Author Topic: [GB] Helix Aaru65 | start from 4th July  (Read 14666 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Sun, 02 July 2023, 20:59:12 »
Aaru65 (Aten)
Designed by Helix Lab
Index
- What's changed since IC
- Unboxing, Building & Typing Tests
- PCB and Layouts
- GB Details
- Vendors
- Social
▼ The weight is surface treated with PVD coat then mirror polished. Two different weight designs will be offered in the GB. (Due to the low weight production yield for dual process weight, the entire weight piece will be PVD Mirror.)
▼ According to the suggestions from creators, Helix Lab has re-designed the scarab and added a POM insert to provide better stability and prevent it from falling off or rattling.
Please see the IC post for more details: https://geekhack.org/index.php?topic=118707.0
Alexotos
Twitch VOD
BlackSimon
Frankthetank_16
Tofu Types
Lewis Toh
PCB and Layouts
▼ PCB has two option, both use QMK firmware and are VIA compatible:
└ Hotswap: ANSI layout, 6.25u spacebar, per-key RGB, supports SignalRGB (https://signalrgb.com/)
└ Soldered: ANSI and ISO layouts, split backspace and left shift support, stepped caps support, 7u spacebar support.
GB Details
There will be two editions:
└ Standard Edition: with embossed hieroglyphs on the top case
└ Divine Edition: with double-anodized hieroglyphs on the top case in gold color
▼ Standard Edition - Black (Anodized)
▼ Standard Edition - Safari (Anodized)
▼ Standard Edition - Ivory (Electrophoresis)
▼ Standard Edition - Wildcard (Random Mystery Colors)
▼ Divine Edition - Black (Anodized)
▼ Divine Edition - Silver (Anodized)
▼ Divine Edition - Wildcard (Random Mystery Colors)
GB start time: 4th July 2023 20:00 EST
GB end time: 23rd July 2023 23:59 EST
This groupbuy will be unlimited.
Shipping date is estimated to be Q4 2023
Pricing for different versions is as follows (pricing may vary between vendors):
- Standard Edition: $430
- Wildcard Standard Edition: $485
- Divine Edition: $580
- Wildcard Divine Edition: $640
- Extra Weight: $105
- Extra PC Plate + Poron Plate foam: $15
- Extra Alu Plate + Silicon Plate foam: $25
- Foam Kit: $9(Including Case foam, Plate foam and Under Switch IXPE foam)
- Extra Hotswap PCB: $41
- Ti Badge: $50
- Aluminum Badge: $25
Note: if this badge is added in your order, please make sure you choose the default PCB with unsoldered slider module or purchase an extra PCB with unsoldered slider module.
Vendors
Worldwide: ClickClack
OCE: Allcaps
SG: Ktechs
TH: Aiglatson
Social
Join ClickClack’s Discord for latest update, discussion, questions:
Follow Helix's Discord:
Follow ClickClack's IG for other new projects:
« Last Edit: Tue, 04 July 2023, 05:22:56 by ClickClack.io »
Offline hzh0525
Re: [GB] Helix Aaru65 | start from 4th July
« Reply #1 on: Mon, 03 July 2023, 17:40:05 »
Can't wait to secure one!
    • clickclack.io
« Reply #2 on: Tue, 04 July 2023, 00:16:05 »
Thanks for your patience!  :cool:
