Author Topic: [GB] Vanguard65 | GB completed - Extras In-Stock Now  (Read 165953 times)
Offline MrEsosmao
« on: Tue, 09 May 2023, 16:51:25 »
MUST READ: We can’t thank you enough for all the love and support you’ve given us with our Vanguard65 keyboard midi 🙏The amount of pre-orders/GB have exceeded MOQ expectations and beyond.🚀Much ❤️ to all of the keyboard content creators/hobbyists who helped us with photos, reels, and in-depth product reviews.
    Vanguard65 (VG65)
    EXTRAS AVAILALBE HERE
    Gallery
    Sound Tests & Overview
    Specifications
    Plate Materials
    Plateless or Full Aluminum, FR4, PC, POM, Carbon Fiber, Brass
    Typing Angle
    6.5 degrees
    Front Height
    19.2mm
    Weight
    Brass, sandblasted CC
    Mount
    Gasket Sock PCB Mount
    Case Materials
    Top - Aluminum 6063 (top)
    Bottom - Polycarbonate White Frosted or Black Aluminum 6063
    PCB
    • Custom designed hotswap with underglow
    • ANSI/ISO hotswap support
    • QMK/VIA compatible
    • Split backspace support
    • Kailh hotswap sockets
    • Universal USB-C daughterboard
    What does that slider do?
    Prioritizing User experience first, we built an extension within VIA for a seamless user experience to switch the slider on-the-fly with ease.
    • Layers Shift: Switch between keyboard layers by allowing slider to to easily transition between your different key bindings set within VIA.
    • MIDI encoding: Let the slider act as a MIDI CC, meaning you can program it to pass values to supported software in order to make adjustments on the fly beyond music and photo/video production. We will provide more details of a recommended list of DAW software and open-source apps that you can download free in the builders guide.
    • RGB Brightness Control: Set the brightness levels of the case underglow.
    • Volume Control: Command your system volume with MIDI companion programs
    Colorways
    Primary
    • Forest Green
    • White
    • Black
    • Ruby Star Purple
    Limited Edition
    • Ethereal Pearl Oil Slick (available via raffles)
    • MVKB Terminal x Keebfront (available via raffles and Keebfront website)
    Etheral Pearl Oil Slick Limited Edition
    Prior to the official GB, we created an exclusive limited edition colorshift cerakoted finish case.
    Most went through a private GB but the remaining kits will be available via raffles.
    Less then 25 kits of this version will be available and shipped immediately, early access before anyone else.
    Collabs
    VoxelMods x VG65 Artisan Cables
    Optional, premium hand-made straight cables that you'll be able to purchase to compliment the Vanguard65 keyboard color you choose.
    This will be available during the duration of the group buy. Note: This collaboration is an exclusive to US customers only.
    • Pricing: $125
    Terminal x VG65 Limited Edition
    I'm excited to announce that a limited edition collaboration with MVKB is underway. Limited kits of this version will be arriving once GB ends.
    If you don't live in the 🇺🇸 but are interested in picking this kit up, then Keebfront
    The kit will include:
    • Custom Color: 9-5 Beige on black
    • Terminal R2 keycaps (Optional)
    • Custom knob
    • Custom slider
    • VoxelMods custom straight cable (Optional)
    Layout Options
    Default
    - 65% hotswap pcb
    - ANSI/ISO support
    - Split backspace support
    What is VG65 about?
    It’s been a long dream of mine to design a custom board that provides something truly personalized to add to the keyboard collection. The Vanguard65 (VG65), is a keyboard kit that serves both aesthetic beauty and function while incorporating a slider and knob. The case design is inspired by the Porsche Cayman, which is a perfect representation of a timeless masterpiece.
    Why the name Vanguard?
    Noun. “A group of people leading the way in new developments or ideas”.
    IMO - The word, Vanguard, is representative of what I have been able to design, build, and achieve in 2022. Starting with the creation of DOOM switches, which is the 1st of its kind to introduce a new PE material called HDPE into the hobby. Following that, I designed and mass-produced BIGWIG switches which is the 1st switch to introduce and use PBT material as a housing in the Western market. BIGWIG is also the first and only switch to use HDPE/PBT for top and bottom housing combination. Additionally, I introduced a new small switch manufacturer named Meirun. Lastly, the word Vanguard is just f**king cool.;D :D
    Group Buy Information
    Note: Prices will vary for each region.
    Base Kit: $274.99
    • Plate: PC 1x
    • Hotswap PCB 1x
    • Weight: Brass, sandblasted CC 1x
    • Foam dampening kit (case and plate)
    • Choice of PC or Aluminum bottom
    • Option to engrave slider notches +$10
    • All needed items to build kit such as screws, building guide QR card, gasket socks, daughter board for USB, rubber case feet, rotary encoder, rotary knob, fader encoder, fader handle.
    Extras
    • Plate: Aluminum
    • Plate: FR4
    • Plate: POM
    • Plate: PC
    • Plate: Carbon Fiber
    • Plate: Brass
    • Hotswap PCB
    • Aluminum bottom
    • PC bottom
    • VoxelMods Straight Cable: Forest Green
    • VoxelMods Straight Cable: Black
    • VoxelMods Straight Cable: White
    • VoxelMods Straight Cable: Ruby Star Purple
    • VoxelMods Straight Cable: Terminal LE
    Timeline:
    NOTE: Time will vary depending on your region. We suggest you contact the vendor for your region.
    • GB Start Date: May 24, 2023 at 7:00 PM-CST (USA)
    • GB End Date: June 24, 2023
    • Delivery Date: Q4 2023
    Main Vendors:
    Show your support
    Add this to your signature to show your support
    [/list]
    Code: [Select]
    [url=https://geekhack.org/index.php?topic=120293.0][img width=540 height=120]https://i.imgur.com/UffSI7e.png[/img][/url]
    Code: [Select]
    [url=https://geekhack.org/index.php?topic=120293.0][img width=540 height=120]https://i.imgur.com/Aab5gVr.png[/img][/url]
    « Last Edit: Mon, 07 October 2024, 20:38:55 by MrEsosmao »
    Offline MrEsosmao
    Re: [GB] Vanguard65 | Starts May 24th
    « Reply #1 on: Wed, 10 May 2023, 21:30:49 »
    Update
    It's been a minute since I've provided an update. Almost forgot about this GH post as it's been quite busy.
    We'll be getting the first batch before the end of the year (US for now)!  :p Pending any QC issues, we may be able to fulfill units as they come in.
    To the lucky few that were able to get their hands on the Colorshift version, the supplier is building the crates in order to ensure added protection before sending off to freight forwarder.  :cool:
    Lastly, please follow us on Discord or Instagram for the latest updates, photos and more.
    Update
    We can’t thank you enough for all the love and support you’ve given us with our Vanguard65 keyboard midi 🙏The amount of pre-orders have exceeded our MOQ expectations and beyond.🚀 Much ❤️ to all of the keyboard content creators/hobbyists who helped us with photos, reels, and in-depth product reviews.
    If you still haven’t ordered your Vanguard65, it’s not too late - KEEBFRONT.COM
    Updates
    The Terminal x Vanguard65 collab is ready to pre-order.
    Since we had mentioned exceeding MOQ numbers for the group buy, we will be opening up pre-orders for the MVKB Terminal x VG65 collab kit. 👀
    It will be setup as fcfs on our website. However, if you don't live in the US but are interested in buying this kit up then contact Keebfront.
    Update
    New sound test is out now by Hi Keebs. See Sound Test & Overview section of main post.
    Update
    To address improvements regarding the PC bottom for VG65. This is a MUCH improved version then the samples sent out to Content Creators.
    We heard some of the feedback regarding underglow "hotspot" concerns and have been working on a better solution to combat this.
    As you can also see (in the 2 images below), I've increased the "frost" finish to help diffuse more the PCB underglow for an even spread in the front lip area where the hotspots are more identifiable.
    Update
    New sound test is out now by Preston's Thoughts. See Sound Test & Overview section of main post.
    Update
    Photo uploaded showcasing Aluminum bottom and forest green top frame from Alexotos. See Gallery section of main post.
    Update
    Video uploaded showcasing Aluminum bottom and forest green top frame from Alexotos. See Sound Test & Overview section of main post.
    Update
    Short reel added showcasing product overview and sound test using PC plate and case foam (no plate foam) by Captain Sterling. See Sound Test section of main post.
    Update
    GROUP BUY IS LIVE!!! :eek: :p
    All the time spent designing, working with other partners, and listening to the community feedback - the wait is finally over!
    Thank you for embarking on this journey. Without you, we wouldn't be where we are today.
    Update
    Overview video released on YouTube by Captain Sterling. See Sound Test section of main post.
    Update
    More photos added of E-White with PC bottom using Mode Tomorrow keycaps.
    Update
    Additional photos added of E-White with PC bottom.  ;D
    Also added photos of plate extras.
    Update
    Twitch streamer friend, Captain Sterling is doing a live build E-White with PC bottom :eek:
    When: Today at 2:00 PM-CST
    Where: Twitch
    Update
    Added new sound test using Plateless with no foam config. See [Sound Test] section of main post.
    Update
    Added a new vendor for Chile region.
    Update
    Twitch streamer friend, nainaigogo will be doing a live build of Vanguard65 on Twitch! :eek:
    When: May 15th at 6:30 PM-CST
    Where: Twitch
    « Last Edit: Wed, 08 November 2023, 16:39:36 by MrEsosmao »
    Offline ZippoW2905
    « Reply #2 on: Thu, 11 May 2023, 00:04:31 »
    I'm so ready for this! Good job, team!
    Offline ZippoW2905
    « Reply #3 on: Thu, 11 May 2023, 00:07:06 »
    Looking forward to the limited color raffle as well!
    Offline sowleo
    « Reply #4 on: Thu, 11 May 2023, 17:05:38 »
    Why can't I see all of your photos?
    trap the cat
    « Last Edit: Thu, 11 May 2023, 20:30:16 by sowleo »
    Offline MrEsosmao
    « Reply #5 on: Thu, 11 May 2023, 19:46:37 »
    Not sure what you mean. Could you provide more details?
    Offline sowleo
    « Reply #6 on: Thu, 11 May 2023, 20:23:17 »
    I do not know on my screen the image is all black.
    Offline MrEsosmao
    « Reply #7 on: Sat, 13 May 2023, 10:23:00 »
    Update
    Where: Twitch
    Offline MrEsosmao
    « Reply #8 on: Mon, 15 May 2023, 13:05:19 »
    Update
    Offline MrEsosmao
    « Reply #9 on: Tue, 16 May 2023, 12:03:26 »
    Update
    Offline MrEsosmao
    « Reply #10 on: Fri, 19 May 2023, 14:09:17 »
    Update
    Where: Twitch
    Offline MrEsosmao
    « Reply #11 on: Sun, 21 May 2023, 12:59:25 »
    Update
    Offline MrEsosmao
    « Reply #12 on: Mon, 22 May 2023, 19:03:17 »
    Update
    Offline MrEsosmao
    « Reply #13 on: Tue, 23 May 2023, 17:27:17 »
    Update
    Overview video released on YouTube. See Sound Test section of main post.
    Offline MrEsosmao
    Re: [GB] Vanguard65 | Starts May 24th 7:00PM-CST
    « Reply #14 on: Wed, 24 May 2023, 11:48:57 »
    Update
    More photos added of E-White with PC bottom using GMK Iceberg for those that love that ice cold feel :cool:.
    Offline MrEsosmao
    « Reply #15 on: Wed, 24 May 2023, 21:13:46 »
    Update
    Offline MrEsosmao
    Re: [GB] Vanguard65 | LIVE NOW until June 24
    « Reply #16 on: Fri, 26 May 2023, 05:05:56 »
    Update
    New video added. See Sound Test section of main post.
    Offline MrEsosmao
    « Reply #17 on: Fri, 26 May 2023, 17:31:50 »
    Update
    Short reel added showcasing product overview and sound test using PC plate and case foam (no plate foam) . See Sound Test section of main post.
    Offline MrEsosmao
    « Reply #18 on: Wed, 31 May 2023, 23:05:29 »
    Update
    Offline MrEsosmao
    « Reply #19 on: Fri, 02 June 2023, 11:54:19 »
    Update
    Offline MrEsosmao
    « Reply #20 on: Mon, 05 June 2023, 13:15:47 »
    Update
    Offline MrEsosmao
    Re: [GB] Vanguard65 | LIVE until June 24
    « Reply #21 on: Tue, 06 June 2023, 19:45:04 »
    Update
    As you can also see in the images, I've increased the "frost" finish to help diffuse more the PCB underglow for an even spread in the front lip area where the hotspots are more identifiable.
    « Last Edit: Tue, 06 June 2023, 19:47:50 by MrEsosmao »
    Offline MrEsosmao
    Re: [GB] Vanguard65 | GB LIVE until June 24
    « Reply #22 on: Mon, 12 June 2023, 14:33:17 »
    Update
    Photos added to gallery of green case with aluminum bottom.
    Offline MrEsosmao
    Re: [GB] Vanguard65 | GIVEAWAY + GB LIVE until June 24
    « Reply #23 on: Tue, 13 June 2023, 01:08:55 »
    Update
    Join Giveaway running this week! :p
    Offline MrEsosmao
    « Reply #24 on: Wed, 14 June 2023, 08:52:23 »
    Update
    Offline MrEsosmao
    « Reply #25 on: Thu, 15 June 2023, 20:10:13 »
    Raffles for the limited edition colorshift are happening on discord!
    Offline MrEsosmao
    Re: [GB] Vanguard65 | Colorshift LE Raffles, Giveaway LIVE
    « Reply #26 on: Sat, 17 June 2023, 14:55:22 »
    Update
    New in-depth full review is out now by Dutchmasterw.
    Offline MrEsosmao
    Re: [GB] Vanguard65 | ends June 24th
    « Reply #27 on: Mon, 19 June 2023, 10:10:03 »
    Updates
    « Last Edit: Mon, 19 June 2023, 10:15:34 by MrEsosmao »
    Offline MrEsosmao
    Re: [GB] Vanguard65 | GB ends June 24th
    « Reply #28 on: Thu, 22 June 2023, 17:36:30 »
    Update
    2 days left to join group buy! Thanks all who helped us exceed MOQ and we'll be starting production soon.
    Offline MrEsosmao
    Re: [GB] Vanguard65 | MOQ reached/surpassed - GB ends June 24th
    « Reply #29 on: Fri, 23 June 2023, 16:44:37 »
    Update
    Offline MrEsosmao
    Re: [GB] Vanguard65 | GB closed
    « Reply #30 on: Wed, 28 June 2023, 11:21:43 »
    Update
    Group buy has officially closed🙏Thanks all who joined!!
    Offline MrEsosmao
    Re: [GB] Vanguard65 | GB closed - In Production
    « Reply #31 on: Wed, 02 August 2023, 12:48:47 »
    Update
    Currently in production. Goal is to deliver by Q4 2023.
    Offline MrEsosmao
    « Reply #32 on: Wed, 08 November 2023, 16:38:57 »
    Update
    Offline ocular
    « Reply #33 on: Wed, 15 November 2023, 03:09:11 »
    So the boards (at least for non-US) won't be delivered in Q42023?
    Offline PrizeOcelot5911
    « Reply #34 on: Wed, 22 November 2023, 04:03:47 »
    I like the dark green keyboard color, which gives people a calm feeling. :thumb:
    Offline MrEsosmao
    « Reply #35 on: Thu, 14 December 2023, 13:21:55 »
    Q1 2024
    Offline MrEsosmao
    Re: [GB] Vanguard65 | GB completed - Extras In-Stock Now
    « Reply #36 on: Mon, 07 October 2024, 20:35:37 »
    Hey all, Thanks for you support! Just wanted to announce that on the Keebfront website. Extras are available!
    https://keebfront.com
