Author Topic: [IC] BOLO LOVELESS ☺ | GB live!  (Read 9709 times)
Offline Aquarius
« on: Fri, 26 May 2023, 13:06:03 »
Hello everyone! This is Aquarius. I would like to introduce you to the first set of keycaps I designed, named “LOVELESS”.
Intro
This set of keycaps is full of lovely pink, with pure blue legend, is inspired by the changes in my mood when my last relationship broke up, including pain, sadness, depression, and finally slowly letting go. Pink is my favorite color and blue is his favorites, so only these two colors are used in the whole design. In fact, I was not familiar with keycaps before, because he liked it, so I gradually got to know it and designed this set. I hope you can also feel my mood and love!
Kits
Samples
Specifications
profile: cherry
legend type: Dye-sublimation
Material: PBT
thickness: 1.5 mm
Number of keys: 160
Manufacturer: BOLO Keys
DISCORD
Aquarius
Iris | BOLO Keys#8957
Pricing and Lead time
TBA
Vendors
USA: Otakeeks
CA: Ashkeebs
EU: KEYGEM
UK: Prototypist
OCE: Daily Clack
SEA: Qwertyqop
Closing thoughts
I’m very excited with how my first set has came out. We are working hard to identify vendors in all regions and the samples have been produced. As soon as all vendors are confirmed, we will start Group Buy. Thank you for your support!
« Last Edit: Mon, 19 June 2023, 10:26:32 by Aquarius »
Offline Magnificent Bureaucrat
  • Sooooo much red tape
Re: [IC] BOLO & Aquarius LOVELESS ☺
« Reply #1 on: Fri, 26 May 2023, 17:27:11 »
Looks like you're missing a 1.25 shift and R4 alpha ( <> or \ ) to cover terminal ISO.
I can't see anybody wanting to use novelties to fill those gaps.
Offline Rhienfo
  • GOTHETIGES
« Reply #2 on: Fri, 26 May 2023, 20:43:38 »
Please work on your kitting, there is no hhkb support in this set (Split backspace, R1 |\ key, R3 control) which hhkb support should be in every base kit IMO, you're also missing terminal ISO keys which someone else has mentioned in the thread, which if your including iso you need to have that as well.
Offline Aquarius
« Reply #3 on: Mon, 29 May 2023, 02:53:54 »
Because the price of this set is very cheap, considering the cost, we have reduced a few keys, but we will consider adding some later. :D
Offline Akele
« Reply #4 on: Mon, 29 May 2023, 12:36:22 »
With that being the case, you may want to remove ISO keys entirely to reduce costs further, as without proper terminal ISO support, this set isn't going to be much use to ISO users.
I say this as a UK ISO user.
Offline niakulah
« Reply #5 on: Mon, 29 May 2023, 20:50:02 »
A mono latin Poco. Tempting.
Offline Aquarius
« Reply #6 on: Tue, 30 May 2023, 02:20:47 »
Offline MateKeys
« Reply #7 on: Tue, 30 May 2023, 09:55:34 »
I really like this style.
It's cute and I'm looking forward to it!
Offline keepoto
  • HHKB top for TKL pls
« Reply #8 on: Tue, 30 May 2023, 11:15:59 »
minivan support but no double decker bus hhkb support!
also you might be missing some keys for iso
Offline Aquarius
« Reply #9 on: Wed, 31 May 2023, 02:44:13 »
thanks!  ;)
Offline Aquarius
« Reply #10 on: Fri, 02 June 2023, 03:40:28 »
hello, everyone. We'll add these keys that have mentioned and hhkb support. :) please continue to keep attention.
Offline Aquarius
« Reply #11 on: Fri, 02 June 2023, 03:41:45 »
all right! we'll add these keys. ;)
Offline Aquarius
Re: [IC] BOLO & Aquarius LOVELESS ☺ | kits modified and vendors confirmed
« Reply #12 on: Mon, 05 June 2023, 07:46:57 »
The base kits and vendor are updated! :thumb:
Offline Aquarius
Re: [IC] BOLO & Aquarius LOVELESS ☺ | GB live!
« Reply #13 on: Tue, 06 June 2023, 03:44:15 »
Hello, everyone. GB live today!
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #14 on: Tue, 06 June 2023, 04:29:00 »
Love the colors!
Offline Aquarius
« Reply #15 on: Tue, 06 June 2023, 06:10:28 »
Offline Aquarius
« Reply #16 on: Sun, 11 June 2023, 05:34:16 »
GIVEAWAY live! please pay attention to regional vendors!
Offline dvorcol
  • Discord: dvorcol_5071
Offline Aquarius
Offline MateKeys
Re: [IC] BOLO LOVELESS ☺ | GB live!
« Reply #19 on: Mon, 26 June 2023, 10:31:08 »
Loved your work it was truly amazing! :thumb: :thumb:
We are a heat sublimation supplier, can we work with you please? Thank you. :D
