will update in July.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thank you, nice to hear you say that.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Sorry, we work hard to provide this very budget price, so we will not provide carrying case. :(
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Don't worry, it's possible.
Offline Typel
That's sad to hear, I would even pay for the carrying case as extra but oh well  :(
I'm the Typel
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
We will consider offering the carrying case as an optional extra purchase.
Offline ppatches24
I filled out the IC check form, but also want to leave a comment here. The cursive on the weight should be your MK logo, that would look so clean. And that green that is in the renders is PERFECT! Please do not do a lighter or darker green. That green in the renders is so unique and we don't have enough of that color green board out there.
Thank you for this project and I cant wait to buy a couple of them.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Thank you for leaving this comment and thank you for your support. I'm glad you like the MKC logo, we'll work hard to make sure the colors of the prototypes and renders are consistent.
